E36 (1991 - 1999)
Look at this photo with valve cover off and tell me what you think...
I was changing the valve cover gasket and this is how it looked inside. The oil was caked all over. the year is a 1994 320i. Is this normal.. the gasket was leaking and that is why i had to change it. we scraped out as much sludge as we could and sealed it back up. Is this caking due to air or moisture getting in?? the car runs fine but was leaking a fair bit of oil..
will it be ok? is this normal for a leaking valve cover gasket? any ifo would be great. thanks |
That is disgusting! I would clean the hell out of that motor.
Looks like the result of 15k oil change intervals to me...oil needs to be done around 5ishK with sythetic.
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e |
is there a way to clean it out with a flush?
will that get rid of some of the gunk? will it effect the engine? |
Run Seafoam through it. You can pull the cover again pour it all over the top, that will help break that up then run the motor for about an hour or two then change it. When you put in the new oil add about half a can to it then fill the rest with regular oil, run it about 3k then pour a full can into it run it for a bit then change again. look inside as best as you can to see how clean it is if it isn't do the same thing again and again until clean. Good luck. if you don't feel good about using seafoam then you can substitute it with ATF. Use a full quart every oil change until its clean.
Ick, that is gross. It's most likely the result of excessively long oil change intervals and driving short distances.
How often do you change the oil, and what is your daily driving like?
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
yes... you are right.. i dont drive alot ,, maybe 10 min drive to work everyday - before that i walked to work and car sat alot.. oil change every few years.. car is a 1994 but only has 83,000 miles on it...
will it be ok?? can the aditive clean it out a bit??? |
Change your oil! every few years?? you serious bro?
Seafoam will help but you need to do a complete foam, crankcase, brake booster and probably wouldnt hurt to put it through the fuel system. Last edited by Apex_24; 06-25-2012 at 10:06 AM. |
Oil changes every few years?!? Yikes. A ten minute drive is barely long enough to warm the engine up and burn off any accumulated condensation which builds up inside the crankcase while the car is parked. Even with putting very few miles on the car annually, you really should change your oil at least twice a year. You are hurting the engine severely by keeping the oil in there for so long, and then subjecting it to very short drives. The condensation is never getting the chance to burn off, and it's building up to an absurd degree due to the oil never getting changed. Better get some Seafoam in there. That's one gummy looking engine.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 06-25-2012 at 10:19 AM. |
That's pretty typical of dino oil that's been driven short and changed too seldom. Used to see a lot of engines like that in my friends dad's salvage yard. No surprise why they were there.
I think you're going to have better luck with the ATF than you are with the Seafoam. The ATF has more detergents in it than solvents and tends to not evaporate out. Seafoam is high solvent content and will evaporate out and that engine needs something that's going work a long, long time.I'd be tempted to go 6 quarts of high detergent dino oil and a quart of ATF and drive a couple hundred miles then drain it, change the filter and fill again with the same mix. Keep the revs under 4K with the ATF mix in. When you change the filter you'll have an idea if you're making any progress. I'd expect to see a lot of crud in the filter initially and then it will start to taper off. When the filter looks fairly clean, switch to a good synthetic and change the oil every 3K miles or 6 months, whichever comes first. No engine should ever go more than 6 months without an oil change no matter how low the mileage.
Eek. Seems like everybody else nailed it. I suppose it can't hurt to try and wipe off as much as you can before putting the valve cover on and seafoaming, running ATF, etc.
-CJ
HOLYFCK.
No, nothing about that sludge is "normal". that pic.. makes me ill. Oil changes every year..? Why does that seem ok? Do NOT neglect the method of conveyance that gets you to work everyday. You drive 10 minutes.. to work? If you are only 10 minutes from work.. RIDE A BIKE. ![]() ![]() I dont care if you're crippled.. they make em for handi-capable people too. ![]() You'll save money on fuel, insurance, & registration. Not to mention you'll benefit from better health..and YOUR CAR WILL TOO.
Change oil every 3,000 miles ?? Good advise for the Model T's but folks we have made a little progress with oils and engine materials and tolarances over the years. 6 or 6 ( miles/months) would be max conservative for todays - 1994 included - products and synthetic oils do give a bit more protection for all conditions. Drive more longer periods then change a bit less frequently. It's all in the manuals and other related literature. Of course what happened here is beyond all understanding.
Cheap Trick |
Actually, the OP stated that the oil is changed every FEW years.
![]() Article A: Scary. The reality is that not everyone is a nuts & bolts car guy, and many don't know that oil should still be changed even if you don't drive very much. That seems to be what happened here. Quote:
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 06-26-2012 at 12:44 PM. |
That makes me soooo sad. ![]() Quote:
YOU SHOULD AT LEAST READ THE OWNERS MANUAL. Oil changes seem rudimentary in comparison to VCG.Quote:
Yeah, I actually just had my oil analyzed by Blackstone Labs because I was curious about the ramifications of leaving oil in for long periods of time despite low miles. The sample I sent them only had 3,673 miles on it, but it had been in my engine for about 9 months. My report came back perfect except a very trace (and insignificant) amount of fuel. The reason why my engine isn't all sludged like the OP's is because I refuse to use my car for short drives where the engine barely warms up. Coincidentally, I ride my bike to work year round... Car only gets driven on weekends and occasionally for errands on weekday evenings.
Yeah.. I DRIVE mine too.
![]() and a big MF-ing +70 virgins for you riding your Bike.
bmw-mania, Ladies and Gentlemen.
-CJ
*bow*
My new SIG.
that is gross....
Turbo lag is actually a headstart to make it fair |
![]() dammit.. you made me do it again..
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
