E36 (1991 - 1999)
#26
you sir are brilliant
"if you look close enough... youll see my bumper is being held together with zip ties
#27
yeah..... thats not air in the lines
New transmission time. Drain the fluid. see how new it is.... or if there is flakes in it.
nothing.
#28
i changed the fluid when i pulled it off to do the tob and pivot pin, i used a dirty pan and didnt even look at it. its GREAT to know that the ****ing thing doesnt just "probably have air in the line" cus i bleed and bleed and bleed that ****er... dot 4 is nasty stuff....
#29
pulled the trans out, get the new one on friday ( from the 94 with 100kish miles) may just open the old one up to see what went wrong.
#30
yeah, that sounds like the synchros and blocking rings are prettu much done...
post pics of teh carnage inside if/when you get it apart!! df
so i got it apart. not the right way...
but either way.. i found a round magnet in 4 pieces floating around. The gears were not in as bad of shape as i expected
#32
uhhhh.... magnet?
can you get it back together? lol
nothing.
#33
ok so i got the transmission today, got it all installed, and it shifts great
![]() Downside if i push the clutch in all the way i get the same sound i got when the pivot pin was bad in the last transmission, i switched the pivot pin to the new one so i dont think it is bad. so my guess is.. i did not seat the pivot pin all the way do you guys think it will solve itself by regular use of the clutch? maybe stomp the peddle a few hundred times? it does not hit if i put the stopper in. i dont wanna pull it again..
#34
then put the clutch stop in...
![]() and the gears themselves are probably going to be looking ok. they're hardened. the synchros and blocking rings are brass/bronze (something) and are not as hard. they wear out with (improper) use. df
so what exactly was the issue?
nothing.
#36
Hi, I'm no expert in this , but it would make sense to me to get his clutch sorted out, even if it means having to change out both master and slave cylinders. It would be a lot cheaper than a replacement transmission surely. If the clutch is not disengaging properly it wouldn't make any difference what tranny he put in it, the gears are still going to crash and grind.
#37
Well like previously stated the slave was replaced and the master tested good so being that my guess was the transmission was bad i choose to spend the $200 on a good one and swap it. Which proved to be the solution as the transmission shifts great. The grinding i mentioned recently is unrelated to the transmission. Its the pivot arm hitting on the pressure plate, this is because i failed to seat the pivot in the last millimeter it needed to go in. with the stop behind the clutch peddle the clutch disengages fine and i can shift without a problem.
