Old 05-31-2012, 06:40 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
I am getting a sense of Déjà vu here.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 06-01-2012, 02:51 PM
grilodan grilodan is offline
Mein Auto: E70 X5 35i Sport Activity
@DreamCar, feel free to add my name to the helpers ... I'm in Chicago, IL and have been able to code everything on this list except SLI and HUD because I don't have them, but it should be straightforward enough.
- 2013 X5 35i Sport Activity (Born 08/12) - Titanium Silver /Oyster Nevada /Dark Bamboo - ZCV /ZCW /ZPS /Sport Package /Adaptive Drive /Soft-Close Doors/Running Boards /HUD /Shift Paddles /Comfort Seats /6NR /6NF
- 2011 535i (Born 08/10) - Titanium Silver /Black Dakota /Anthracite - ZCV /ZCW /ZPP /ZP2 /6FL /6NF (Sold 08/12)
- 2010 335i (Born 02/10) - Titanium Silver /Black Dakota - ZCW /ZPP /6FL (Sold 09/10)
- 2007 328i (Born 07/07) - Jet Black /Black Dakota - ZSP /ZPP /6FL (Sold 04/10)
Old 06-02-2012, 11:25 AM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
Epic
Old 06-03-2012, 12:42 PM
Ausfahrt Ausfahrt is offline
Groccery Getter
Mein Auto: E46 325iT/F10 550
Dreamcar, add me to the list I can help people install everything or help them get started . I'm at St. Louis, MO.
Old 06-04-2012, 06:08 PM
1STBimmer 1STBimmer is offline
Mein Auto: 550i GT/X5 35d
@dreamcar,
I can code/help with set up in Birmingham, AL...please add to the list.
Old 06-04-2012, 08:19 PM
park828 park828 is offline
Mein Auto: f10 535 m, e60 550 m
i can help in norcal area
Old 06-04-2012, 08:55 PM
jgscott987 jgscott987 is offline
Mein Auto: 2011 528i
One feature I'd love to disable is the comfort access locking by touching the ribbed portion of the door handle.
When I reach for the door handle, especially in a tight parking space, my hand naturally lands on the ribs, causing the door to lock. I never use the feature intentionally- I just reach in my pocket and press the fob to lock. I would like to keep the comfort unlock function intact if possible.
Anyone have any ideas on what module or code area I could disable this in?
Thanks!
Old 06-04-2012, 08:57 PM
Thanks!
Check the CAS Module.
- BMWCCA #446923
- flick
Old 06-05-2012, 04:12 AM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: Future: F80 M3
Guys we have entire forum for us... please create a seperate threads.... and you have more visisbility for your question
Old 06-05-2012, 06:36 AM
alextremo alextremo is offline
Mein Auto: F10 550i
I'd be willing to help others code in MA.
Old 06-07-2012, 08:43 AM
harrisfb harrisfb is offline
Mein Auto: 2012 550i MSport 6MT
I was able to successfully code my car yesterday. Thanks to the help of DreamCar and the other members of the forum!
I coded:
Window/moonroof close on fob and door ridges.
Trunk close on cabin button and fob.
Auto high beams on by default with headlights.
Fog lights and high beams on at the same time.
iDrive warnings off (camera & navigation).
Seat belt warnings at 1 chime instead of 90 seconds of chiming.
Front windows continue to roll up with opening of door.
Side view cameras at all speeds.
Tire pressure monitor show psi and temp.
DVD in motion.
Doors unlock on engine off.
I am no expert as I have only done my own car. But I have the software and the enet cable, so put me down for being able to assist with coding in the Philadelphia/South Jersey area.
Old 06-07-2012, 10:00 AM
dmunz dmunz is offline
Mein Auto: 535i GT
Hit a Roadblock - HELP
I got everything set up, I see the IP address for my car and the VIN shows up in ZGW.
I open E-Sys and when I hit connect get the pop up which has my VIN next to that radio buttion, but nothing shows up in the Target box.
Any thoughts on what I'm doing wrong?
TIA
DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g.
Old 06-07-2012, 10:12 AM
ImSW1 ImSW1 is offline
Mein Auto: F10
TIA
DLM
More than likely the "dist" folders missing from your installation. The folders should be empty, but they need to be there:
http://www.bimmerfest.com/forums/sho...postcount=1453
Sean
Old 06-07-2012, 10:49 AM
Sean
yup i had the same problem but i was missing the dist folders.
Old 06-07-2012, 12:24 PM
Mein Auto: 535i GT
Not me. I had the dist folders, but managed to put the whlole data set in the wrong sub-folder.
FWIW
DLM
Old 06-07-2012, 12:37 PM
Mein Auto: F10
FWIW
DLM
Score! Could be worse, you could have posted about it...oh wait! :oP
Sean
Old 06-07-2012, 03:02 PM
gspannu gspannu is offline
Mein Auto: 5 Series F10 2012 Model
First of all, a big Thank You to @Dreamcar and others for this forum.
I have just come back from my first session.
1. Took backup of all CAFD modules (as advised).
2. Coded the following:
- Auto Start/ Stop - remember last used setting.
- Auto Headlight Activation (ON by default).
- Bootlid close from Driver button (The UK models already close from the Fob as standard with Comfort Pack). Surprisingly, this worked straight away - no need to wait as per cheat sheet.
: It was fairly easy to code with the instructions from your posts.
Much appreciated; you have been really helpful.
Thank you, @DreamCar once again.
Old 06-07-2012, 03:04 PM
I am based in the UK, Southern England.
I am willing to help others install the software and assist in coding.
You may put my name down as a volunteer.
Old 06-07-2012, 03:52 PM
Mein Auto: F10
Awesome! As of today F-Series coding assistance goes international.
Sean
Old 06-07-2012, 08:06 PM
Mein Auto: bmw
How does one backup all the CAFD modules before even coding? I have been asking this question and I do not see any literature on how to do this...
Old 06-07-2012, 08:47 PM
Mein Auto: F10
cn555ic,
We've just finished a "how-to" for where the backups of your CAFD files are stored and how to get a baseline set. It also gives instructions on how to read your FDL files while disconnected from the car.
DreamCar is going to attach it to the first post, but here's a copy for you to reference.
Sean
Old 06-08-2012, 03:41 AM
DreamCar's Avatar
Moderator
Attached the file to the first post.... And i think we need to clean up the first post little bit.
Old 06-08-2012, 05:37 AM
Mein Auto: F10
DreamCar,
I have enough trouble keeping my PM inbox clean and clear. Sounds like a good idea to me. Can't wait to see version 1.1 or 2.0, whichever you chose.
Sean
Old 06-08-2012, 03:33 PM
Mein Auto: bmw
Okay. Thanks Sean. I guess the next part is showing us how to actually code the cafd stored back into the ecu in case we somehow messed up the coding!
Old 06-09-2012, 05:58 AM
Mein Auto: bmw
I get it's spreading bigtime now! BMWcoding Forum now has the E-Sys 3.18.4 download as a sticky! LMAO. I guess there is no more money to be made on it. So sick of the line. It can be had but not free! Lol. Let's see them post the 3.20 or 3.22 without a price! Not happening unless this site starts getting it out public
