#76
But I think we came up with a good (i.e., simple) test for when the bottom of the dipstick guide tube is clogged! - How to test, clean, & redesign the original BMW dipstick guide tube (CCV vent clogs!) The simple suggestion is to elevate the vehicle and temporarily disconnect the rubber lower CCV vent hose, and then insert a test hose onto the steel CCV vent finger of the dipstick guide tube. Blowing on 'that' test hose should instantly indicate whether or not the dipstick guide tube is clogged. BTW, I measured my original CCV vent hose at 0.430 inches inside diameter (ID) ... which is about 11 mm metric, or about 7/16 inch SAE ID.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 07-04-2012 at 02:36 AM. |
#77
When i remove the dipstick to check the oil level, it's very hard to pull out. Clean it, re-insert to accurately measure the oil level, comes out easy. this is clockwork. So, the vacuum is pretty strong?
Another weird thing: Before changing the CCV (& new style dipstick) to the winterized version I always knew exactly my oil level. With the new dipstick, it's very iffy. Example: change the oil (as always), re-fill 7 qts, check oil, the oil level should be at max. Wrong. It barely shows at the bottom, BELOW the first notch of the min level. Drive it for a day, the oil level is at max - upper notch level. Drive it one more day, the level is at the middle. Check it every other day or so, every time the level is different (pending on the car's mood?) between the lower notch and the max notch. My garage floor level never changes. What gives? This started to happen right after the CCV was changed to the "new" winterized version. That CCV system and whoever designed it should be shot Together with the one who designed the SAP. I hope Gary comes up with an update for the CCV very soon
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
#79
Doru,
You might try opening the oil filler cap before checking the oil level. Just in case residual vacuum plays any part in the inconsistent oil level. Steve
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
#80
I'll say! I measured just under 8 inches of water over in this thread yesterday (engine idling for about five minutes, everything connected except the dipstick itself).
- How to test, clean, & redesign the original BMW dipstick guide tube (CCV vent clogs!) The whole point is to come up with a test of the CCV system and the oil dipstick guide tube portion too. So I was following RDLs advice ... but ... maybe I did something wrong measuring my oil dipstick guide tube vacuum ... because 8 inches is a whopping 19 milliBar (which is a tad too much vacuum given the BMW spec of 10-15 mBar). Maybe I made my loop too loose (does the loop size matter?) or maybe, since it was a cold idle of about five minutes or so, maybe the 'cold idle' gave me "too much vacuum". I don't know. I don't even know HOW to reduce vacuum, if it indeed is too high. ![]() Let's bear in mind what we're looking for is a TEST for the CCV system and dipstick - so - it would be nice if someone else can run the almost-free water manometer test that RDL suggested earlier. Here's what I had posted yesterday - but no response yet: Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 06-11-2012 at 04:54 PM. |
#81
I have the new, cold weather guidetube too & have found oil level measurements to be consistent. Perhaps the retaining brace and bolt for the tube on your engine is a little loose. If the guidetube can move up & down even slightly, the dipstick reading will be thrown off. The span from lower to upper mark on the dipstick is only 16mm or 5/8" so it wouldn't take much movement in the guidetube to make a difference between a reading of full and down half a quart/litre. I can't think of another reason for the inconsistent results you are seeing. BTW, my dipstick is sticky too. It was on the old concentric tube design & still is with the new cold weather version. But it isn't vacuum. A properly functioning CCV will hold crankcase vacuum at 4 - 6" w.c. which converts to ~0.25 psi. Guide tube diameter is ~1/2" for an area of 0.2 sq. in. So the force exerted by the vacuum is ~0.05 lb or ~3/4 ounce. Besides, once the engine stops crankcase vacuum bleeds away in seconds; long before I'm under the hood yanking on the dipstick. The stickiness must be caused by the O-rings adhering to the guidetube. I do agree with you the BMW's CCV compares badly with the PCV I'm used to with its $15 cost & 5 minutes to change. It calls to mind advice a mentor gave me years ago: "there comes a time in every project when you have to shoot the engineers and get on with it." I think BMW missed that checkpoint on this engine.
