ABS Module is bad - Bimmerfest - BMW Forums
Old 07-03-2012, 11:15 AM
Dan335i Dan335i is offline
Mein Auto: 08 335i
ABS Module is bad
Newbie here. Just took my 08 335i to a local mechanic because all of the ABS dash lights came on after a hard brake. He told me the ABS module was bad and quoted me $900.00 for the complete job. Not sure if that is a good price or not. Can someone recommend a good mechanic in the Tampa bay area that I could get another opinion. Thank you for your help.
Old 07-03-2012, 11:21 AM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
That's a good price. I believe there is a cheaper ($250 ?) method if you're willing to DIY. Pull the module, send it out for re-build, and replace. Can't remember the search terms...
Old 07-03-2012, 12:03 PM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
I can't help you with the recommendation but I think a second opinion is in order. Seems odd it would fail right after a hard brake.
Old 07-03-2012, 03:51 PM
90rr 90rr is offline
Mein Auto: 2013 335i M-sport
bmw dealership quoted me around $1200- $1400 for part installation and programing. I got help from fellow member on this forum, he paid 350 for refurbished part and 100 for instalation and programing. I can pm you a link for pump.
let me know
http://www.i35.photobucket.com/albums/d159/novak223/335i/222222_zpsxxm9xpwu.jpg
Old 07-05-2012, 05:52 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
I have seen it many times in other cars. One of the the piston in the pumps freezes.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 07-05-2012, 06:58 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Not agreeing that the OP needs a module, but this is one of the best companies rebuilding them; BBA, Taunton MA, 866-573-2740 toll free. Never had a bad job from them.
My personal opinion; get a second opinion if you have not been using this garage long enough to have an established relationship. (If you pop the ABS motor fuse you'll light up your dashboard. Fuses sometimes fail on a one shot basis due to the ABS pump not having operated in a long time. Don't want to second guess the garage, they had the job in the shop and may be correct in the diagnosis.)
Old 07-05-2012, 08:31 AM
Mein Auto: 08 335i
Thank you all for your help. I did get another quote on Tuesday. They came to the same conclusion it is a bad module as well quoted me $815.00 out the door. Just sucks that this is become a common problem and BMW does not have a recall on it.
Old 07-05-2012, 08:46 AM
Thanks for coming up with that name. Your brain is more tuned to this stuff than a dilettante like me.
Two things come to mind (regarding the price). 1) This is partly a result of BMW NA deciding to not fix/rebuild things that break, but to just replace them with new/reconditioned parts (transmission for instance.) 2) Be glad you don't have an NSX. My pump/valving went at around 50K miles, but the dealership/Acura decided to do a goodwill repair since I had had the brake fluid changed at the dealer every 15K miles as suggested. The part alone was $2500.
Old 07-05-2012, 09:02 AM
DSXMachina's Avatar
Bimmerdex 7.4!
I have that company on speed dial.
ABS modules are very complex pieces of machinery and how much can be done depends on the design. Some have sub-modules for the electronics, the motor/pump, and the valves. Those are the ones which can usually be selectively rebuilt depending on where the work is needed. As a result cost is lower.
In my experience, properly rebuilt units are as good as or better than the originals since the failure prone parts are replaced with modified (improved) parts.
Old 07-15-2012, 06:00 PM
Southwest Southwest is offline
Mein Auto: 2007 328i sports wagon
I have the same yellow "idiots lights" on my dash. I called my independent mechanic and they suggested my car needs a new ABS module and the part is $900. They said sometimes the warning lights are false and they will go away, only to reappear again, and so on. I'm supposed to drive it for a couple of weeks and see what happens. Of course watch out coming around a corner with water, etc.
Old 07-17-2012, 10:25 AM
htownres htownres is offline
Mein Auto: e90 328i
Almost same thing
My car 2008 with 15k miles had the DSC hydro unit go. Not sure if it's the same or related to the ABS pump, but I still think these are breaking awfully early. My dealer had to swamp pump, flush brake fluid/clutch slave, then reprogram the entire car. Took the whole day and cost the better part of $1k. I was told the pump was replaced with a better design from Continental/Teves, so I'm hoping they got it right with version #2. I figured by the time I find an indy shop and add it up, I won't save that much and the dealer installed part came with a 2 year warranty.
fingers crossed...
Old 09-13-2012, 09:05 AM
goinsurfin goinsurfin is offline
Mein Auto: 2007 530i
I'm hoping this is the same issue, but for a 08 328i, the ABS light is also on.
