E90/E91/E92/E93 (2006 - 2013)
Old 05-08-2011, 09:41 AM
ChrisUNC79's Avatar
ChrisUNC79 ChrisUNC79 is offline
Mein Auto: 335i Coupe
Less Brake dust in 2011
Did BMW recently make a change to their brakes? Other than switching to P21s, my detail regime is exactly the same with my 2011 E92 vs my previous 2007 E92; however, I've noticed significantly less brake dust accumulation even after a couple weeks between washings.
PCD 12/21/2010: 2011 335i Coupe 6MT | Black Sapphire Metallic | Saddle Brown Dakota | Premium Pkg | M Sport Pkg | Harman Kardon | Navigation | iPod/USB | Sirius | Smartphone Integration | Heated Seats | Comfort Access
Old 05-08-2011, 09:47 AM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S65B40 Powered
I believe BMW did change the pad material. I've heard some complain about less initial bite with the newer pads, but far less dust. I guess there is always a trade off.
08 E90M3 6MT Alpinweiss/Schwartz
Old 05-08-2011, 10:19 AM
Dwight_Schrute's Avatar
Dwight_Schrute Dwight_Schrute is offline
I Know Nothing
Mein Auto: '10 E92 335i
There are a few threads on this. I think they made the change for MY2010.
Never argue with a fool. Onlookers may be unable to tell the difference.
Old 05-08-2011, 10:23 AM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
my MY 2010 ( December 2009 prod) has much less dust generation than my 2007/
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 05-08-2011, 11:09 AM
Sky Keeper Sky Keeper is offline
Skxawng
Mein Auto: 335i E90 MT
new set of stock fronts produce way less dust - installed a year ago.
Old 05-08-2011, 01:51 PM
beden1's Avatar
beden1 beden1 is offline
Mein Auto: '11 335is Cab & '08 535xi
I've commented on this before that my 2011 335is gets very little brake dust, and then just usually trace amounts on the wheels and none sprayed over the rest of the car.
I asked two BMW parts departments about this, as I wanted to get the same composition of brake pads for my wife's '08 535xi which is terrible for brake dust. They had no idea, and none has gotten back to me after they were going to "check it out"!
Current Stablemates:
'12 Porsche 911 GTS Cabriolet; '11 BMW 335is Convertible; '08 BMW 535xi
Favorite Cars Gone But Not Forgotten:
'09 Corvette ZO6; '01 BMW 740iL; '90 Nissan 300ZX 2+2; '89 Jeep Grand Wagoneer; '79 BMW 320i; '79 MB 300D; '67 MG Midget
Old 05-08-2011, 03:11 PM
pointandgo's Avatar
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
I'm suspecting a move to a ceramic type pad forumula as one characteristic of ceramic type pads is low brake dust. Even semi-metallic type pads have come under attack by environmentalists due to copper content. If this is the case, I would think that there should be a stern warning in the owner's manual about what type of pad to use as replacement (with respect to the rotor compatibility).
While E.U. regulation ECE 90 establishes brake pad testing and certification, there is no such reg. for rotors (that I can find).
Old 05-08-2011, 05:42 PM
Bimmer4life Bimmer4life is offline
Mein Auto: 2011 335i
It's one of the things I love most about my car, the wheels stay clean for weeks, hardly any dust. I also use Armor All Wheel Protectant clear spray let it dry for a few hours and I swear there is almost no brake dust anymore.
THIS IS WHAT I CALL BMW "Joy"
Seriously I had an E46 before and was always cleaning my wheels, the money I spent on P21 was crazy, I could clean them and in 2 days they were filthy dirty.
No more for 2011.
