E34 (1989 - 1995)
Coolant Level Warning
Hi all, after successfully fixing the ongoing issues with my light warnings(thanks to Shogun) I have been driving happily with no 'BING's" until I replaced the radiator along with a new Coolant Level Sensor. I keep on getting incorrect low level warnings. After the first time I reset by earthing the plug but the warnings keep coming. Level is fine.
Suggestions?? Cheers Weisebar |
The floats dislodge on the sensor I think. I just wired the float on to the sensor on mine solved the check control bell .You be the sensor and check your level evey time you drive.
Check your wires very carefully. Here is what I found in my coolant system overhaul:
![]() Hope this helps.
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
It is probably wiring since he ruled out the sensor.
Could be faulty part.
Thanks for the reply's guys.
Will check as suggested Cheers Weisebar |
