The X5 SAV Forum
Old 05-14-2012, 09:56 PM
Zelimir Zelimir is offline
Mein Auto: 2003 BMW X5
Yes | No A/C Cooling Fan not working
Hi all,
I'm having an issue with my cooling fan, it will not start. AC blows cold when car is running but when it stops, it is kind of blowing hot air. I was told not to use the AC while in idle, it could damage the ac compressor since fan is not working. Now, how can I check if fan is bad or just a relay?
Thanks,
Zelimir
Old 05-29-2012, 05:27 PM
Siberiangroup Siberiangroup is offline
Mein Auto: X5 2002
Easy.
Turn car on. Turn AC on. Unplug AC fan wire(located on main fan shield, passenger side) and than plug in. If fan will move a bit- relay is good, fan- blown.
Sent from my PC36100 using Bimmer App
Old 06-29-2012, 03:57 PM
mike grunwald mike grunwald is offline
Mein Auto: 2002 X5
final stage relay
had a similar problem which eventually lead to a dead battery, replace th efinal stage relay (resistor) battery problem solved and ACand fan works properly
