Old 05-21-2012, 05:44 PM
tmwtf tmwtf is offline
Mein Auto: 2001 325CI
How do you synch the top motor on a 2001 325ci
The dogear on my top broke and was pressed between the top framing and the upper interior ledge near the back window. Well, the top would not close all the way (about 2" away from closing) and that is not good. I disengaged the top motor using the button on the black box in between the rear seats. Then I used the hex wrench to fully close the top. So, I now need to re-synch my motor for the top. I saw a clip on the E36 but do not know if the procedure is the same for the E46. Can anyone help with some instructions on how to synch my top motor(s). Thank you tmwtf
Old 05-21-2012, 08:23 PM
jvr826's Avatar
jvr826 jvr826 is online now
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
A post I found on Bimmerforums...
http://forums.bimmerforums.com/forum...73&postcount=9
pulled out the allen wrench and put it in the keyhole next to the emergency button, and cranked it. The button "popped" back up, and then I pushed the top open button; and it sucked down. Then pushed top close and things worked as they should.
Jeff R.
Old 05-29-2012, 09:48 AM
atkinst744 atkinst744 is offline
Mein Auto: 2001 BMW 325ci
2001 BMW 325ci - top problems
I am experiencing the same problem. How do I reset the motors after I pushed the emergency release button. Thank you.
Old 06-02-2012, 01:22 PM
Thanks Jeff. I will try to reengage the top. If I get it to work, I will let you know. tmw
Old 06-02-2012, 01:42 PM
That did not work for me.
Originally Posted by jvr826 View Post
I used the hex wrench to released the button on the motor control box in between the back seat. I pressed the top back button (my top is in the normal up position) and nothing happen. I remember when the button was pressed in and I pushed the button to put the top back and I could hear the top motor running. Well, I did not hear anything after I tried the same thing after the button popped out. Maybe I blew a fuse somewhere. I will check some threads to find the fuse locations for the top. Any other suggestions would be appreciated. tmw
Old 06-02-2012, 04:25 PM
SJBimmer SJBimmer is online now
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Check the convertible forum at e46fanatics.com all sorts of useful info there. I believe the re sync procedure is also in the owners manual, although not positive.
Old 06-03-2012, 05:22 AM
Re sync of 2001 CI
I appreciate your suggestion but have not found any information on the re sync yet. I found the fuses, checked them all and afterwards when I pressed the top back button, I could hear the motors running again. So, at least there is power to the motors. Thanks. tmwtf
