E30 (1982 - 1993)
91 318 is
my indie BMW Garage said it's cost prohibitive to replace the leaking timing chain cover gasket. Is this a possible DYI repair for a novice mechanic? I also have a high quote to repair the non-functioning electric fan located behind the radiator. Shop owner said the fuse box is likely culprit and need to be replaced...may or may not fix fan. Does any of this sound reasonable? The numbers sound like BMW dealer numbers so I'm going to drop it off there tomorrow for a second opinion.
Find a different shop. Seriously.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Lol take a 2 dollar switch and wire up a toggle switch for the fan instead of paying a buttload of money to a shop or do some research on here and it shouldn't be to hard to switch I ripped all my a/c equipment out because in wa turning all the way to cold blows cold enough for me
sounds like another money hungry mechanic thats taking advantage of your car being a euro
![]() Personally I would think this "mechanic" should rather sell Newspapers, that way he can cause less damage
I would say take it to the BMW dealer and see what their opinion of it is and then go to a different shop that specializes in euro cars and one that doesn't and compare the quotes of what it would take.
Hot, hot, hot
it's freakin' hot here....107 in Austin today but I like the wire switch directly to fan idea best. I actually did think of that but I'll wait till tomorrow to see what the dealer says.
thx all |
'91 318is fan
Problem was a burnt out relay, $175 less 20% for BMW Club Membership at dealership.
You can buy a relay your self for $10 bucks. Just pull the old one/s and pluging. Highspeed relay is K6. Try jumpering it. Pull the battery, unplug the k6 relay on the underside of the relay put a wire inbetween 87-30 though the holes in the relay plugs. Then plug in and plug in the battery. It will stay on the whole time unless you unplug the battey or pull the relay. Good thing to know if your car is ever over heating.
^this. $140 for a relay is preposterous.
It could just be a bad resistor on the fan.
