Old 07-03-2012, 10:29 AM
bitsnibblebytes bitsnibblebytes is offline
Mein Auto: 2001 525i
Outside Temperature Sensor - Where is it ?
I have 2001 E39 525i. The temperature as shown on the dash/miles indicator is always wrong. When it is 85F outside it shows -10F. It affect the way the auto AC works. Where is this sensor located and is this something I can replace? Please suggest me any online shop I can order it from. Thanks.
Old 07-03-2012, 10:39 AM
Albo's Avatar
Albo Albo is offline
Der ursprünglich....Albo
Mein Auto: OO=[][]=OO
Passenger side front wheel well just aft of the bumper. The liner contains a molded bracket that holds the sensor....this often breaks with time, heat or impact.
Liner:
Use this DIY:
http://haferman.org/bmw/
Want to learn about your E39 5 Series?
Click Me
2003 530iA - Mumbo Jumbo *E39 in Sig is Not My Car
Originally Posted by edjack View Post
If you don't want to do nothing, you must want to do something.
Old 07-03-2012, 11:10 AM
Thanks. The link is quite descriptive. I will give it a try. Any recommendation where to buy the sensor and parts?
Old 07-03-2012, 11:19 AM
Mein Auto: 01 525i, 01 X5, 91 Z32TT
go here for part number http://www.realoem.com/bmw/
then go here to shop http://furiousmethod.com/
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 07-03-2012, 11:32 AM
Krafty530 Krafty530 is offline
Mein Auto: 2003 530
Easy to replace on the car. They sell on eBay for around $16 and are easy to install. They are shaped like a long cone. This will enable the max air to work as well.
Old 07-03-2012, 03:03 PM
L0F L0F is offline
Mein Auto: 3/98 528i
The wiring for the sensor also is prone to damage, and many times the actual sensor is still good just the wiring that ****s up.
Old 07-03-2012, 08:53 PM
seemyad's Avatar
seemyad seemyad is offline
BMW ****ie
Mein Auto: 530i Sport Package
+1
Do a visual inspection for corrosion in the connector.
If you have a meter check your wires to chassis ground. Do DC voltage to ground first. If that reads zero then check ohms to ground.
I imagine the sensor is a thermistor of some sort.
Old 07-04-2012, 01:46 AM
Go to the bestlinks and thread search for "ambient" & you'll find, among others:
- Ambient temperature sensor breaking
To re-locate, see cn90's DIY:
AMBIENT TEMP SENSOR HIDING PLACE:
http://forums.bimmerforums.com/forum....php?t=1418124
