Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 03-16-2008, 12:06 PM
dna5ty2 dna5ty2 is offline
Mein Auto: 2001 M5
Talking TSW 10-60 M-Power Oil vs. CASTROL Synthetic Oil
Dealer recommended TSW MPower 10-60W Engine Oil....vs. CASTROL Synthetic Oil 10-60W. any suggestions? i'm thinking of switching to synthetic oil... pics soon!!
Old 03-16-2008, 12:50 PM
Bruce's Avatar
Bruce Bruce is offline
///M forum moderator
Mein Auto: 88 E30 M3.2, 08 451
Castrol doesn't make a 10w60 unless it has just come out. Castrol DOES make the BMW labelled 10w60 and is available outside the dealer but only in Europe.
You should be using synthetic anyway. The M5 gets 10w60 if it has a build date of 3/00 or earlier. Build dates after 3/00 can use 10w60 or 5w30.
Old 03-28-2008, 03:48 PM
DouglasABaker DouglasABaker is offline
Mein Auto: 2002 Chiaretto Red M5
In the interest of clarity, build dates after 3/00 can use BMW TWS or BMW 5W30. Using 5W30 from any other manufacturer is a no no. Valvoline is 5W40, Castrol is 0W30, and Mobil1 is 0W40. There are others I'm sure
d-
Old 04-09-2012, 12:01 PM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is online now
Constantly Learning
Mein Auto: 1999 M3, 2002 M5
Ancient thread I can see, but just had this conversation over at M5 Board. Liqui-Moly 10W60 is good alternative to Castrol and MUCH cheaper.
I LIKE OLDER BMWS, PLEASE HELP ME:
Fern Green 99 M3, Conforti Shark Software, Conforti CAI, Dinan Exhaust. Stamped LTWs, 235x40 square, OE Hella heads, ///M Pedal Kit, Clear Corners, OEM Rear Spoiler, CD43 stereo. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 04-11-2012, 11:35 AM
ECSTuning's Avatar
Mein Auto: e30
Just jump on the grave dig train If you switch over to Liqui Moly I suggest the Race Tech GT1. There are a few variations they make, the GT1 is the correct one for the S62.
800.924.5172
OEM BMW Part Number Search
Old 04-11-2012, 11:58 AM
Edgy36-39's Avatar
Constantly Learning
Wow, this stuff gets complicated doesn't it? Just like always with these cars.
Luckily, GT1 is the kind I picked up!
Old 04-18-2012, 07:03 PM
Edgy36-39's Avatar
Constantly Learning
Updating thread with my writeup and pics from the oil change -- simple job: http://cparente.wordpress.com/2012/0...m5-oil-change/
Old 04-18-2012, 08:41 PM
beewang's Avatar
beewang beewang is online now
Bo-ma-win!
Location: Eugene, OREGON, Home to the Rose Bowl Champion
Send a message via Yahoo to beewang
Mein Auto: S62 E39
That is WAY too much work Chris. In the future, consider using a topsider oil extractor and take full advantage of the E39 design of having the oil filter on top.
... just had this conversation over at M5 Board. Liqui-Moly 10W60 is good alternative to Castrol and MUCH cheaper...
Liqui-Moly is my perferred choice due to the fact that the GT-1 is made of G-IV base stock, aka "True synthetic". I can't figured out what Castrol TWS is made of and have since stop using them. Full disclosure.. my employer is the US importer for Liqui-Moly (and just about everything else you can think of for a car) and I get these things for nothing.. But I am a huge fan of Lubro Moly (and Idenmitsu for that matter).
Old 04-19-2012, 06:48 AM
Edgy36-39's Avatar
Constantly Learning
@beewang - I've used the extraction method on my M3, prior to getting access to a lift. I like inspecting the underbody regularly, and also there is a chance that extraction doesn't get quite as much out oil out as does gravity.
But sounds like we agree on larger points -- no need to go to dealer for simple stuff like this, and no need to pay $16/l for Castrol TWS!
Old 06-05-2012, 03:00 AM
GaryM5 GaryM5 is offline
Mein Auto: M5 e-39
Oil
d-
I have an 01 M5 and have been using Mobil 1 5w30 for 4 years, Why is this a no no?
Old 06-06-2012, 07:44 PM
Edgy36-39's Avatar
Constantly Learning
Gary -- many threads on this, very subjective topic. Check out my post, has links to other discussions.
Probably nothing wrong with 5w30. But in South Carolina, there is no reason you need to go that thin, and 10w60 gives the engine better cooling due to the broader viscosity range.
Old 06-13-2012, 09:26 PM
ard ard is offline
Resident Curmudgeon
I'll bite...
Based on what?
Edgy- you'd be surprised to learn the higher viscosity actually runs HOTTER, not cooler....
Old 08-21-2012, 12:06 AM
ard ard is offline
Resident Curmudgeon
That oil is significantly THINNER than the recommended BMW 5w30... And THAT is way thinner than the 10-60
If you look at the actual viscosity specs of the BMW 5w30 it runs like a 5W40....which is why Doug Baker (above, 4 year ago... wave) suggested those oils.