Regards RDL |
#82
Agreed.
But, at least we can come up with some simple (almost free) tests to determine if the tear-down is necessary or not. So far, does this summarize the three simple CCV tests? (If so, may I ask others if they get similar readings because my results were iffy ... or ... my results might actually indicate a leaky CCV diaphragm.) DIPSTICK GUIDE TUBE VACUUM: 1. Using a 5/8" ID rubber tube about three feet long, my M54 vacuum at idle at the dipstick guide tube was just under 8 inches of water. It would be nice to see what others get using a hose and water and some string and a ruler. Note: I will run the test again, taking more care to keep the water-filled parallel lines vertical. UPPER VENT PIPE RESISTANCE: 2. Using a 1/2 inch OD rubber hose about seven feet long (with some tape wrapped around the end for tight fit), I felt absolutely NO RESISTANCE to blowing into the CCV upper vent tube whether the engine was running or not - and - whether the engine was at idle, low speed, or high speed (it's hard to tell the speed because I had to prop the accelerator with a heavy object). This might be indicative of a torn CCV diaphragm according to Steve's post just now in the related thread: Quote:
3. Using a 7/16 inch ID hose (11mm ID) about three feet long, from under the car, one can temporarily disconnect the rubber ccv vent hose and connect a three foot rubber hose to the bottom finger of the steel dipstick guide tube and blow to see if the concentric ring is clogged. In my case, I unclogged that already - but it would be nice to see what others get when they test it.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 06-11-2012 at 04:43 PM. |
#83
There is no need to keep the lines vertical, parallel, any particular shape or anything else. The only thing that matters is the vertical distance between the two water levels. Keeping the two legs of the "U" vertical & together does make it easier to measure though. I'm afraid that the reading of 8" you got indicates that the CCV is suspect, assuming they were vertical inches. I appreciate that the "blow for bubbles test" has been recommended for some time. It has never made sense to me. (Doesn't work for me either) Making bubbles would require pressurizing the CCV chambers in order to force air down to the dipstick guidetube and bubble through the oil in the sump. But, while the engine is operating the CCV is keeping the port to the inlet manifold open "just the right amount" so that the hose (which the CCV thinks should be connected to the crankcase) has 4 - 6" w.c. vacuum. Any pressure rise generated by blowing into the pipe would cause the CCV diaphram to open the port wider to overcome the effect and maintain vacuum. When the engine is stopped, the CCV default position is for the port to inlet manifold to be fully open; again impossible to generate pressure to bubble through the oil. Any pressure would go to the inlet manifold, past the throttle toward the engine air filter, or though a cylinder that has both valve open in overlap and down the exhaust. Can anyone report that they have succeeded in making bubbles with a properly functioning CCV? If so, please disregard my theory above.
Regards RDL |
#84
Interesting... Because I specifically remember finding sandy oil inside the intake manifold after removing the Disa Valve... So, if there is oil in the Intake manifold, the CCV is most definitely DEAD...? Thanks! Jason
#85
The separator will work only so good. Some misted fumes are still pulled through the intake manifold. So wether the CCV is new or old, it will always have some oil in there. If the CCV is blown, the amount of oil may be higher than normal. Because if that's the case, a CCV will last probably only 2-3 months. My DISA was oily after the new CCV went in - checked it about 4-5 months later.
#86
In that specific post I was trying to warn the person that a failed CCV can suck oil into the intake manifold. So if you have no leaks, but the oil level is dropping, it's worth checking that there isn't lots of oil being sucked into the manifold by a failed CCV. There was a post in another thread about an engine that was hydrolocked by oil that was sucked into the cylinder through a failed CCV. I guess I did a poor job explaining that issue. Sorry if it caused confusion.
