Normal oil temp? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 05-27-2012, 12:27 AM
Ballerbrian4u Ballerbrian4u is offline
Mein Auto: 2004 M3 carbon black
Normal oil temp?
Hey guys I just got a 2004 BMW m3 and it has 42,000 miles. When I turn the at on it says 11,994 miles to oil service. My question is what is the normal temp for the oil and coolant? Tonight in 58 F tem I was having so fun and my oil temp was abit before 210. Is that normal? And the coolant sometimes goes past the middle. Also after I accelerate hard and come to a stop and go again normally it shakes a little. Are these normal?
ID:	326721   Click image for larger version
Old 05-27-2012, 11:01 AM
mwhiteknight mwhiteknight is offline
Mein Auto: 05 m3 05 545i
It is normal When you push it hard it could go up to 260 and still fine
Old 05-29-2012, 11:24 AM
OBS3SSION OBS3SSION is offline
Mein Auto: '02 M3 'Vert
My needle is almost always to the left of center. Seems normal.
Eric (the Obsessed)
2002 M3 Convertible
2005 VW Passat 1.8T Wagon
Old 06-07-2012, 01:25 PM
TheStyleguy TheStyleguy is offline
Mein Auto: '02 M3 vert
Oil and coolant temps should be between the two white dots on the gauges. They will fluctuate depending on ambient temperature and how hard you are driving, but as long as the needle is between the two dots, you're good.
