Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 06-16-2012, 04:27 AM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Originally Posted by bennybenny View Post
goetz for rings, and glyco bearings. got all my stuff sourced from the US, pelican parts. even with shipping turned out a hell of a lot cheaper that way (instead of sourcing from Oz)
and as for ECU, it's a 0 261 200 405.
well still waiting for the MAF from the UK at any rate. i'm going to see if that changes anything and maybe then yank the head off to see what's up... really frustrating me.
Good stuff there.
I wouldn't be looking at motors 10 years newer that really share no common part with your engine as a comparison for troubleshooting.
Your issue sounds like a sticky vanos, but you have none, my $ is on your lifters or trays being toast.
Old 06-16-2012, 05:03 AM
bennybenny bennybenny is offline
bennybenny
Mein Auto: e30 m50
some pics to liven the thread
the donor 525i
325e after the Sydney to Gold Coast trip
about to be torn down
sandblasted valve cover
primered
cleaned up ready for head to go on
ready for bearings.
bores honed ready
doing the monowiper mod
motor all ready for install
goin in #1
goin in #2
IN!
off to the exhaust shop
just a proof of timing
left biased
exhaust #1
exhaust #2
exhaust #3
the bay #1
the bay #2
Old 06-16-2012, 05:13 AM
bennybenny
Mein Auto: e30 m50
Originally Posted by SWISS View Post
Good stuff there.
hehe, i did feel iffy doing a comparison of the two.
but hey, it was the closest i could get to that same distinct sound
cheers for the tips. i'll owe you one if you're right! thanks for the tips.
Old 06-16-2012, 06:01 AM
SWISS's Avatar
On Top
Ok after looking through all your pics I am positive you:
did not remove the crank and take it and rods in for proper inpsection and sizing for bearings at a qualified machine shop.
The head surface looks filthy from what I can see.
And you cannot time cams like that, they are not parallel to each other, they are perpendicular to the head top surface or VC seal.
Have you bearings properly resized, and time the engine correctly using a tension tool to load the chain, and cam blocks.
Old 06-16-2012, 05:24 PM
bennybenny
Mein Auto: e30 m50
sigh... ok swiss you got me. i used plastigauge.
and removed the crank to replace the bearings
http://s18.postimage.org/445nnu795/IMAG0109.jpg
, as for timing...
well i followed a timing guide on one of these forums, can't remember which one
and i did pre-tension the chain according to that guide.
that pic probably wasn't the best to use to document the cleanliness of the block.
it is only a mobile phone.
i appreciate the help in any case. if you have another timing guide which i can follow i'll gladly use it as i found it hard to find one and settled on the first one i did find.
please don't treat me like a novice because i am not one when it come to engines. i clearly just do not have your know-how on these engines specifically.
your condescending attitude is not appreciated.
Old 06-16-2012, 07:09 PM
SWISS's Avatar
On Top
, as for timing...
You can call my tone condescending and I can call your work half a55. We all have our opinions, but you asked for advice because you tore apart a motor that was not knocking, rebuilt it and now it's ticking away.
I have may sound cocky because I have done this several times and never had any clackity clack clack in my motors. I follow this procedure and use these,
I highly recommend them if you have the means.
Here's a pic of the cam locks installed on an M44:
Old 06-16-2012, 07:45 PM
jeffgifford jeffgifford is offline
Mein Auto: 1991 318is
chip problem
I just received the Conforti performance chip 175-300 from Turner Motorsports for my 1991 318is but when I took the ECU apart the label on the current chip says 1 267 356 378 and the instruction say it should say 0-261-200-175 or don’t install it. Whatz up wit dat?
Jeff Gifford 512-775-1797
Old 06-16-2012, 08:25 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Jeff, quit highjacking existing threads and start your own to ask that question. You'll get a better response and it will be more likely to be answered.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 06-16-2012, 08:29 PM
bennybenny
Mein Auto: e30 m50
ok well as far as i can see the tool mentioned holds the cams in position so that you can tension the chain w/o worrying about them moving and losing the timing.
does it hold it at any particular angle? as far as i can see it holds them perpendicular to the head as you said, but that would also mean they sit parallel to one another so a straight edge would be "fine" to check them after the chain has been fitted no?
having the tools on hand would be incredibly handy but i don't.
as far as i can tell this tapping sound of mine in not consistent with poor timing.
i'm pretty sure i've got that part right. this procedure is quite similar to the one i used so thanks for letting me see that.
i'll have another look when i get the chance and consider the lifters as a possible issue as well. cheers for the input, i really appreciate it.
Old 06-16-2012, 08:32 PM
SWISS's Avatar
On Top
Sure thing, you can find the tools on ebay. And I think the fixtures hold the cams at a slight angle to each other the tops are not flat on the cam locks look at the pic. IF you buy one tool get the cam blocks.
Old 06-25-2012, 05:02 AM
bennybenny
Mein Auto: e30 m50
well i suppose i'd better wrap up this thread.
had another look today and decided i'd go through all the simple things again.
check wiring, plugs, start her up, listen and try to isolate the sound, etc.
i then decided to clean the ICV valve for the hell of it. hey, the car wasn't going anywhere.
cleaned her up, bit of brake cleaner in the end, and a rag.
SUCCESS! the waviness of the engine ceased, changed to a hum, knocking has ceased.
the engine now has an entirely new sound. all fixed.
thanks for all the input guys, i've learned quite a bit!
Old 07-14-2012, 09:07 PM
BluE30 BluE30 is offline
Mein Auto: E30
Great info here guys, I'll be rebuilding an M50 here soon for a turbo build and this thread is exactly what i needed to see.
