Old 06-12-2012, 02:24 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
2003 745Li Driver's side HID headlight dim/yellow than other side
I replaced the factory HID bulbs with aftermarket D2S bulbs, however, driver's side seem to be missing the blue tint when compared to the passenger side.. I moved the ballast around but driver's side still the same. I think this was happening before I changed out the bulbs. Anyway I ordered another set of bulbs to try. Any thoughts? Has anyone had this issue?
Old 06-12-2012, 02:45 PM
muggzytx muggzytx is offline
Mein Auto: 745li
Maybe the ignitor? Also, the name isnt coming to me right now, but there are two boxes under the headlights ( one on each side) that may be going out? Those are all the components to the HID..
Old 06-12-2012, 02:48 PM
sak_916's Avatar
sak_916 sak_916 is offline
Mein Auto: 2005 BMW 745I
you mean ballast?
it might be from the ballast but I have noticed on many 7s that one side is a bit green and the other a bit bluish. you will get over it in a few months
Old 06-12-2012, 02:58 PM
Mein Auto: 745li
http://www.realoem.com/bmw/showparts...24&hg=63&fg=05 Part 1. But im not sure if it gives off symptoms when its going out, or it plain either just works or doesnt work... Just giving some ideas, as this has never happen to me.
Old 06-12-2012, 03:49 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
Most likely got a different K bulb (not a matching pair).
HID Guide
LED Guide
Old 06-12-2012, 06:30 PM
2003 745Li Driver's side HID headlight dim/yellow than other side Edit Post
Thanks for such quick replies
Old 06-12-2012, 06:35 PM
To add to my original post, I swapped the square box (I think it's the ballast) that is twisted onto the back of the bulb, to the other side to see if the color difference moved to the passenger side, but it didn't. Anyway, I am waiting on the new set of D2S 8000K bulbs.
muggzytx - Thanks for the schematics... This can get expensive...I'll keep everyone posted on my findings. Thanks everyone for your input.
Old 06-13-2012, 11:32 AM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
our MTEC D1S and D2S 6k HID bulbs are all perfectly matching and error free
Old 06-16-2012, 06:07 PM
Ok so I got a new set of 8000K D2S bulbs.. same thing
I think I have to look at the other parts (schematics provided by muggzytx) that make of the HID system.. I'm getting a used control unit and the electronics box for $150 from someone that's parting out the a 7 series. I am thinking about buying both, but I could be in the same predicament.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 06-16-2012, 08:09 PM
quarterto8's Avatar
quarterto8 quarterto8 is offline
Send a message via MSN to quarterto8 Send a message via Yahoo to quarterto8
Mein Auto: BMW 745
What is the difference in D1S and D2S bulbs and which size do we use for 2004? Ive read both.
Old 06-16-2012, 09:53 PM
Shows the 2004 uses D2S.. Not sure what the differences are.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
