Old 06-02-2012, 11:32 AM
1996bmw740il 1996bmw740il is offline
Mein Auto: 1996 740il
Longer tire bolts
I need to put 7.5mm wheel spacers on my 740il what size lug bolts should i get? Anyone know what the stock length is?
Matt
Sent from my DROID RAZR using Bimmer App
Old 06-03-2012, 08:09 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Bolt Pattern (in):
Bolt Pattern (mm):
Offset Range (mm):
Front Center Bore (mm):
Rear Center Bore (mm):
Stud_Size:
5x4.72
5x120
10 to 25
72.6
72.6
14x1.25
JOY = BMW
Old 06-08-2012, 05:23 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
The stock length of the OEM lug studs are 26.4mm. You will need the longer 33.3mm lugs to accommodate the 7.5mm spacers. Just make sure you buy hub centric wheel spacers.
Big Boyz with Bad Toyz.
Old 06-17-2012, 09:08 AM
Why hub centric why are they better
Matt
Old 06-17-2012, 10:32 PM
joyism5's Avatar
Bmw uses hub centric wheels not lug centric. If you use universal spacers that are not hub centric you might end up with bad steering wheel shake.
JOY = BMW
