integrated garage door opener - Page 2 - Bimmerfest - BMW Forums
Old 06-22-2012, 02:10 PM
georgejm georgejm is offline
Mein Auto: BMW X5 35d
I picked up my X5 Tuesday and today I linked it to my garage door. These were my steps:
Press and hold the two outside buttons until there was a rapid flash.
Hold garage door remote at base of rearview mirror and press button on remote and desired button on mirror. Hold both until rapid flash
Stood on my running board to press the "learn" button on the back of garage door unit (it will flash).
Sat back in the driver's seat-pushed the programed button on the mirror and wala, it opened.
Thank you very much.
2012 X5 35d AW/Black Dark Burl
ZAP ZAV ZCW ZPP ZPS ZRC ZTP HUD AD BMW Apps
Spare Tire-Comfort Access-Running Boards-Roof Rails-335 Wheels-Auto High Beams-Smart Phone Int.
Mods : Clear Bra-Radar Hard-wired
So far so good-made on Wednesday
Old 06-22-2012, 02:28 PM
calif11 calif11 is offline
Mein Auto: x5
Unfortunately, I can't get rapid flashing in the first step, regardless of where I hold the remote and whether I press the remote continuously or in intervals. Same as OP's issue.
Old 06-22-2012, 02:42 PM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Try it with the engine running.
Old 06-22-2012, 02:45 PM
First step or second step?
Old 06-24-2012, 02:55 PM
Mein Auto: x5
Engine was running, first step - get rapid flashing - does not happen.
This has something to do with the particular garage door system in our building. I could link a friend's remote device (different garage system) to my car.
Old 06-24-2012, 03:18 PM
chiefneil's Avatar
If you're unable to reset the Homelink's memory in the very first step, I'm not sure how that points to an issue with your remote device.
Regardless, if you're able to program a button with your friend's remote, then try again with your remote but this time try touching the remote to the mirror during the learning step. That worked for me after many attempts with just holding the remote close.
Old 06-24-2012, 03:46 PM
Mein Auto: x5
Thanks for replying. I can clear memory (buttons 1, 3 together), that's fine. I can't get learning, I guess it's step 2, sorry for confusion. I've already tried touching the mirror, also different angles, distances, etc. Nothing works. It must be either incompatibility of the garage system with homelink, or the remote's battery is weak (although it works fine opening garage door).
e70
