760Li, success using the laptop to clear serious codes and register a new battery - Page 2 - Bimmerfest - BMW Forums
Old 06-19-2012, 03:04 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Originally Posted by mws View Post
I glossed over the link Stuart posted (sorry, Stuart) and thought it was just a cable. These guys appear to be bundling everything.
Please let us know how it goes once you get it. Yeah, I agree, if more than one or two members can voiuch for the setup of this, and say it works, forget the Bavariantechnic stuff!
I have this setup and I think its great, if you go and have a look at some of the E39 and E46 forums there are knowledgable guys on there that have been using this setup for years.
So long as your competent installing some USB drivers and following some instructions its pretty straight forward, you should be up and running in around 30 mins. Installing DIS takes a few hours, its pretty complicated, I find that INPA performs the same functions much quicker!
For example, scanning the whole car using DIS took around 5 mins, as it talks to each module in turn, I have recently found a method of doing this in INPA and it does it in about 5-8 seconds! It gives a quick overview of the modules and tells you if any errors are present. They are displayed as HEX here but you can then go back and read the full error report from each module that your interested in.
If you own an E65/66 then you definitely need something to read error codes!
Code:
           E R R O R   M E M O R Y
Date:      19.06.2012 18:31:24
Model:     E65
Scope:     all control module
JobStatus: OKAY
Quantity:  48
ADR Gen. name  JobStatus Number of errors
              Error code   Kind of error
00  ZGM        OKAY      No Error stored
01  SIM/SGM    OKAY      1 Error stored
              9487         60
02  SZL        OKAY      No Error stored
03  SASL       OKAY      No Error stored
04  SASR       OKAY      No Error stored
05  STVL/TEFA  OKAY      No Error stored
06  STVR/TEBF  OKAY      No Error stored
07  SSFA       OKAY      No Error stored
08  SSBF       OKAY      No Error stored
09  SBSL       OKAY      No Error stored
0A  SBSR       OKAY      No Error stored
0D  SSH        OKAY      No Error stored
0E  SFZ        OKAY      No Error stored
12  DME/DDE    OKAY      2 Error stored
              278B         02
              284F         28
18  EGS        OKAY      No Error stored
23  ARS        OKAY      1 Error stored
              D1E1         E8
29  DSC        OKAY      No Error stored
2A  EMF        OKAY      1 Error stored
              D3BE         A4
36  TEL/MULF   OKAY      5 Error stored
              A37B         60
              A37C         60
              A384         60
              A385         60
              D691         20
37  AMP        OKAY      1 Error stored
              D6D1         20
3B  NAV        OKAY      1 Error stored
              D7E4         20
3C  CDC        OKAY      No Error stored
3F  ASK        OKAY      1 Error stored
              D8CF         20
40  CAS        OKAY      No Error stored
41  DWA        OKAY      No Error stored
42  CIM        OKAY      No Error stored
43  POW        OKAY      1 Error stored
              A158         21
45  RLS        OKAY      No Error stored
46  WIM        OKAY      No Error stored
47  ANTTU      OKAY      No Error stored
4B  VIDEO      OKAY      1 Error stored
              A390         61
4C  TMFT       OKAY      No Error stored
4D  TMBT       OKAY      No Error stored
4E  TMFTH      OKAY      No Error stored
4F  TMBTH      OKAY      No Error stored
60  KOMBI      OKAY      1 Error stored
              931C         21
62  MOSTGW     OKAY      1 Error stored
              E191         20
63  MMI/CCC    OKAY      No Error stored
65  BZM/SZM    OKAY      No Error stored
66  BZMF       OKAY      No Error stored
67  ZBE        OKAY      No Error stored
69  FAH        OKAY      No Error stored
6A  BFH        OKAY      No Error stored
6B  HKL        OKAY      No Error stored
6D  FAS        OKAY      No Error stored
6E  BFS        OKAY      No Error stored
70  LM         OKAY      3 Error stored
              9CB9         22
              E519         24
              E514         24
78  KLIMA      OKAY      1 Error stored
              9C60         61
You can then clear all errors on all modules with one click. Another feature is a list of all modules, part numbers, software versions etc... that are in the car, very useful if your updating other modules in the car and re-flashing software using WinKFP.
