Old 04-05-2010, 09:44 AM
casacujo casacujo is offline
Mein Auto: 2002 525i
Locating the 2002 525i fuel filter
I need someone who have experienced replacing the fuel filter for 2002 525i..to tell me where it's located.. can't find it by looking under the car. Thanks
Old 04-05-2010, 09:48 AM
aa240sx's Avatar
aa240sx aa240sx is offline
Mein Auto: 2001 BMW 530I
It's there. It's on the driver's side under the car and under a plastic cover that will require you to remove about 4-5 screws. Take my advice on this one. Mark with a sharpie your in/out lines and don't get them crossed up.
good luck
- 2008 R350 Mercedes Wagon
- 2003 M3 Coupe - Alpine SMG
- 2001 530i - 5 speed, Anthracite Metallic, Sport Package
Old 04-05-2010, 09:50 AM
cn90 cn90 is online now
Under the chassis, your Left Butt area.
Remove the Plastic Cover, you will see it.
Take note, diagram, take pic so you don't mess it up.
Old 04-05-2010, 10:07 AM
Thanks for your help. I got a few suggestions of where the fuel filter is located, and this one is from pelicanparts.com..I just don't want to pull the back seat out trying to locate the fuel filter.
jared Fenton from pelicanparts.com
I'm pretty sure that the fuel filter is located in the fuel tank, integrated with the fuel pump. You would need to remove the rear lower seat to access the covers \.
Old 04-05-2010, 11:18 AM
cegeste cegeste is offline
Chronic BMW User
Mein Auto: 650i Gran Coupé,E28 M535i
M5Board has a good DIY at http://www.m5board.com/vbulletin/e39...placement.html
The filter is slightly different, but process should be essentially the same.
Old 04-05-2010, 06:39 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
http://www.bimmerfest.com/forums/sho...d.php?t=182047 <-Good resource. It's not dangerous; learn from his mistakes. Do it outside if you can.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 03-18-2012, 07:53 AM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
I just did mine, and took lots of pics. Here is my detailed write-up:
http://www.bimmerfest.com/forums/sho...t=#post6709199
Old 03-18-2012, 08:14 AM
morrisroad's Avatar
morrisroad morrisroad is offline
Mein Auto: BMW 530
And here also...http://www.bimmerfest.com/forums/sho...459&highlight=
MorrisRoad
Old 03-18-2012, 08:40 AM
speedninja speedninja is offline
Big Body Speed
Mein Auto: 01 525i, 09 328x coupe
could the fuel filter be the reason why the car doesnt start .....
Old 03-18-2012, 10:02 AM
Old 07-04-2012, 01:52 AM
For the crosslinked record, this was posted today:
> E39 (1997 - 2003) > Fuel Filter DIY - Post-Mortem Examination and Observations
Originally Posted by Bimmer Remorse View Post
I recently replaced my e39 1997 528i fuel filter at about 120k (I think this is the first change). Check out post-mortem pictures. Other observations:
1. It may be my imagination but I noticed an immediate improvement in engine performance--just sounded better
2. The first fuel refill, post replacement, revealed a three mpg improvement (no change in driving habits/trips)
3. I am only at "1 wrench" skill level but this was a fairly easy DIY--90 minute job max
4. Besides the fuel filter, I only ordered replacement clamps. However, I would recommend ordering new expanding rivets and the c-clip, some were damaged when removing the access panel. My hoses were in good shape but probably better to order replacements too.
5. With engine off and fuse removed--I was unpleasantly surprised that the fuel was still under high pressure when disconnecting hose from filter . I recommend vice grips, to clamp the hose, and wearing goggles.
6. For a budding DIYer, it really is satisfying to complete this job myself--this forum has been indispensable.
Comments are welcomed.
