Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 06-04-2012, 04:07 PM
infernoM3 infernoM3 is offline
Mein Auto: 535
Efficient Dynamics Start/Stop
Do you guys use this on your M3? I remember when I picked up my car on ED the lady told me about it but I had her deactivate it. I just got my car back in US and dont know how to reactivate it and if I should. I know it helps on gas so I was thinking of doing it. But I'm worried in stop and go traffic it would get annoying and prolly not good for car to be on and off every few minutes.
2012 Interlagos Blue M3 ED 3/22/12
Old 06-04-2012, 04:13 PM
kscarrol's Avatar
kscarrol kscarrol is offline
Mein Auto: 2011 E90 M3 + 1997 Z3 2.8
Don't use it, never have. There is a small button on the center dash with an "A" and an arrow going around it that turn the function on or off. A bit counter intuitive but when the light is on, the auto start/stop is off.
Old 06-04-2012, 04:22 PM
highyo highyo is offline
Mein Auto: X5 50i, M3
and thank you designers for that. i would definitely turn it off everytime i started the car if the default were set to on.
2016 F15 X5 35i, Spacegrau, Canberra Beige/Black, Fineline wood trim, Cold Weather, Driver Assistance Plus (ACC), DHP, Luxury Seating, Premium Package, Harman Kardon
Old 06-04-2012, 06:00 PM
Capobranco's Avatar
Capobranco Capobranco is offline
Eye of the Wolf
Mein Auto: M2, X5
Tried it one once...turned it off and I have never looked back.
..BMWCCA...10th BMW
Old 06-04-2012, 08:23 PM
yinlee yinlee is offline
Mein Auto: '11 M3 Coupe
Never used it and don't see the point of it in am M car.
'11 M3 Coupe
'10 335i xDrive - Will be missed
Old 06-04-2012, 09:01 PM
650 Ryder's Avatar
650 Ryder 650 Ryder is offline
Mein Auto: Dinan///M3 - Countryman S
Yeah what they all said ^^^^^.....leave it off...........Phil
2011.5 Dinan ///M3:
SSII DCT
Comp, Conv, Prem 2 Pkg
Heated Seats
Enhnd Prem Sound
BMW Edition Grills / Gills
BMW M Perf. Steering Wheel
BMW C/F Perf. Spoiler
BMW Pedals
Dinan Exhaust
Dinan Mid Racing Exhaust
Dinan Carbon Fiber Intake
Dinan Racing Middle Exhaust Software
Dinan DCT Tune
Dinan Pulley Kit
Dinan CH-R Wheels
Dinan Carbon Fiber Strut Tower Braces
IND M5 Scheme Mirror Caps
Arkym Front Lip
C/F Reflectors
Lux H8 V3
Brembo 365mm BBK
Swift Spec-R Springs
Old 06-04-2012, 10:23 PM
leejak leejak is offline
Mein Auto: 2012 640 ED, 2011 M3,
I don't use it most of the time, but there are a few places that I have to go where there are really long red lights one block apart for 5 blocks in a row, so I turn it on when I go there......I just cannot stand the thought of the car using fuel when it is no moving and just waiting for a 5 minute light to change, only to go one block and stop again....Of course I try to avoid these intersections whenever possible but sometimes just can't avoid......there are some brilliant traffic engineers out there.....clearly interested in us wasting as much gasoline as possible.....really environmentally smart people....
Old 06-05-2012, 02:46 AM
Mein Auto: 535
mpower
What about.the power button? Sport and sport plus. How.often do u use it or when?
Old 06-05-2012, 04:26 AM
me, never sport +, i think maybe too sensitive. i use power when engine is warmed up completely
Old 06-05-2012, 05:30 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
In my 2012 M3 I use the Start/Stop often in my work commute, I cannot stand wasting gas at stoplights especially the way this V8 gulp gas just idling. I used to have a 2008 M3 and one of my biggests complaints was the idle excessive (to me) gas consumption.
I even went ahead and code it to remember its last state instead of defaulting to off at each engine start.
Old 06-05-2012, 06:17 AM
logicalthought logicalthought is offline
Mein Auto: 2013 Boxster S
Originally Posted by Technic View Post
In my 2012 M3 I use the Start/Stop often in my work commute... I even went ahead and code it to remember its last state instead of defaulting to off at each engine start.
Technic,
Do you happen to know if this function uses the car's starter each time? I know that some systems (specifically, Mazda's and perhaps Peugeot's) restart the car based on some sort of compression in the engine (thus not stressing the starter), but I haven't been able to find any details about how the system in the M3 works. The possible starter wear is my biggest reason for leaving mine disabled.
