F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
Gas Choice
Does the new 335i Sedan (2012) require Premium gas or is Regular fine?
Thanks! |
89 octane req. minimum
2008 BMW 335i Retired 2009 BMW 535i Retired 2012 F30 335i sportline (Black Sapphire/Black Leatherette/Black High gloss trim, Technology, Sport Auto, Premium Sound, BMW Apps.) |
Awesome thanks. Love the pic. Looks like we got the same thing....... i didnt do the NAV though.
If I understand correctly, 89 is the minimum. But Premium is recommended and will net you the best performance and economy. Without Premium, the ECU is going to retard the engine to protect itself, reducing horsepower and fuel mileage.
Eric (the Obsessed) 2002 M3 Convertible 2005 VW Passat 1.8T Wagon |
I think the black looks phenomenal. wouldn't have t any other way
What does it say inside the gas filler door?
89 is required, but I'm putting 91/93 in mine. I calculated that it will only be about $74/year higher to go with the good stuff.
I doubt you'd save money by going with lower octane. Probably eat the difference in crappier mileage.
I always put 93 in my 2004 325i. I also started adding BMW Fuel System Cleaner every 3,000 since my fuel pump was replaced at 107,800, now at 132,400. Since then I get a steady 26.2 mpg with a good mix of highway and city driving.
Current Ride: 2013 328i Sport Line - Mineral Grey Previous Ride: 2004 325i Black |
Required or recommended? Look in the owners manual and see what it says. I'm pretty sure BMW recommends 91 octane for maximum power. 89 will work but if the engine senses knock it will retard the timing to compensate costing a bit of power and mileage. If you can't get 91, use 93 but if you can get 91, 93 is a waste and will not make more power in a stock N55.
Why does this come up in every forum? Why are people buying an entry-lux car and then looking to save $150 a year on gas?
Anyways, I do not drive BMWs to save a few pennies on gas; Shell V Power 93 here. YMMV, of course.
I've known people with 6+ digit incomes to be frugal. Or maybe a BMW is a dreamcar that could barely be afforded and ways must be found to save money. Or maybe you just don't care about performance or economy. But what if the claims of 89 was legit? Then why waste money on 91 or 93? Contrary to popular myth, the gas octane level doesn't indicate how much "power" the gas has. Putting 93 in a car that only needs 89 is not going to make it faster, or clean the engine, or make it run better or increase mileage. It's only wasting money. For those reading that don't know, the octane number indicates how much compression the fuel can undergo without premature detonation (engine knock.) Most turbocharged engines run a high compression, hence the requirement for 91+ octane. While normally aspirated and non-performance engines run a lower compression ratio and can use lower octane fuels.
The owner's manual does not say anything about 91 octane getting more power or better fuel economy, all it said was the min AKI requiement is 89 octane and if it knocks upgrade to 91. I am not saying that using 91 octane will not result in more power or better fuel economy, in fact, I do think that is the case. Thats why I put 93 octane in my car
I have used, 95% of the time, Shell V-Power in my 325i for over 110,000 miles. I am not looking for any fictious power. Just want to be consistent with what I use to fuel my car, and the area Shell stations that I do use list the V-Power at 93. Next time I am at the station though I will check to see what the middle grade percent is. I think it might be 89, as I believe regular is at 87. Also I really haven't seen any stations that sell 91 cheaper than 93 in my area, but now I am curious to check it all out.
Put in high grade, better performance and efficiency. I worked on a study about the cost/benefit of using higher octane fuels vs lower octane.
'12 F30 335i Mineral Grey/Black - GONE, trade assist for '13 335i M Sport BSM/Black - GONE also, both had steering vibration...... '12 S63 AMG Black/Black '10 Range Rover Sport Black/Tan '11 A4 S-Line Quattro Monza Grey/Black(alcantara) |
In most of the western states, you get one 'premium' choice.
87 is regular, 89 is usually mid-grade, (though sometimes you'll see things like 88 in certain sparsely-populated states and.. maybe at altitude?) and then premium depends. CA is mostly 91. WA has a lot of 92, IIRC. I don't remember which one Oregon uses.
2013 335i Sportline | M-adaptive | HK | NAV | PDC | Heated Front seats |6-speed MT. 2011 X5 35d German diesel technology. How did these guys lose two wars? ![]() 2009 C350 Mercedes Gone 7-31-2012, good car but boooooooooring. 2008 X5 4.8i - Turned in 1/24/11 They created the Lemon law because of this SUV. If I didn't know better I would have thought my wife had a thing with the BMW service manager. |
Many of our forum colleagues are bi-polar.
Most of station here in the Northeat is 87, 89 or 93. 89 is only 10 cents cheaper than 93, so that a savings of $1.60 per fill up and I only fill up once every two week, so its not worth it for me.
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production |
![]() June 9,2012 New Order. 2013 335i Sedan, Melbourne Red Metallic Sport Line, Brushed Aluminum, Leather Dakota Black/Red Highlight, 19" Wheels, Premium Package, Dynamic Handling Package, Technology Package, Sport Transmission with Paddles, Htd Front Seats & Harmon Kardon |
If you aren't putting in the best fuel that you can find (91-93), OP should trade his car in on a Honda
I'm tired of these posts. Come on people. These are high compression turbo engines. Last thing I'm going to be penny pinching on is the fuel it takes.
#25
Required fuel Gasoline with lower AKI The minimum AKI Rating is 89. If you use gasoline with this minimum AKI Rating, the engine may produce knocking sounds when starting at high outside temperatures. This has no effect on the engine life. Minimum fuel grade Do not use any gasoline below the minimum specified fuel grade; otherwise, engine damage may occur. Use high-quality brands Field experience has indicated significant differences in fuel quality: volatility, composition, additives, etc., among gasolines offered for sale in the United States and Canada. Fuels containing up to and including 10 % ethanol or other oxygenates with up to 2.8 % oxygen by weight, that is, 15 % MTBE or 3 % methanol plus an equivalent amount of co-solvent, will not void the applicable warranties with respect to defects in materials or workmanship. Minimum fuel grade The use of poor-quality fuels may result in driveability, starting and stalling problems especially under certain environmental conditions such as high ambient temperature and high altitude. Should you encounter driveability problems which you suspect could be related to the fuel you are using, we recommend that you respond by switching to a recognized high-quality brand such as gasoline that is advertised as Top Tier Detergent Gasoline. Failure to comply with these recommendations may result in unscheduled maintenance." No mention of Premium. Curious. Last edited by SunnyandRich; 06-09-2012 at 02:25 PM. |
