Old 06-27-2012, 06:23 PM
navytattoos navytattoos is offline
Your not first your last!
Mein Auto: 2000 540i
Crankshaft position sensor location
Hey, so i have an oil leak and the guys at the shop that did my alignment said its coming from the crankshaft positon sensor and that it happens alot on these.
So one is it just a seal? and two WHERE the hell is it on the engine? LOL
car is in the air cause im rebuilding the gears and rear suspension may do the trans fluid too. but i would like to bang that out now that i do have the time. Thank you all any help would be great.
Its a 2000 540i 4.4l
Old 06-27-2012, 06:34 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
He might be confused. The crank sensor is nowhere near a source of oil. He may have meant the cam position sensor. There are two on your car, on the front face of each cylinder head.
Old 06-27-2012, 06:43 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
tha cam position sensor uses an o-ring.
the vanos solenoid uses a gasket. solenoid is more likely.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 06-27-2012, 06:51 PM
Really! hmmmm i already did the cam sesors and those and nice and dry. what is the Vanos solenoid and where is that located?
I may power wash the hell out of the engine bay and wait for a drip. Ill bring a sandwich wih me...
Old 06-27-2012, 07:15 PM
JimLev JimLev is offline
The vanos solenoids are mounted in the front of the heads below the cam sensors. The are about 4" long and 1.5" in diameter with a 2 pin connector on the end.
Your crank sensor is in the pass side of the tranny bellhousing. It's the little thing sticking up in the lower left corner of this pic. I don't have a pic from the outside.
Old 06-27-2012, 07:24 PM
Thanks alot everyone Im going to take a look at the solenoids tomorrow when i do the valve cover gaskets.
Old 06-27-2012, 07:58 PM
Topaz540i's Avatar
Agnostic Priest
Look for the black rubber gasket number 9 in this pic
http://realoem.com/bmw/showparts.do?...47&hg=11&fg=10
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 07-03-2012, 01:08 PM
Hey all
So I did the valve cover gaskets and degreease the engine bay and it looks like its leaking oil by the driver side engine mount any ideas?
Old 07-03-2012, 01:37 PM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
Are you sure it's not the vanos seals and running around the block and down near the mount?
I have minor oil leak that runs down drivers side on to the power steering pump. I think this is the vanos seal that appear to be leaking (lots of dirty oil around them) but hard to see with pipes and stuff in that area. There ~$6 each and two bolts to change so a good starting point.
A side comment would be are you sure its engine oil? Powerstering fluid is common leak on that side of the engine bay. The mounts are also oil filled so the could have just have gone and be leaking their oil.
Old 07-03-2012, 01:41 PM
His oil lines from the remote oil filter canister go to that side of the block.
Old 07-03-2012, 02:11 PM
Well, it's too late now, but pressure-washing a modern engine is a big no-no. You have no doubt forced water into several electrical connectors, that will begin a corrosive process that will cause a plague of electrical malfunctions for years.
Old 07-03-2012, 02:25 PM
Na it's not the vanos seals its nice and dry in the front of the motor.
And no I didn't pressure wash the engine. And it's not ps fluid I replaced all that already.
Jimlev may be right if I shove my hand up I can feel the wetness right in that area.
Is this going to be an easy job or should I leave it be.
I'm looking into building a turbo engine setup. But I do love driving this car so I don't want to take it off the road just yet till winter.
Old 07-03-2012, 02:28 PM
I sold my 72 camaro race car to buy and build this car. But I can't stop driving this thing it's to much fun..
Old 07-30-2012, 05:34 PM
beam95530i beam95530i is offline
Mein Auto: 95 BMW touring
camshaft position sensor
had engine light check and found P1397 fault. Camshaft Position Sensor. What does it mean when it says "B" circuit (bank 1). don't know if it's the exhaust or intake. would you know? is these an easy fix? could use your input on this. thanks
Wil
i have a 2000 528it.
Old 07-31-2012, 10:37 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
Wil
Circuit B is exhaust. It's a 5 min job and only requires a 5mm allen key. It's right under the t-stat behind the expansion tank.
Old 08-05-2012, 09:08 PM
thanks for the help! didn't quiet knew where it's located since i don't have the manual yet. thanks again.
Wil
Old 09-09-2012, 04:39 AM
ZUSHAH786@AOL.C ZUSHAH786@AOL.C is offline
Mein Auto: BMW 530I
LOCATION AND CHANGING OF CAMSHAFT EXHAUST POSITION SENSOR BMW 530i (E39)
Old 09-09-2012, 04:40 AM
Mein Auto: BMW 530I
LOCATION AND CHANGING OF CAMSHAFT EXHAUST POSITION SENSOR BMW 530i (E39),YEAR 2001
Old 09-09-2012, 01:37 PM
collardgreens's Avatar
collardgreens collardgreens is offline
Mein Auto: 01 540/6
Upper oil pan gasket?