It also shows manufacturing dates of modules so you can see what modules have been replaced in the past. (If your interested in that kind of thing )
Code:
           I D E N T I F I C A T I O N
Date:      19.06.2012 18:35:36
Model:     E65
JobStatus: OKAY
Quantity:  48
ADR Gen. name  JobStatus SGBD     GROUP    Part No.  VarI DiaI CoI HwI   SW-No FSV   SW-No OSV   SW-No MCV   SW-No res       Date Supplier         Name
00  ZGM        OKAY      ZGM_E65  D_ZGM    6941842   4335 0100   0  15       7.0.2      0.4.10      0.9.22      0.1.95 17.12.2002 Loewe => Lear    Zentrales Gatewaymodul
01  SIM/SGM    OKAY      SIM      D_SIM    6949899   4441 0110   7  05      6.14.1       6.9.0     0.6.108 255.255.255 06.12.2001 Loewe => Lear    Sicherheits- Informationsmodul
02  SZL        OKAY      SZL      D_SZL    6970833   4442 0120   8  10      6.15.0      6.10.1     0.6.119 255.255.255 09.10.2003 Kostal           Satellit Lenks***8240;ule
03  SASL       OKAY      SASL     D_SASL   6949909   4443 0130   7  05      6.14.1       6.9.0     0.6.101 255.255.255 30.11.2001 Delphi PHI       Satellit A-S***8240;ule links
04  SASR       OKAY      SASR     D_SASR   6949908   4444 0140   7  05      6.14.1       6.9.0     0.6.102 255.255.255 04.12.2001 Delphi PHI       Satellit A-S***8240;ule rechts
05  STVL/TEFA  OKAY      STVL     D_STVL   6970905   4445 0150   7  05      6.14.4       6.9.0     0.6.116 255.255.255 13.11.2001 Siemens          Satellit T¸r vorne links
06  STVR/TEBF  OKAY      STVR     D_STVR   6970907   4446 0160   7  05      6.14.4       6.9.0     0.6.117 255.255.255 13.11.2001 Siemens          Satellit T¸r vorne rechts
07  SSFA       OKAY      SSFA     D_SSFA   6949905   4447 0170   7  05      6.14.1       6.9.0     0.6.114 255.255.255 16.01.2002 Loewe => Lear    Satellit Sitz Fahrer
08  SSBF       OKAY      SSBF     D_SSBF   6949904   4448 0180   7  05      6.14.1       6.9.0     0.6.113 255.255.255 16.01.2002 Loewe => Lear    Satellit Sitz Beifahrer
09  SBSL       OKAY      SBSL     D_SBSL   6949911   4449 0190   8  05      6.14.1       6.9.0     0.6.103 255.255.255 10.11.2001 Delphi PHI       Satellit B-S***8240;ule links
0A  SBSR       OKAY      SBSR     D_SBSR   6949910   444A 01A0   8  06      6.14.1       6.9.0     0.6.104 255.255.255 01.12.2001 Delphi PHI       Satellit B-S***8240;ule rechts
0D  SSH        OKAY      SSH      D_SSH    6949906   444D 01D0   7  05      6.14.1       6.9.0     0.6.115 255.255.255 16.01.2002 Loewe => Lear    Satellit Sitz hinten
0E  SFZ        OKAY      SFZ      D_SFZ    6949901   444E 01E0   8  04      6.14.1       6.9.0     0.6.105 255.255.255 27.11.2001 Delphi PHI       Satellit Fahrzeugzentrum
12  DME/DDE    OKAY      ME9E65_6 D_MOTOR  7540760   3051 000F  12  10 255.255.255 255.255.255 255.255.255       0.0.0 30.11.2001 Bosch            Motorelektronik ME 9  8 Zylinder N62
18  EGS        OKAY      GS19     D_EGS    7534928   324C 0200   0  43   6.255.255      3.0.11     0.9.238       0.0.0 20.10.2001 ZF               Getriebesteuerger***8240;t GS19
23  ARS        OKAY      ARS_E65  D_ARS    6762208   4131 0250  11  C1      6.13.0      2.3.12      0.5.48       3.7.2 04.12.2001 Temic            Aktive Rollstabilisierung
29  DSC        OKAY      DSC_E65  D_DSC    6759565   0001 0270   0  01      6.46.0       0.0.0      0.6.36       0.0.0 04.11.2001 Bosch            Dynamische Stabilit***8240;tskontrolle
2A  EMF        OKAY      EMF_E65  D_EMF    6760702   4132 0280   7  33      6.55.0       2.3.0      0.5.50       0.0.0 16.11.2001 Siemens          Elektromechanische Feststellbremse
36  TEL/MULF   OKAY      TELE60_3 D_TEL    9149615   5542 0632  18  18       6.1.5 255.255.255    0.22.150       0.0.0 12.01.2007 Unknown manufact Telefon ECE,US,Japan Variante
