5 Series DIY
Old 02-05-2004, 08:00 AM
DZeckhausen's Avatar
DZeckhausen DZeckhausen is offline
Send a message via AIM to DZeckhausen
Mein Auto: 2012 BMW F30 328i 8-Speed
How to bleed your brakes: Step-by-Step Instructions
I've been meaning to do this for a long time, since it's something I often have to explain to people. Here's my write-up on bleeding brakes. I intend to improve it over time, probably adding photos and more detail as I get feedback from people using them.
How to Bleed Brakes
Dave Zeckhausen
Owner, Zeckhausen Racing
2015 BMW X1 xDrive28i M Sport
2012 BMW F30 328i Luxury Line 8-Speed
StopTech 4-wheel big brake upgrade
2001 BMW E39 540i 6-Speed (Traded-in for F30)
CDV deleted
Old 02-05-2004, 05:37 PM
Lscman Lscman is offline
Mein Auto: 540i 6spd
I sincerely appreciate your great writeups and advice on tech topics.
I guess I'm not the only one that had a negative experience with 1-way valve bleeders.
Old 02-05-2004, 06:20 PM
Please tell me more! I'm assuming you mean the SpeedBleeders or some similar product? What sort of problem did you have? I often wonder if I've simply had incredibly bad luck with these or if they really do only work 1/3 of the time. Even if they worked 100 percent of the time, they still aren't very good at getting stubborn air bubbles out.
Dave Zeckhausen
CDV deleted
Old 03-10-2004, 06:53 PM
I have had "some" luck pushing a pint or so of fluid thru with 1 way bleeders, that is, purging moisture or cloudy brown fluid from a wet system.
It doesn't seem to get that last bit of air out, like you can when a person is standing at the wheel cranking the bleeder each pedal stroke & watching for an end to streams of bubbles coming out.
