Old 06-20-2012, 12:41 PM
lloydcole lloydcole is offline
Mein Auto: 330d z3
electric window fault
If you have to continually press the window switch, let go, and press several times again to get the windows down, and then back up again, what is the part I need to put right. Z3 2.2 2001
Old 06-20-2012, 07:59 PM
Blacklane Blacklane is online now
Mein Auto: 1998 Z3 Roadster
Try looking through this thread:
http://forums.bimmerforums.com/forum...d.php?t=709563
If that doesn't quite explain your problem, go to the top of the page on the right and find the button called "search this forum." Click that and type "slow window" or something similar. You will find lots of ideas.
Old 06-21-2012, 03:21 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Hey, Most of the time when you start having these problems with the windows in BMW's it is the window regulator. I own an 04 Z4 and have had to replace both of mine. They started going down slow, then a loud squelling noise. I went to the Dealership and bought the regulator and installed it myself. Got to try to save a buck anyway you can these day's. Good luck with your car.
