Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 05-22-2012, 06:29 PM
Steamboat740i Steamboat740i is offline
Mein Auto: 2001 740i
2001 740i trunk latch issues
Installed a new battery and now the trunk will not shut and the electric latch will not engage and the trunk will not latch. I tried the master key to the left to clear the stop per the owners manual, but it does nothing and the latch will not close the trunk. Suggestions?
Old 06-06-2012, 11:01 AM
my blue 740il my blue 740il is offline
Mein Auto: 1997 bmw 740il
Hi I posted a fix for that on seven40il post check his post about the trunk . Still new to the site don't know how to share my reply to his post
Sent from my PC36100 using Bimmer App
Old 06-06-2012, 01:24 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Originally Posted by my blue 740il View Post
Hi I posted a fix for that...Still new to the site don't know how to share my reply to his post
Click on your name (left side of page) in any of your posts...and you'll see a pull down list appear. In that list is a link that says "find all posts by my blue 740il". When you click that link, it will pull up all of your posts...search thru the list of your posts for the reply that you seek and click on it.
Once your old reply comes up...you can either copy the URL (from your browser's URL box)...or you can right-click on the post # (look at the upper right of your reply) and you will get an option to "copy this link's location". Once you've copied a post directly to your reply...or to the whole thread...you can just paste it into your current reply and the forum's software will automatically turn it into a clickable link.
Here's your reply to seven40il: http://www.bimmerfest.com/forums/sho...28&postcount=2
Q {BMW CCA Member #191509}
(SOLD)
Old 06-06-2012, 03:40 PM
With the trunk open with your hand push the latch closed so it is locked . I'm the lock mechanism there is a triangle looking switch turn it the lock should reset and the trunk should close and lock
HTML code is Off