37  AMP        OKAY      AMP_E65  D_AMP    6941681   4141 02A0   0  06       7.5.0 255.255.255     0.6.145       0.0.0 19.08.2003 Becker           Top HIFI Verst***8240;rker
3B  NAV        OKAY      NAV_E65  D_NAV    9195222   4231 02E0   5  61       9.8.2 255.255.255     0.6.118       0.0.0 07.07.2005 VDO              Navigation ECE/US
3C  CDC        OKAY      CDC_E65  D_CDC    6919474   4450 02F0   0  11       6.3.3 255.255.255      0.6.30       0.0.0 16.10.2001 Alpine           Audio CD-Changer
3F  ASK        OKAY      ASK_E65  D_ASK    6924724   4143 0300   2  03       7.1.0 255.255.255      0.6.18       0.0.0 07.12.2001 Becker           Audio System Kontroller
40  CAS        OKAY      CAS      D_CAS    6942488   4148 0310   3  03      6.12.8       2.3.0    0.10.216      0.1.57 07.08.2003 Siemens          Car Access System
41  DWA        OKAY      DWA_E65  D_DWA    6929701   414D 0320   3  C1       6.3.6       2.3.0      0.5.34       0.0.0 03.12.2001 Megamos          Diebstahlwarnanlage
42  CIM        OKAY      CIM      D_CIM    6764527   4149 0330   3  21       6.4.2       2.3.0     0.8.228       0.0.0 07.12.2001 Temic            Chassis Integration Modul
43  POW        OKAY      POW_E65  D_POW    6935431   4234 0341   3  C3      6.50.0       2.3.0       0.9.0       0.0.0 14.08.2001 Hella            Powermodul
45  RLS        OKAY      RLS_E65  D_RLS    6922046   4139 0360   2  41       6.0.5       2.3.0      0.5.41     99.16.4 18.09.2001 Kostal           Regen- Lichtsensor
46  WIM        OKAY      WIM_E65  D_WIM    6923740   4334 0370   3  00       6.5.4       2.3.0     0.6.147       0.0.0 22.02.2000 Bosch            Wischermodul
47  ANTTU      OKAY      ANT_E65  D_ANTTU  9145422   4146 0380   3  43      6.8.67 255.255.255      0.6.16       0.0.0 04.12.2001 VDO              Antennentuner
4B  VIDEO      OKAY      VID_E65  D_VIDEO  6933861   4332 0390   0  C3      6.4.34 255.255.255     0.6.142       0.0.0 08.12.2001 Loewe => Lear    Videomodul ECE
4C  TMFT       OKAY      TMF_E65  D_TMFT   6945385   4330 03A0   4  00      6.10.5       2.3.0     0.6.137       0.0.0 08.06.2001 Siemens          T¸rmodul Fahrer
4D  TMBT       OKAY      TMB_E65  D_TMBT   6945383   4259 03B0   4  00      6.10.5       2.3.0     0.6.135       0.0.0 08.06.2001 Siemens          T¸rmodul Beifahrer
4E  TMFTH      OKAY      TMFHE65  D_TMFTH  6945386   4331 03C0   4  00      6.10.5       2.3.0     0.6.138       0.0.0 19.11.2001 Loewe => Lear    T¸rmodul Fahrer hinten
4F  TMBTH      OKAY      TMBHE65  D_TMBTH  6945384   425A 03D0   4  00      6.10.5       2.3.0     0.6.136       0.0.0 21.09.2001 Loewe => Lear    T¸rmodul Beifahrer hinten
60  KOMBI      OKAY      KOMB65_2 D_KOMBI  6969024   4133 03F3   6  10     6.17.22    35.242.5    0.14.135      6.17.4 25.01.2002 VDO              Instrumentenkombi
62  MOSTGW     OKAY      MC_GW    D_MOSTGW 9149996   4158 0400   0  01     6.142.0       2.3.0     0.8.251       0.0.0 16.08.2005 Becker           MOST/CAN-Gateway (im MMI)
63  MMI/CCC    OKAY      MMI_GT   D_MMI    9157123   415A 0410   4  02     6.165.2 255.255.255     0.8.251      6.10.1 10.05.2006 Becker           Mensch Maschine Interface Grafikteil
65  BZM/SZM    OKAY      BZM_E65  D_BZM    6928255   4257 0430   0  15       6.7.0       2.3.0       0.5.9       0.0.0 01.06.2001 Eaton            Bedienzentrum Mittelkonsole
66  BZMF       OKAY      BZMF_E65 D_BZMF   6920884   4258 0440   0  15       6.7.0       2.3.0      0.5.10       0.0.1 16.07.2001 Eaton            Bedienzentrum Mittelarmlehne
67  ZBE        OKAY      EC_E65   D_EC     6933261   414E 0540   0  01    6.67.235       2.3.0     0.2.212       0.0.0 30.03.2001 Alps             Zentrale Bedieneinheit
69  FAH        OKAY      FAH_65_2 D_FAH    6924879   424C 0451   3  09      6.12.0       2.3.0      0.5.17       0.0.0 28.11.2001 Temic            Sitzmodul Fahrer hinten
