The X5 SAV Forum
Old 01-13-2012, 09:41 AM
fastro01 fastro01 is offline
Mein Auto: 2006 X5
2006 X5 check low beam warning when I use fog lamps.
Occasionally I get a Check Low Beam Lights warning and then my headlights do not work. If I shut my truck off and restart they then work. This only seems to happen when I am driving with my headlights and fog lamps on. If my fog lamps are off, I don't get the Check Low Beam Lights warning and don't lose the use of my headlights. Has anyone had the same issue? Any trouble shooting suggestions?
Old 01-13-2012, 04:31 PM
DirtyDan DirtyDan is offline
Mein Auto: 2003 X5 3.0i
Have you ever changed your battery? It could be an indicator of it going bad. It may not be keeping a current battery level.
Old 06-27-2012, 10:38 PM
Mein Auto: 2006 X5
Problem Resolved
I ended up taking it in to my mechanic. It turns out that the previous owner had replaced the headlight bulbs with non-OEM bulbs (manufactured in Hungary). They were not drawing current at a consistent level, which caused the fault. I replaced the bulbs with OEM's and no more problems.
