Old 07-03-2012, 03:27 AM
collardgreens's Avatar
collardgreens collardgreens is offline
Mein Auto: 01 540/6
torque angles
according to TIS, the torque specs for the m62 vibration dampner are 100nm then 60* torque angle. Another 60* torque angle then 30* torque angle.
Is this right? Do I torque it to 60 degrees, release then re-torque to 60 degrees?
I was thinking about getting an electronic torque wrench with angle. gearwrench makes one.
Old 07-03-2012, 04:07 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
First tighten the bolt to 100nm then continue an additional 60+30 =90 degrees.
What i did was tighten to 100nm then mark the bolt at 12 o'clock and then mark the case at 3 o'clock. Turn the bolt until it lines up at 3 o'clock and theres your additional 90 degrees. Bmw actually makes a magnet that has the degrees but its just one more rediculious special tool that you can get around buying by being smart.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 07-03-2012, 04:44 AM
Mein Auto: 01 540/6
So 60 plus 30, got it.
I should disregard the extra 60 the Tis mentions?
Old 07-03-2012, 04:45 AM
WDRAcing WDRAcing is offline
Mein Auto: 99 540iA
Just curious, is this bolt a one time use stretch to torque type?
Old 07-03-2012, 04:52 AM
Mein Auto: 01 540/6
The parts guy at the dealer said no but i can't take his word for it since he said there are no stretch bolts on the e39. I know the main crank bolt is.
I was under the assumption that if it required torque angles it might be a strectch bolt.
Old 07-03-2012, 05:28 AM
pshovest pshovest is online now
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
BMW uses the angle tightening method for both stretch and non-stretch bolts.
Angle tightening removes the effects of thread & bolt head friction, which interferes with torque measurement. It's also MUCH easier to tighten to an angle then to find a 450 ftlb torque wrench that's only accurate to +/- 15%.
Originally Posted by collardgreens View Post
.........I was under the assumption that if it required torque angles it might be a strectch bolt.
Old 07-03-2012, 05:57 AM
Topaz540i's Avatar
Agnostic Priest
Sorry i forgot what the spec is for the angle. Do the whole thing that it states. I beleive the reason e book divides the angle up in pieces is because the bmw angle gauge doesnt turn that far in one shot. 60+60+30=150 which is the same as from 12 to 5 i believe.
The guy is wrong. The e39 uses alot of stretch bolts and i know this for a fact because i have worked on most of them. There are 16 in the wheel bearings alone. Yes the crank bolt is one time use. Last thing you want to do is snap the head off when reinstalling to the superhuman torque specification.
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 07-03-2012, 09:57 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
FWIW, the TIS specifies to replace the bolt.