6A  BFH        OKAY      BFH_65_2 D_BFH    6924879   424C 0451   3  09      6.12.0       2.3.0      0.5.17       0.0.0 28.11.2001 Temic            Sitzmodul Beifahrer hinten
6B  HKL        OKAY      HKL_E65  D_HKL    6935618   4154 0470   2  C1       6.0.9       2.3.0      0.6.58       0.0.0 03.12.2001 Helbako          Heckklappenlift
6D  FAS        OKAY      FAS_65_2 D_FAS    6924878   424C 0451   3  09      6.12.0       2.3.0      0.5.17       0.0.0 30.11.2001 Temic            Sitzmodul Fahrer
6E  BFS        OKAY      BFS_65_2 D_BFS    6924878   424C 0451   3  09      6.12.0       2.3.0      0.5.17       0.0.0 30.11.2001 Temic            Sitzmodul Beifahrer
70  LM         OKAY                        9192641   5352 0D60  52  14     4.50.20       4.0.5    0.16.112       0.0.0 16.09.2008 Loewe => Lear
78  KLIMA      OKAY      IHKA65   D_KLIMA  6932149   4134 04C0   3  04    6.32.255       2.3.0     0.8.240       0.0.0 29.11.2001 Preh             Klimabedienteil
Old 06-20-2012, 10:15 AM
mws mws is offline
Mein Auto: 760Li, F250 V10, Ex 7.3L
Thanks, Stuart
So, I was asked when I first posted this thread "what's the point", by a certain someone-- who was removed from this thread by the admins for not playing very politely.
I think the point was: we're all professionals who (in my case work for Apple and black-box test software for a living) have tech skillz, but may not be a Windows Wiz™ and great at mucking around in the dll level of a PC to ensure drivers are working. Plus, the time. When I was 30, and unmarried, I had more time than money. I spent it on lots of projects like this.
Now, I have a 13-month old and a 4-acre ranch. I do a lot of the maintenance myself. I bought my laptop and had someone else install on it, back in October of 2010. I only just NOW had the time to bust it open and spend basically, half a day figuring it out. And my system came to me completely installed!
Also, cruising the DIY sites is daunting for those who don't have time to sift 500 emails and follow the trails for weeks worth of posts, only to find they failed or bricked their car. Or they were successful, sure, but you have to decide for yourself who actually "knows" what they are doing.
Having One-Stop Shopping, with some instructions on how to install the stuff, is very helpful. Especially for those who don;'t spend most of their time in the DIY section.
Thanks for the detailed replies, the link to the bundle on Ebay, and also for being a gentleman about it.
Old 06-22-2012, 08:41 AM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
I going to make this short, got cable and started direction to install software, about 1/2 way done and I need to test INPA to talk to car, the version that is supplied with the cable is a older version 4.6.1 or something like that, don't recall as I'm at work, I could NOT get INPA to open in windows 7, I went to bmw coding site and I am downloading the software via the link posted in the newbie section.
I wanted to pass this information on to you all as I got stuck for right now. I would suggest to just download a copy of INPA then follow directions to install USB drivers
I will know more tonight. Keeping this live in this thread.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 06-22-2012, 09:26 AM
mws mws is offline
great feedback, I will have my package soon as well.
I am currently running XP 32-bit and probably will have no issues. But your feedback should certainly be passed on to the vendor, ESPECIALLY via their Ebay feedback which most Ebay vendors are very careful to protect. I guess it would be more sporting to email them first and get a response. They might bend over backwards to fix the situation or at least send you an update (not that you need one). It's like rape, if no one reports it, it did not happen.
