Camber help - Bimmerfest - BMW Forums
Old 07-02-2012, 04:07 PM
brewder brewder is offline
Mein Auto: 2011 328i xDrive
Camber help
Hello,
I had some new shoes mounted on the X3 today and my indy told me I really needed an alignment. Well, I got the X back, and when viewed from behind, it sure seems like there is a LOT of negative camber on the rear tires. I didn't take a picture of the car, but I do have the alignment before/after reports and was curious if someone here could take a look and offer any suggestions.
In reading the reports, of which I am NOT an expert, it seems like the settings are "in range".. But with such a negative camber, it sure seems like i'm going to see a lot of wear on the inside of the tire.
Thoughts/Suggestions for me??
//Brew...KCCO
('11 E92 328i xDrive - Deep Sea Blue | '07 E92 328xi - Space Gray)
Old 07-02-2012, 09:37 PM
Ishniknork's Avatar
Ishniknork Ishniknork is offline
I hate doing dishes
Mein Auto: '05 X3 3.0i
No expert here either but it looks like the "After" specs are more in line with what they should be. Some of the "Before" specs were definitely off.
Don't worry about the seemingly excessive negative camber on the rear wheels, it's normal. As long as the camber, toe and thrust angle are correct there shouldn't be a problem. Wear on my 2005's rear tires has been pretty darn even across the tread pattern all the way down to the wear bars. (Front ones too) I'm on my second set of replacement tires now and have never had or needed an alignment.
'05 X3 3.0i Alpine White/Gray Leather/Alum. Trim
Sport/Steptronic/Servotronic/Panoramic
Premium Sound/Staggered Style 114 18"ers
Old 07-03-2012, 10:25 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Those are 100% acceptable alignment numbers in my experience.
Almost identical to the numbers on our 2004 X3 with 132,000 miles on it now.
We haven't had any negative experiences with abnormal tire wear.
Alignments are the only reason I visit the local BMW dealer.
Old 07-03-2012, 10:39 AM
Thanks to all for the feedback. My indy has a new "alignment machine" which is part of the reason I posted this... the other was that visually, nothing looks any different. But I'm going to ignore what I "see" and put my faith in the forum and the numbers! Thanks everyone!
Ps... if you need an reputable indy for Audi/BMW work, I highly recommend Berhard's here in the Lehigh Valley area of PA...
//Brew...KCCO
Old 07-03-2012, 10:53 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Normal. -2.0 deg right at the middle of the range. (-1.8 <--> -2.3)
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
