EML & DSC light came on during hard acceleration
hello guys,
Started my 2000 328ci today everything was normal. I let it warm up for about a minute then accelerated quickly, the EML and DSC lights came on. The lights were on for maybe 15 seconds and then went off. I recently changed all my brakes and deleted my muffler about 3 weeks ago. Any ideas as to why this happened? Has anyone else experienced this problem? I read a little on the issue but their are many explanations: O2 sensors, mass airflow sensor, a camshaft position sensor, bad cat converter, etc. debating on getting codes read Any advice would be appreciated! Thanks |
You`ll never know WHAT it is until you get the codes scanned....
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Your DSC light will flicker when the system is engaged. Quick acceleration with wheel slippage will cause this.
The EML light, according to the owner manual: "There is a fault in the electronic engine-management system. You can continue to drive with reduced engine output or engine speed. Please have the system inspected at your BMW Center." If you got a Check Engine light (picture of an engine) then it could be any number of other things. These codes can be read by most code readers. I am not sure about the EML codes however.
Jeff R. Golden Gate Chapter BMW CCA - Autocross - Come Join Us! ![]() "You drive like old people $#@%... slow and sloppy!" - George Carlin |
OP, scan for codes, you should have some. |
| Tags |
| ds, eml |
