Discussion pertaining to the flagship BMW here. |
I'm n fl... There's been a bad hurricane and I get into my car just a Lil bit ago to find out my sunroof was partially open so the whole passenger side of my car was flooded...
I soaked up as much as I could... I drove the car and all the lights on my cluster went crazy and I was stuck in seems to be like 2nd gear... Power steering stopped workin and everything else... Can someone please help me... Also, there is no check engine light and I also can post a video of my cluster |
Btw it's a 03' 745i
Sounds like you have soaked a load of modules in the floorpan area.
I would suggest you park the car up and disconnect the battery immediately, as water has penetrated one or more modules the voltage mixed with the water will corrode the PCB's inside. You will need to completely dry the car out, if its humid this will take some considerable time, Remove the front seats and carpet to make things quicker. Reconnect the battery and hope you can reset error codes and things return to normal. These are probably the worst cars to suffer water damage. |
You happen to have any type of comprehensive coverage on your auto insurance? Might be worth while to file a claim.
No I dont, had the car for awhile n I just looked up kbb it's only value at $7400 trade in n $9100 private
Those prices are with the damage right? I cant find any 03's going for less than $12k up here. But anyways, if you've done all the drying out you can, then something is definitely corroded. If your tech savvy then at least pay to have the car diagnosed an go from their.
Ill be honest, I cant confirm if thats it or not. I dont think its going to be possible to say its "this or that" module for sure from anyone who hasn't seen the car in person.
If there's no check engine light will the dealer still b able to scan it?
Yes, they should have the tools to diagnose all parts of the car. To bad you nto up here, could have hooked it up to my friend Snap-on Verus system
do like people been telling you , Take the seats & carpet out & dry them completely .
Then start drying the floor boards . don't put the carpet back in til it is all dry .
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
a Verus isnt going to tell you everything thats wrong with that car.
better act quick. you doing nothing and waiting is just making it worse. bring it to sports'n'imports in kissimmie. Talk to Jivi. Last edited by bigugly fab; 06-26-2012 at 06:43 AM. |
If it was only that easy I would... Thanks
The ZGM module is under the dash, from what you have said this should not have got wet.
At a quick glance there are 5 modules in the lower floor pan, the seat controllers and the airbag satellites. From what you are describing it sounds like the body CAN may be down due to a faulty unit. Also the CAN bus requires an impedance of 120 ohms between CAN H and CAN L to operate correctly, any water in the electrical connectors will cause major problems here. The E65 relies heavily on CAN buses so that modules can talk to each other. I Would estimate even with the carpets out and the windows open (in a garage) it could take days for it to naturally dry out properly. I would remove the carpet and mass of insulation and take out all the modules that have got wet and put them in an airing cupboard to dry out thoroughly. Check connectors are dry and use contact cleaner to remove moisture otherwise they will only corrode later on. It's not an easy task an it's a lot of messing around. It's not going to dry out overnight. Stuart |
The carpet needs to be pulled. That foam under the carpet can hold gallons of water. It takes days in the sun to fully dry without mold and mildew.
Whatever you do, you need to act quickly to not total this car |
Yea my driveway is pretty up at a angle... And there was gallons of water that I got out... This may sound dum but I turned on the car and opened the doors and have the heater blowin on the floor and now all the lights arnt flashin and the car actually idles now...
Also, the transmission malfunction went away, P/S is also workin
There will be a seat module an airbag module and another module under the passenger seat (if your left hand drive).
You may end up with intermittent faults in future with the body modules malfunctioning because of CAN errors caused by poor electrical connections inside connectors or damage caused to PCB's inside modules, these cars are temperamental enough as they are! and random errors would drive you mad! |
Yeah brown wires are grounds. I would remove any units that have got wet and dry them out thoroughly. That's a fair bit of water!
#25
So if those are the grounds can u post a pic of the modules??? All I c is the grounds and a Blk box that has Bosch on it... So since the last post I just started my car and everything is back to normal and I wanna thanks everyone on here for helpin out
| Tags |
| dynamic stability control, electrical failure, electrical faults, trans warning light |
