noise from front doors / front pillars - Bimmerfest - BMW Forums
Old 12-05-2011, 01:28 PM
kanar200's Avatar
kanar200 kanar200 is online now
Mein Auto: was 530d, is X5d 2011
Hi,
Do you hear any kind of noise from the front doors / front pillars in your X5s? It is like crack of upholstery (not sure whether it is good English description).
I noticed the noise around 4k miles, I heard that mostly only when going through bumpers. Now I have 8k miles and the noise is more intense / annoying and I hear it more frequently.
Ultimate Towing Machine - towing Jayco 28DSBH (2017)
We travel not to escape life, but for life not to escape us.
Old 12-05-2011, 01:51 PM
Matt_UKTX Matt_UKTX is offline
Mein Auto: 2012 X5 35d
There have been several reports of weld issues on some of the earlier X5's which resulted in a popping/creaking sound in the door pillars. Do some searching on here and you'll find multiple posts. If this is the issue you have, you may have to lemon your vehicle since there is no fix at this time.
Current:
2014 F15 X5 sDrive 35i (Carbon Black / Ivory)
Gone but not forgotten:
2012 E70 X5 35d (Alpine White / Oyster)
2008 E60 535i (Black Sapphire / Natural Brown)
2006 E90 330i (Jet Black / Sand Beige)
2003 E46 325i (Black Sapphire / Natural Brown)
Old 12-05-2011, 01:56 PM
Some links on this:
http://www.bimmerfest.com/forums/sho...d.php?t=515778
http://www.bimmerfest.com/forums/sho...d.php?t=578972
http://www.bimmerfest.com/forums/sho...d.php?t=471428
Current:
Old 12-05-2011, 01:58 PM
1naztyx5 1naztyx5 is offline
Account Under Review
Mein Auto: E70 X5/E60 528i
wow and I thought it was just me, I have more of a squeaky sound coming from the driver side pillar very annoying but since am out of the factory warranty didn't think about it much, so you say it can be the welds ?
Old 12-05-2011, 02:00 PM
Personally, I have no idea. I just remember reading about this and posted the links. There's definitely something to this as BMW took the car back no questions asked.
FWIW, the issue seems to be fixed now. My 2012 X5 has no creaks/rattles (yet).
Current:
Old 12-05-2011, 02:05 PM
kanar200's Avatar
Thanks Matt, I have seen these posts. I watched a move recorded by the owner of such X5 - the noise coming from the weld sounds different for me. Therefore, I thought that it is just upholstery problem and maybe somebody experienced that.
I have another 3k miles to the first service (in my standards 2-4 months). I am trying to avoid trips to the dealership as much as possible
Old 12-05-2011, 03:13 PM
Frankly, if you think there is even an outside chance of a weld issue, I wouldn't wait. You don't want to find out you've got a weld failure for the first time when you're driving along at 70mph on the freeway
When you take it in, make sure you explicitly state you're concerned about the reported weld issue online. Print the pages from these forums. Make them confirm in writing (on the service report) that the welds were inspected and there is no issue - that way, if anything does go wrong, they have opened themselves up to the lawsuit from hell.
Current:
Old 12-05-2011, 09:28 PM
Billyraymallard Billyraymallard is offline
Mein Auto: 2011 x5 35i
Listen to the sound. Some felt tape or silicone grease can likely fix the noise.
Old 12-05-2011, 10:24 PM
ard ard is offline
Resident Curmudgeon
Chillax.
BMWs are notorious for the rubber weatherstrip in the door seals causing 'crackly' noises... there are 'dressings' (like Gummipfledge) that will fix the problem. People have been driven to distraction by this, only to spray on some stuff and Wa La, gone.
Just saying, worth checking it out...
Or lemon it. (Couldn't resist.)
A
Old 12-06-2011, 07:47 AM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
Chillax.
A
I had the same creaking sound from left front passenger door . . . it is indeed the weather strip . . . the felt material that sits between the top of the door frame and the body . . . *not* the felt strip against which the glass seals.
BMW actually has a service bulletin to address this issue . . . good news is it works (mine hasn't creaked for over a year, currently 24K miles on the odometer) . . . they placed a clear teflon tape on the painted body surface against which the felt strip on the door frame seals.
I am currently traveling outside the country . . . I can post a copy of the service report when I get back home - first week Jan. 2012.
Old 12-06-2011, 08:58 AM
kanar200's Avatar
Thanks for all info. I think that it could be the weather strip you mentioned. Last two weekends I spent in Tahoe area. Obviously it was colder than in the Bay Area and the noise was more annoying (the rubber less flexible?).
I will be travelling until the end of the year; I will bring the car in Jan to dealership.
Lemon probably not this time, would prefer after in ca. 2 years
Old 12-06-2011, 05:22 PM
A quick check . . . take a clean wet rag and wipe that felt material on *top* of the door frame. You may have to step on to the running board to see this felt strip. Also wipe down the painted area on the car frame against which this felt strip seals. If the creaking sound decreases (or disappears), you know for sure that is your problem.
The wipe method is very temporary . . . you will need that teflon strip installed.
My suggestion - do not use any chemicals on this felt strip until you have had a chance to install the teflon tape . . . what you don't want is for the felt strip to be altered by any lubricants and then the teflon solution is no longer effective.
Yes, in my case weather has an impact on how much it creaks . . . both the temperature and the humidity . . . recalling from memory, on humid days the noise was less.
PS: To repeat, the felt strip I am referring to here is *not* the one against which the top of the glass seals (this has a vertical orientation) . . . the one I am referring to is on top of the door frame and has a horizontal orientation.
Old 12-07-2011, 05:35 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
My X5 and my 335 are both rattle traps. Just get use to it.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 12-10-2011, 06:14 PM
Got my wife to scan and email me the relevant Service Report . . . see attached.
This telflon tape installation has worked through one summer, one winter and one rainy season . . . so I feel this problem is solved.
Name:	BMW e70 Door Noise- Teflon Tape.jpg
Old 01-03-2012, 09:31 PM
kanar200's Avatar
Hi,
I just recorded how my X5 sounds inside the best part is after 2 minutes - I drove through bumpers. Enjoy!
http://www.mediafire.com/?sstzhqj39b8i542
Old 01-04-2012, 03:32 AM
tonka858 tonka858 is offline
Mein Auto: 2015 Golf R
wow that's loud.drive with door open see if changes ..but that does not sound like dry rubber
Old 01-04-2012, 10:46 AM
kanar200's Avatar
good tip, I will try it! The noise is so loud and annoying that it makes me laughing
Old 01-06-2012, 12:36 PM
kanar200's Avatar
no noise with door open, so probably it is rubber
Old 01-07-2012, 07:15 AM
Try lowering the window just a bit so that it is still closed but not pressing hard up against the door frame.
Old 06-30-2012, 10:32 PM
kanar200's Avatar
Hi,
BMW had two attempts to fix the popping/creaking sound in the door pillars. They applied teflon tape - no improvement. The second time they changed the door seals - helped for a few miles... there is again the amusing noise...
http://oag.ca.gov/consumers/general/lemon
"During the first 18 months or 18,000 miles, the "Lemon Law" presumes that a manufacturer has had a reasonable number of attempts to repair the vehicle if either (...) (2) The same problem has been subject to repair four or more times by the manufacturer or its agents and the buyer has at least once directly notified the manufacturer of the need for the repair of the problem as provided in the warranty or owner's manual (...)"
Question: I understand it is not enough to bring the car to dealership, I have to notify the manufacturer / BMWNA about the defect. Does it matter whether the notification is done before bringing the car for the third (or fourth) service to the dealer?
The lemon law is pretty new legislation for me. What is the difference between SONG-BEVERLY WARRANTY RIGHTS where "The law applies for the entire period of your warranty" and lemon law applies "to these problems if they arise during the first 18 months after the consumer received delivery of the vehicle or within the first 18,000 miles on the odometer, whichever occurs first"?
thanks
kanar
