E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Tie Rod End Question
I understand that where the tie rod end connects to the spindle can get worn out. But can the tie rod end where it attaches to the rack and pinion get worn out?
I am getting some bad cupping in my front tires. I have just replaced all of my ball joints, lolly pops, sway bar end links and sway bar frame bushings. The outer ends of my tie rods look good, no play, but it looks like the tie rod is moving where it attaches to the rack and pinion. Thanks for the advice!
E36 M3 |
Yes. Replace the inner/outer tierods. I normall see the inner tie rods on E36s wear out before the outer.....
Absolutely, inner tie rods can definitely wear.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
Thanks guys. Looks like my front end will be nearly brand new before I take it to be aligned!
Sent from my T-Mobile myTouch 3G Slide using Bimmer App
E36 M3 |
That's the best way to do it. Just replace everything up there and get ONE alignment. The parts are cheap enough.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
totally agree with this. But I don't know about inner wearing faster than outer. The outer tie rod has the ball joint that connects to the hubs. That seems to go first.
And the inner has a ball joint, too. Although the range of movement isn't much, it still wears, particularly if the boot is compromised.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Most people just buy the complete tie rod, inner and outer as one piece. If you have to get an alignment anyway, throwing a couple of extra bucks to replace the whole things makes the most sense to me.
It is "recommended" that you get the proper thin wrench to remove the inner tie rod end. I did it with a pair of channel locks without issue. Craig
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door) Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat) Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel) |
When buying tie rods, be sure to also buy new tie rod locking plates (you need two). They are 1-time use only.
And don't get anything but lemforder or meyle parts. Less quality parts are JUNK. (fem, febi
| Tags |
| tie rod end |
