E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
#101
Get all the old stuff OUT.
LINKY Linky
Thank you home slice
"if you look close enough... youll see my bumper is being held together with zip ties
#103
the first bmw coupe trunk lid to come up for sale in a month is now on the back of my car.
#104
hey dakota, really impressed with your work. which DIY did you end up using for the PS fluid? Dougs domain looked good to me.
dab of oppo anyone? Project List: Replace coolant temp sensor Replace starter Brake and Power Steering Fluid Flush Front Control Arms, Bushings, and Tie Rods Replace Passenger Lock Actuator Reglue Peeling Hedliner Swirl removal |
#105
Thanks, means alot that guys whith such nice cars like you think im doing a good job.
I used the Dougs domain one, i intended to do the optimal flush method but i guess i misplaced my only 22mm wrench and was working later on a Sunday and couldn't go get one. I ended up doing the simple flush but instead of using a syringe i unbolted the reservoir and turned it upside down allowing me to get about a quart of fluid out. I plan to do it again in theory getting all but 1/2 a quart out. as there was no improvement in the steering i feel i may have proplems further then old fluid though.
#106
Mine's being retarded. see my post here. I'll let you know how it goes.
#107
my baby... is legal
#108
what kinda problems are you having? i fixed mine with a dousing of PB blaster on the bearing. cant hurt to try.
#109
well.. i wish you didnt ask..
i opened the hood to spray down the the pivot points and found that someone left a wrench on a transmission bolt and it was rubbing on said pivot point causing the hard steering.we can all pretend we dont know who left it there
#110
Well at least its a cheap and easy fix!
Sent from my DROID4 using Bimmer App
#111
very true, i have a problem with leaving tools in there, i left an alen wrench on the control arm which pressed up against the ac unit which was causing irregular idle.
#112
And Done.. + 7000 for this guy ^ fcuking cojones
Yeah, Dakota gets mad props for sticking with it.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
#115
Good job.
Make sure you collect all your tools before you close everything up. Like a surgeon leaving a scalpel in somebody, it could be bad news.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
#117
Ive been driving her a bunch today and yesterday, the exhaust manifold is still leaking a bit, i was unable to tighten all the bolts, but the big kick in the pants is its throwing the mass air flow sensor code agian.
#118
i got a 1214 which is apparently not a code, im assuming its a
1215 bad maf 1213 lambda control 2 then after unhooking the battery and driving around the block it got 1222 lambda control 1 does the same exact thing as it did before i changed out my maf Update, i checked the codes again today after driving a bunch today and yesterday and the maf code has not come back up after clearing the codes, im thinking it may have just been stored from before the newer maf. Any one know where to look first to fix my lambda control 1 code?
#119
#120
Lambda Control 1 1222
This code is stored when the DME detects excessive deviations in the air-fuel mixture (too rich or too lean) for longer than 10 seconds. Possible causes: Fuel tank ran empty, Incorrect Fuel Pressure, Injector valve defective or coked, Engine Temperature Sensor defective, Secondary air leak, Fuel evaporation control system defective, Air Flow Meter defective and/or the combustion is being disturbed by mechanical failure (Spark plugs,, compression, intake/exhaust valves, ...etc.) I would look at the 02 sensor first.. disconnect the o2 sensor at the plug when the car is cold. start the car and warm it up. if the problem doesnt return, o2 sensor bad. o2 sensor is bypassed until operating temperature is reached. Then double check for vacuum leaks for the umpteenth time.. Does CEL go away when you blip the throttle? No fuel leaks? Is your evap system for the fuel tank breathing properly? Are all the gaskets on the intake manifold seated proper? Not Sure? Pull/push gently on intake manifold.. look/listen for idle RPM changes.. Idle Control Valve? Throttle Position Sensor? stab in the dark: engine temp sensor..
#121
THANK YOU!!
![]() Ill try the o2 sensor first. I just checked all my vacuum hoses again yesterday and insured that none are leaking or are pinched. yes if i rev it past 1-1.5k it truns right off, it comes on when i stay at any rmp for 10-15 seconds but goes away if the rpms drop or rise. No fuel leaks that i can tell and ive spent quite a bit of time under the car so i assuem i would have noticed. Idle control valve has been cleaned and if it is unpluged the car will die. Is your evap system for the fuel tank breathing properly? Are all the gaskets on the intake manifold seated proper? Not Sure? Pull/push gently on intake manifold.. look/listen for idle RPM changes.. Throttle Position Sensor? ^^ for all that stuff i have absoluty no clue
#122
Inspect, check, clean, the throttle position sensor on the side of the throttle body. Inspect, check, and find out if your intake manifold is leaking. Check engine temp sensor also.. If it works.. you'll know. There is a tiny hose on the fuel pressure regulator that tends to crack over time. It attaches to the under side of the intake manifold and its very possible a leak in that tube would not be detected. Vacuum check.. -intake boot to valve cover -intake boot to ICV -ICV to manifold -manifold to FPR -manifold to brake booster -TB to charcoal canister
Vacuum check..
-intake boot to valve cover (done) -intake boot to ICV (done) -ICV to manifold -manifold to FPR (done) -manifold to brake booster (done) -TB to charcoal canister (done) There is a tiny hose on the fuel pressure regulator that tends to crack over time. It attaches to the under side of the intake manifold and its very possible a leak in that tube would not be detected. ( if this is the one the runs from under the throttle body to down by the drive side wheel well, its been replaced and it was a pain in the ass to do so) Inspect, check, clean, the throttle position sensor on the side of the throttle body. (the throttle position sensor has been cleaned as has the inside of the throttle body and passages.) Inspect, check, and find out if your intake manifold is leaking. once my engine is cool, i will yank the crap outa that thing
#124
i unplugged the oxygen sensor, let it warm up, and then took it on a drive to alburtsons, not a long drive but a few miles and enough that the light would have normally come on. it did not come on at all.
does this mean the o2 sensor is bad? the only difference in the drive was the idle did not always drop down as low.
#125
I would say 02 sensor is suspect.
Check it, swap it, see if issue returns.
