California
eas | Inspection I/II, VANOS Maintenance, Subframe Reinforcements, and More!
As your preferred SoCal BMW shop, EAS is proud to offer service for your M3! We can offer various services for your car, from maintenance, to parts installation, and even dyno sessions. Our large facility is complete with a full service lift, specialty tools and equipment, and two highly skilled technicians with over 20 years of combined BMW experience. We know how much your BMW means to you, which is why we treat every car with the utmost care and respect. Our customers always let us know how valuable it is for them to have a shop that they can trust with their BMW.
![]() For your e46 M3, we are offering Oil Change Services, Inspection I, Inspection II (including Valve Adjustments), Subframe Reinforcements, and VANOS maintenance: Inspection I: $825 - Oil Change Service - Differential Fluid Flush - Transmission Fluid Flush - Clean MAF Sensor - Cabin Air Filter Replacement - Fuel System Cleaning (Redline Fuel System Clearer) - Valve Adjustment ( Can be done separately as well) - Full Inspection of the Vehicle (Check for leaks, fluids, pressures, bushings, brakes, etc.) - Reset Service Indicator - Road test with check of brakes, clutch, steering, suspension). Inspection II: $1225 - Oil Change Service - Differential Fluid Change - Transmission Fluid Change - Clean MAF Sensor - New Cabin Air Filter - Fuel System Cleaning (Redline Fuel System Clearer) - Coolant Flush - Power Steering Fluid Flush - Fuel Filter replacement - Spark Plugs replacement - Valve Adjustment ( Can be done separately as well) - Full Inspection of the Vehicle (Check for leaks, fluids, pressures, bushings, parts, etc.) - Reset Service Indicator - Road test with check of brakes, clutch, steering, suspension). *All OEM BMW Fluids and Parts used unless otherwise noted or requested Other Services offered for your e46 M3: - Belt Replacement: $180 - Constant Pressure Valve Replacement: $125 - Chain Tensioner Seal: $110 - Oil Change Service: $150 - Powerflex or Rogue Engineering Rear Trailing Arm Bushings: $ 225(with Powerflex) - Powerflex or Rogue Engineering Front Control Arm Bushings: $275(with Powerflex) - Subframe Reinforcement: $1250 (If subframe is already damaged, repair may be required at an additional cost.) - VANOS Maintenance (Vanos Seal, Vanos Filter and O Rings): $150 ![]() ![]() Give us a call today to set up your appointment to get service done!
Customer Service | european auto source (eas) email: info@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr Last edited by eas; 10-19-2011 at 01:11 PM. |
Time slots are available. Call us today to set up your service appointment!
Customer Service | european auto source (eas) email: info@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr |
Call us today to set up an appointment!!
A few slots open these upcoming weeks, call to schedule your appointment!!
Bring your car in today for all for an inspection!!
Call us to set up an appointment
Inspection I: $825 Inspection II: $1225 European Auto SourceYour prefered SOCAL BMW service shop!
Call in to make an appointment!!!
A few slot open up next week. Call today to schedule an appointment!!
Call today and schedule your service today!! A few slots open!!
can you do for E46 non M ??
Inspection I
Inspection II Call us today to set up an appointment!!! ![]()
Slots open during the next few weeks!! Call toady to set up an inspection!!
Call us for an appointment! Here is one of the recent Subframe Reinforcements we worked on recently. ![]()
I called and got my work scheduled. I will report after completion. Thank You Robert and Steve.
ZSCCA Area Rep SoCal |
Call us today to schedule your appointment! ![]()
Time Slots open next week!! Give us a call to set up an appointment!!
Call to day to schedule your inspection or subframe reinforcement!!
Call us for an appointment to get your Inspection II and other Services for your BMW
Call in to schedule your appointment for your Inspection II
Inquire about other services available for your BMW
Make your appointment to get your service done at eas!