Old 06-05-2012, 09:28 AM
Mein Auto: 535
I think I saw somewhere that the display can also show u when to shift for better gas consumption? Anyone seen this.
Old 06-05-2012, 12:38 PM
Exactly....I could not agree with you more....just sitting at idle burning gas just bothers me to no end....I have no problem enjoying the power that the V8 produces when driving, but just sitting there while the engines sucks down the fuel is just plain wasteful both of the gas the the car's capabilities....
Old 06-05-2012, 01:00 PM
solstice solstice is offline
Mein Auto: 2015 F80 M3
Originally Posted by logicalthought View Post
Technic,
I tried the system ( don't like it ) and I heard my starter motor running, however I guess it should be possible for the computer to park the engine with some cylinders at perfect ignition position ( compressed with fuel in the chambers ) and then as a first attempt try to just fire the spark plugs to get the engine running again. Not sure if the M3 can or ever does this.
Old 06-05-2012, 03:15 PM
Not sure, but the times that I use this, it seems to take far fewer turns of the engine/starter to restart the car compared to a cold or even a warm start, so something must be different...
Old 06-05-2012, 03:33 PM
Mein Auto: 535
do you guys know how this works or how to activate. Shift indicator
http://www.bmw.com/com/en/insights/t...indicator.html
Old 06-05-2012, 07:47 PM
Okay, I've done some homework on this. Apparently BMW's start-stop system uses a special heavy-duty starter made by Bosch, along with a heavy duty EGM battery (which won't activate start-stop if it's under heavy load in either very cold or very hot weather). I don't trust any BMW parts out of warranty (I think this company looks to parts & repairs as being a massive profit center) so I'd be a bit concerned about how durable that starter really is, but they've been using it in Europe since late 2007 so one could probably hunt around the on-line forums and see if there are any complaints about the durability. Maybe I'll do that later this week, if I have a chance.
Old 06-05-2012, 08:16 PM
Technic's Avatar
Mein Auto: 2017 M3
I used to literally see my average fuel consumption ticking down like a time bomb at stop lights in a matter of seconds in my old M3... 15.7, 15.6, 15.5, 15.4mpg, and then the green light.
No mo'...
Old 06-05-2012, 08:18 PM
Technic's Avatar
Mein Auto: 2017 M3
Yes, that's correct... the Mazda approach is better from the point of view of starter load/long term reliability.
Old 06-07-2012, 10:45 AM
LarkHouston's Avatar
LarkHouston LarkHouston is offline
Doing the best I can
Mein Auto: 2013 Porsche Boxster S
Recent Road & Track article about the different type of start/stop technology/systems. Included some subjective ratings by the editors and IIRC, they gave BMW's either last and next to last as far as being seamless and working well. They basically said the BMW system is the least technologically advanced and not well integrated.
2015 Audi SQ5
Recent Past:
2009 335i Coupe Dinan S3
2006 BMW Z4
Old 06-08-2012, 09:05 PM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Been there, Done that.
Mein Auto: Does it matter?
I understand it on a 328/335i but I just don't get why an V8 M3 needs start/stop. I work for BMW so I drive these cars daily and while the system is cool, it still needs some work.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
Old 06-10-2012, 09:09 AM
PhillyNate's Avatar
PhillyNate PhillyNate is offline
BMWCCA Member #405750
Mein Auto: 2011 E92 M3 ZCP
I've had my car 1 year this month and don't even look at that button. Never used it and have no intention on using it. My particular car is efficient enough for me and is improving daily as the engine is breaking in.
I used to use the power button sparingly, now I press it every damn time I get in the car. I prefer the throttle response with it on.
2011 Alpine White BMW M3 Coupe 6-speed Manual w/ ZCP.
2008 Alpine White 328i Coupe 6-speed Manual/ BMW Performance Exhaust/ M6 Wheels. (Retired)
Future owner of a Jetson's fold-up briefcase car. So I can TRULY park worry free.
"what I'm driving here...is an ending." Jeremy Clarkson
Old 06-10-2012, 09:17 AM
PhillyNate's Avatar
I suspected this. It makes sense. The starter in this car sounds and works like it will easily last the life of the car. I haven't seen 1 single starter failure on any of the forums on an M3. NOT ONE! Maybe I missed one or two but I don't think so. This is one positive we get whether we use the technology or not.