Old 05-08-2011, 06:48 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi Sedan
Yep, new pad compound, same braking performance (or so close as to not matter--seriously) and damn near zero dust. What little there is, is light grey in color, barely visible on the wheels and has far lower adhesion than the old stuff. I have yet to bother buying wheel cleaner--they clean up perfectly with ordinary car shampoo and a (dedicated) sponge.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Old 05-08-2011, 09:06 PM
pointandgo's Avatar
So, my question is: are the '11 pads compatible with other MY 335i's...I've misplaced my owner's manual...what does the '11 owner's manual say about this, if anything? I do tend to think that the rotor would have to be compatible with the pad material. Generally speaking, I don't think the scope of the owner's manual extends to brake pad/rotor compatibility except for disclaimers such as "only use BMW approved replacement parts for your car."
Old 05-09-2011, 05:53 AM
DougN's Avatar
DougN DougN is offline
Original Owners Club
Mein Auto: '10 E93;'66 MGB;'73 240Z
I also think they made the change for the MY10 cars, as I have very, very little brake dust as well on my E93, and what little does accumulate comes off easily when washing. without needed to scrub it to death. I would think the MY10 or MY11 pads would fit on older models, as long as the other bits (calipers, etc.) are the same. I guess the easiest way to find out is to go the the parts department and ask for both and see if they are the same size.
Doug
________________________________________________
2010 328 E93 Titanium|Black|Aluminum
Other Cars:
1973 Datsun 240Z
1966 MGB Roadster
Old 05-09-2011, 07:56 AM
Bcube's Avatar
Bcube Bcube is offline
Combat Commuter
Mein Auto: 2007 E93 335i
As mentioned, the new pads began in MY 2010 (9/2009). And they will fit any model/year of E9X 335i. I have them on my 2007 E93. While overall braking performance would seem to be the same as the earlier pads, there is definitely less initial bite - similar characteristic as the aftermarket ones that promote "low dust" pads.
I'm still looking for the "perfect" pad for my driving situation.
-Brian
"Used cars are our entry cars." - Luca di Montezemolo
Old 05-09-2011, 10:18 AM
caesarp caesarp is offline
Mein Auto: 328i xdrive
I can also vouch for the less brake dust. I just traded in a 2005 X3 for a 2011 328xi.
Although my 328 is barely 3 weeks old, I can already tell there is much less brake dust compared to my old X3. With the X3, there was tons of dark black brake dust as soon as 3 days after the car/wheels were cleaned. Now, I barely see anything.
Old 05-09-2011, 02:13 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Originally Posted by Bimmer4life View Post
...Seriously I had an E46 before and was always cleaning my wheels, the money I spent on P21 was crazy, I could clean them and in 2 days they were filthy dirty.
This was an unexpected treat on my new 2011 328i. Clean wheels!
Although I love my old E46, I have never owned any other car that generated so much brake dust. Even my E83 generates less dust than the E46.
Thank you for listening, BMW.
Alpinweiß
E46, E83, E90 (all with three pedals)
BMW CCA member
Old 06-30-2012, 07:41 PM
whazzup whazzup is offline
Mein Auto: Lexus, Volvo
So I am not crazy. I just traded a 2010 535 for a 2012 e93 and the difference is amazing. Normal dust, just like my Lexus. Easily maintained. The e60 was horrible; I was constantly cleaning the wheels.
Old 07-01-2012, 06:32 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW E90 2007
What you had in front was NOT ONLY dust from PADS. It is also metallic particles from the rotors. That's why they are yellowish and so hard to remove if you let it there for a while. It seems to be a different set-up in the rear.
If you see less dust in the front, it is because the front rotors are no more worn the way they used to be. I wouldn't be surprised that brakes performance is a bit less good.
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers
Old 07-01-2012, 08:01 AM
It was obvious to me on the drive home from the dealer that the bite on the brakes was significantly reduced. I rarely drive over 6/10's, so it is a compromise that I can live with. I expect the emergency performance to be more than adequate.
2012 e93 335i (WooHoo!!)
2011 Lexus RX 350 (our workhorse)
2012 Volvo S60 T5
2010 e60 535i xDrive - Sold
2006 Volvo XC70 - Sold
2004 Lexus GX 470 - gone, but not forgotten