Old 06-22-2012, 10:08 AM
sirstopher's Avatar
Na, they state the software is for educational use/ viewing only and they are not liable for it working, or supporting / troubleshooting.
I will say that the cable is put together quite well and the instructions for just installing the software is extremely detailed. I think it more on the OS on my machine, I do have VM ware that was supplied, so I will just install windows XP if I can't get INPA to work.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 06-22-2012, 04:07 PM
Mein Auto: BMW F01
It definitely works on xp, it ha to be a 32 bit OS. I have it running on my MacBook in a VM running xp sp2. It does work, you need the ftdi drivers and follow the instructions supplied. The software is intended for engineers/technicians at BMW for production test routines during vehicle production and diagnosis. It works great when installed correctly find some tutorials it's pretty straight forward.
2008 F01 - Sophistograu with Saddle Brown Leather
Retrofits:
Night Vision, Digital TV, Heated M-Sport Steering Wheel + Paddles, Combox, 6NF Baseplate, 6NR Apps, Rear Entertainment System, Automatic Boot Close and Surround View Cameras.
Old 06-22-2012, 04:24 PM
sirstopher's Avatar
I will get there, the world is round....
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 06-26-2012, 06:59 AM
AUBURNTIGERFAN's Avatar
AUBURNTIGERFAN AUBURNTIGERFAN is offline
Mein Auto: 750Li
SIRSTOPHER - I just purchased the same item- let me know how your install goes (any tips/tricks) and if it works like it should when connected to your car. Thanks !
2007 Li with all the good stuff
Old 06-26-2012, 08:14 AM
sirstopher's Avatar
The cable works great, the software and the instructions are good if you have a 32 bit xp OS. I am running windows 7 64 bit, you can find that thread here on this forum. It took me two days working with Pkathee to get INPA to work, basically his software, or hers still confused about that.
I will update more at lunch.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 06-26-2012, 09:08 PM
sirstopher's Avatar
So I got the cable, started installing the software and tried to run INPA, it came up with an error that it only runs on 32bit OS. I didn't have a copy of XP and do I started the thread" INPA 5.02 on windows 7 64 bit"
Pkathee helped me by getting INPA running on my windows 7 box, but that's all I have running right now.
I will say this, after registering the battery with INPA my Max AC started working. The very second we hit the button...... I now have a final stage resistor that my Indy told me to replace. Extra part....
My Indy told me that 1. The car did not have the battery monitoring system, and 2. They used the 4in1 Bavarian tool to register my battery that did absolutely NOTHING.
I suspect that 50% of the people on this board have not registered the battery with the correct software, or have not done this process at all....I am telling you right now it makes all the difference in the world.
So, I did contact the eBay seller and he told me they have a new DVD they are sending out to me with a 1 click install.
My email was nice but I stated the listing on eBay stated that it did work with windows 7......and I am sure it does after reading the 5 different install instructions that are placed in different directories and you then have to login to 4shared and download the 5.02 update for INPA.
I have built computers, deigned websites, written some code, ect....but this just all goes back to the very first post. All of these instructions are strung out and all over the place.
Ok, going to sleep now
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 06-27-2012, 05:55 AM
Lastcombo's Avatar
Lastcombo Lastcombo is offline
Mein Auto: BMW745I E65 ,BMW318 IS 94
That's some good information thanks for sharing
Bayerische Motoren Werke
Old 08-03-2013, 07:01 AM
mlgoolsby8 mlgoolsby8 is offline
Mein Auto: BMW
registing my battery
Originally Posted by samadkins29 View Post
Can you give more detail as to what you were hooking to the car with? I keep hearing the INPA and DIS stuff but nobody every really states what cables and or devices they need in addition to the software. I feel like I should know this considering I'm a computer tech, lol
I keep hearing the INPA and DIS stuff but nobody every really states what cables and or devices they need in addition to the software. Please give me more information, because I am having problem trying to reset my battery.
Old 08-03-2013, 10:10 AM
mws mws is offline
start here. there's a vendor in England that has a kit that supposedly has tons of new instructions and is plug n play
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
I have not used this kit. I looked up a guy called Randomy on bimmerforums and literally asked him what to buy, and sent it all to him and paid him to set it up and test it for me.
Old 08-03-2013, 07:04 PM
Qmetro Qmetro is offline
Qmetro
Send a message via Yahoo to Qmetro
Mein Auto: 97 540i,03 745li
M