The local bmw indy shop said its the ABS hydraulic pump motor that needs replacement. Was quoted $2700ish for the part, any programing, plus labor. In South Florida. If this is the same issue, obviously i was quoted something crazy. I'm not in a position to DIY this so can anyone from S. FL recommend another shop to quote this again?
PLUS, the check engine light is on and was told its a "camshaft sensor intake" quoted $210. Is this a reasonable price?
Thanks huge!
07 530i
Old 09-13-2012, 10:15 AM
slant83 slant83 is offline
Mein Auto: 2007 Porsche Boxster S
Thanks huge!
...cheaper at the dealer...$1200 range
2013 X5
Old 09-13-2012, 11:12 AM
Yes.
Old 09-13-2012, 11:56 AM
Oh yeah? I'm in Miami. Which dealer are you referring to and do you know if that price includes labor or is it separate? I really appreciate the feedback.
This guidance is another reason why both the BMW and Land Rover communities are special! We look out for each other! Thanks!
07 530i
Yes.
Thank you!
07 530i
Old 09-14-2012, 11:19 AM
Thanks huge!
check your PM
Old 02-04-2013, 09:12 AM
ATI ATI is offline
Mein Auto: BMW 328i 2007
Hi all, someone used the ABS installed? I bought for my BMW 328 2007, but the dealer refused to program ABS, bought new for $ 410 on ECStyuning. What to do with used. Somebody reprogrammed?
Old 02-04-2013, 09:53 AM
Banned
Mein Auto: 2007-335 HTC
on a side note if you have the ABS module out, replace the vacuum booster gasket and check valve, easier to do with all that removed, ( a known problem is the brake booster vacuum leaks down over night resulting in a hard brake peddle in the morning or first start caused by leaking check valve and or bad grommet
Hondo
Old 06-05-2013, 03:21 AM
aba030 aba030 is offline
Mein Auto: 2008 328i E93
It turns out I also need to get a new ABS module for my 2008 E93. A new part from BMW retails for roughly $2,700, but it's available from Tischer for roughly $2,100. My 3rd party extended warranty is covering the part and some labor (2.5 hours), but the dealer is saying the job requires 5 hours to complete (need to bleed the brakes). Does the 5 hour quote seem reasonable?
328i E93 (ED - Nov. 2007) - Space Grey w/ Black Leather, Automatic, Premium, Navigation, iPod, Heated Seats, Comfort Access, HD Radio
Old 06-05-2013, 03:29 PM
ATI ATI is offline
Abs
I bought a new on ecs tuning- $410, replaced myself and programming on BMW -$120. Total $530
Old 06-05-2013, 07:18 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
If you have some free time, cut open the old ABS module and look at the solder joints. On the E46s, the modules would fail because the joints would break. Simply retouch all the connectors with a soldering gun and that should fix the issue.
Old 06-05-2013, 10:56 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Not certain, but I believe the E9x modules are gel encapsulated which makes your fix near impossible.
Old 10-04-2013, 08:20 AM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 17Outback
Faults 5DF0 and 5DF1: ABS Pump and Control Unit
This is the first code that my 2007 E93 has thrown.
As an update to those that will run into this problem note that there are two part numbers for this system, one for the early 2007 models up to around 9/2007 (verify this with your VIN) and the other for later 2007 on.
PNs are
34506777160 early 2007's
34506777164 later 2007's on
Here is a DIY for those so inclined (like me)
http://www.e90post.com/forums/showthread.php?t=600491
One member there sent his pump and distributor assembly out to a place in England for a rebuild.
DSX has provided a local US company that can do the rebuilds. I plan to keep my pump and distributor and send it off to the company he recommended so I have a spare. I purchased the system from this location, a BMW dealer in Minn. This was the cheapest system I could locate even checking ESC and Tischer
BMW OF MINNETONKA
wlais@bmwofminnetonka.com
No point in doing a DIY since I plan to follow the one posted above.
Just trying to add to the thread with part numbers and the DIY. Seems this isn't all that expensive for labor based on what I have seen when researching this. Part is still 1000 bucks plus or minus.
Also I plan to remove my control module and install that on the new pump and distributor since it is already programmed and then brake bleed and do some ABS pulsing to purge any air out of that unit.
Hope this helps someone else that has this problem. By the way I reset the codes and they didn't come back for a few driving cycles but are back now so most likely as said before a piston in the distribution block must be sticking speculating here...
Old 10-04-2013, 01:33 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
$900 is a bargain
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