#87
Thank you for the response, and I very much respect your posts...! Very informative...! Thank you! Jason
I found a great read here:
http://www.aa1car.com/library/pcv.htm ![]() And, a possible CCV alternative (Crawford AOS "Air/ Oil Separator"): http://www.iwsti.com/forums/2-5-lite...-answered.html http://store.crawfordperformance.com.../categories/78 Review: http://forums.nasioc.com/forums/show....php?t=2228499 And a related thread by BimmerFiver about the Leak Detection Pump at the Charcoal Canister (Fuel Tank): http://forums.bimmerforums.com/forum...1#post24609271 Quote:
He highly suggested running a WHOLE CAN of B12 carb/ throttle body cleaner through the intake/ throttle body while running my car to FIX ALL of the issues with my car (leaking oil pan gasket, fuel pump acting-up, CCV dying again...)...
#89
For the record, here is an E46 with the lower CCV vent hose sliced almost exactly as mine was (with concomitant lean-condition misfire error codes):
> CCV valve and vaccum leak diagnotics Quote:
- P1188, P1189, etc Codes Fixed Easily (1 Oil Separator Hose) (*Pics*)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 07-15-2012 at 07:07 AM. |
#90
After seeing this old thread revisited and updated, here's a suggestion directed mainly at the older forum members who do most of this troubleshooting on our cars (and thank you for your efforts! |
#91
I've read some other threads about the oil seperator hose going bad. It looks like on the V8 you have to remove lower cover/jesus bolt to do so, but perhaps people could have some success just replacing a hose if you remove one upper timing cover (much easier). I'm considering this right now, but I've only read of one person replacing a hose in their oil seperator. The pipe that runs to my oil seperator had a lot of gunk on the end near the oil seperator and a bunch of gunk was in the valley pan area. Makes me worry about the oil separator.
#92
This useful distinction was posted to this thread today:
> E39 (1997 - 2003) > How to test, clean, & redesign the original BMW dipstick guide tube (CCV vent clogs!) Quote:
#93
Hello. In my M52 is little vacuum under oil cap, and in dipstick. Maybe it is ok, but what I'm worry about is very low vacuum on hose connecting fuel presure regulator with CVV. Engine is working little rough. Hoses seems to be fine (only hose I didn't checked is CVV hose connected with oil dipstick, but I will do it soon), without vacuum leak, valve cover gasket also good, new, checked with auto-start fluid, CVV is new. But why is so slightly vacuum on hose connected to fuel presure reguletor? Almost no vacuum at all... Is this correct? FPR can operate with so slightly vacuum?
#94
The fuel pressure regulator needs a good clean source of atmospheric pressure to function correctly. See this thread, http://www.bimmerfest.com/forums/sho...=1#post7145659 post #41 for one possible explanation of the air hose from CCV to regulator.
Regards RDL |
#95
Thank you very much!
#96
For the record, in that thread, the related information below was posted today about the bubble test:
> E39 (1997 - 2003) > WHERE does the CCV vacuum source port go for the E39 CCV valves that are not plugged?
#97
From reading this E46 thread today, I just belatedly realized what the BMW design flaw is in the lower CCV vent hose!
> E46 (1999 - 2006) > What is this sensor / plug /wire near the intake? Is it correct that the 90° elbow on the original CCV lower vent hose puts so much stress on the hose that they often crack in half? And, is the replacement 45° hose designed to put less stress at that point?
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-11-2012 at 08:56 AM. |
#98
This thread today covers how to temporarily disable the CCV to limp home in dire cases:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-13-2013 at 08:47 AM. |
#99
Found this posted today, which is something to look out for BEFORE installing a new CCV I guess...
> E39 (1997 - 2003) > Testing ccv
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-28-2013 at 01:31 AM. |
#100
I think we have two good threads for testing the CCV:
> E39 (1997 - 2003) > Cute little trick to diagnose blocked CCV system... > E39 (1997 - 2003) > How to test the BMW E39 pressure-controlled crankcase ventilation system (CCV)? So, I'm not sure which should be the canonical thread to cross-reference this information posted today (in order for others to find it more easily in the future, long after we're gone). Quote:
