Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 07-15-2011, 06:26 PM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
Stealth inter-cooler install (e36)
Stock fan still resides along with the condenser.
Yes, it's the size of the entire front of the car lol...
Bent up metal, nuts/bolts and scrap fuel line turned into mounts...
Old 10-02-2011, 10:28 AM
snailinduced's Avatar
snailinduced snailinduced is offline
BoostJunky
Mein Auto: 328is
Nice!
Photobucket
T40E HKS TIAL GODSPEED 666 Ireland Engineering
UUC SSK SDS MGMT AA DDM 803HFM 42#
Old 03-24-2012, 06:37 PM
thelostartof thelostartof is offline
unbalanced chemical
Mein Auto: '00 528i/5
I come from the Volvo world and I will warn you that ic is junk, please remove it and place it in the trash asap.
any ebay ic will outflow and out cool that ic by a mile.
the Isuzu NPR ic is near drop in replacement for the Volvo one and worlds better.
that ic has around 1.5psi pressure drop @.9bar (13-14psi). We throw them away daily.
'91 744TIC, '93 944GL, '02 GMC 1500, '00 528i
Old 07-02-2012, 07:56 AM
WDRAcing WDRAcing is offline
Mein Auto: 99 540iA
Agreed, tons of nice FMIC's to be had on Ebay. That one should work for low boost though, no?
Old 07-02-2012, 11:36 AM
Holy old thread Batman!
Yeah the client scrapped the project since he wanted an e30. Traded the car before we got the turbo installed.
The new engine is at the machine shop for align boring, bore/hone piston bores, decking and rotating assy balance to 9k. Started with an m50 block, s50 rods/crank.
8.5:1 forged pistons, ARP everything, Cometic gasket, 48gm lifters, heavy valve springs, Fidenza 13lb FW, ACT PP/disk, t70 turbo, Emusa I/C, 42mm gate yadda yadda....
Probably should make a new thread about it?
Wide Open Throttle Technologies (WOT-Tech)
Instagram feed
Facebook page
