E36 (1991 - 1999)
Old 06-21-2012, 01:24 PM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Sorry about the pooin'
Not trying to make you pull your hair out. lol
It can.. depends on what kind of fuel cleanup used.. the brand.. etc..
the tolulene, xylene based ones.. seem not to..
The ones that have more volatile, or HD cleaning agents can screw things up.
Your burning the sludge, and a chemical that can mess with readings.
Denatured Alcohol, xylene, toluene, and the other one escapes me.. are "cleaner"
You can double check your MAF again.. If you did a good job cleaning it the first time, or second, or third..
Give it a once over one more time.. make sure its clean.
Burn that tank of gas outta there.. you can add .75 GAL of E85(flexfuel) to a half tank (or better) of
the highest octane top tier gas you can find.. (Shell, or better)
this is for laughs..
Old 06-21-2012, 02:15 PM
Dakota_leWarne Dakota_leWarne is offline
Mein Auto: 1994 318is
ok, one more update, car wont rev past 4.5k
"if you look close enough... youll see my bumper is being held together with zip ties
Old 06-21-2012, 02:16 PM
Eight Thirty Eight Thirty is offline
nothing.
Mein Auto: ItAintUrShtYUCare?
why are you trying to rev that high?
:P
nothing.
Old 06-21-2012, 03:08 PM
was not while driving, i had the car running in the drive way to run through some of the cleaner, after running it at 1.8k for 10 minutes i revved it a few times and noticed it wouldent go any higher.
Old 06-21-2012, 03:18 PM
Mein Auto: BMW
Sounds like your DME is trying to re-learn*
Go on a drive.. run that tank of gas with the fuel cleaner out..
check the O2 sensor.. and MAF for the umpteenth time.. (HOPEFULLY the LAST TIME)
fill with half tank of top tier HIGH octane.
The highest you can find
Disconnect battery.. like your "resetting" codes.. wait.. Reconnect.
Fire up the car and take it for a drive right out the gate..
Note what it is doing..
After a couple drives.. it'll start changing.. You should notice.
Old 06-22-2012, 10:14 AM
Ok good to know, i work alot the next few days but ill be sure to run the car a bit to get the contaminated gas out.
in other news a made a new custom gas peddle that turned out nice
Old 06-22-2012, 10:15 AM
Mein Auto: BMW
pix or didn't happen
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 06-22-2012, 05:28 PM
you cant really see the bends in the picture, ill get a better one once its mounted
Old 06-22-2012, 07:37 PM
the ghetto install version at the moment.. but worked great
Old 06-22-2012, 07:53 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
What was wrong with the original pedal?
1998 BMW 328is
1966 Pontiac GTO
Old 06-23-2012, 05:35 AM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
Originally Posted by Dakota_leWarne View Post
Cant do a stomp test because i have an m44 OBD11 engine and cant use my OBD11 reader because the car is not set of with a plug being that its a 94
:sigh: ok, first, the designation of obd1/2 is determined by the dme. the motor does not care if it was in an obd1 or 2 vehicle, it has no way of knowing what it is. you *should* still be able to do a stomp test regardless.
if, however, the dme was swapped out from an obd2 vehicle and placed in the obd1 vehicle, *then* you may have issues with stomp test/no stomp test. i would imagine that there would also be all sorts of check engine light issues as well, due to the dme not being able to communicate with other synched modules. (obd2 is flashed, not chipped)
i'd check to see what would cause you to not be able to run a stomp test and see what shows up.
this sounds like a maf default to me. cleaning a bad maf will not do anything, and would screw up the readings as well.
df
Old 06-23-2012, 11:32 AM
Built the new peddle because the old one was broken.
I understand that the engine and car are not obd1/obd2... what im saying it the car was originally obd1 and the wiring is obd1 so it does not have a port for the code reader that and post 95 would have. The engine is run off and Obd2 dme making the stomp test not work.
Old 06-23-2012, 06:27 PM
i do not see how you could possibly run the dme (pcm in obd2 nomenclature) from an obd2 in an obd1 chassis without setting 'u' codes. these would be the codes set from bus-to-bus module communication, and since the obd2 dme units are flashed and not prom chip, it's not like once could swap 'intrnals' to make it work.
i am not saying that this feat could not be worked around, but it would either be something that looks like a hack job, or there would be all sorts of evidence of wiring being spliced for this setup to work. this amount of work would be something that most professional techs would not consider, since it would be way easier to just get the correct dme for the chassis.
so no, an obd2 reader wouldn't work. an oe scan tool, or similar should work if you are still unable to perform the stomp test. however, if you are unable to perform the stomp test, i would search for possible reasons that would cause this.
one last thing that i would make sure about is that you are in the proper ignition position, and start the stomp test after the lights turn off.
it seems that many guys have trouble the first few times trying to perform the stomp test, so please don't stop trying.
df
Old 06-24-2012, 11:23 AM
ok so ive concluded that i am way over my head with everything you are saying.. i was once told that if i had the m44 i HAD to have the 0bd2 dme. if that is not the case then im sure the previose owner did the bare minimum like evey other thing he has done.
i did the stopm test again... it worked and i got 1121 and 1214 any idea what these are?
Old 06-24-2012, 03:47 PM
installed
Old 06-24-2012, 05:59 PM
not familiar with these codes, and no search i have done reflects any actual definition. i would double check the flashes just to be sure.
here's a list of codes, per the pelican website.
http://www.pelicanparts.com/BMW/tech...nostics%20.htm
df
Old 06-25-2012, 08:01 AM
Mein Auto: BMW
If its a typo.. or if you got the codes wrong..
The closest thing that came across
1211 DME Control Unit
1215 Air Mass Sensor
Si or No?
Old 06-25-2012, 12:10 PM
those both make sense for the problems i am having so ill go ahead and order a maf
Old 06-25-2012, 12:17 PM
Mein Auto: BMW
drag..
Old 06-25-2012, 12:25 PM
Old 06-25-2012, 12:37 PM
nothing.
that sucks
nothing.
Old 06-25-2012, 12:39 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
I'd buy a tested, confirmed working MAF from one of our parts car guys (provided they have one) before buying one elsewhere.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 06-25-2012, 01:10 PM
i ordered one on eBay today that was "tested good" with a 30 day money back guarantee.
Old 06-27-2012, 02:45 PM
Got the new maf, no engine codes at all today and passed deq with 190 hc and 0.7 carbon. she shall be on the road in no time
Old 06-27-2012, 03:32 PM
ZeGerman's Avatar
Warm Leatherette
Wooo!!!! Nice!
1998 BMW 328is
1966 Pontiac GTO
