E28 (1982 - 1988)
Replacement Alternator Pulley
Do any of you know where I can find a replacement alternator pulley for our 84 528e?
I can find all the alternators I want with and without the pulley but no luck yet on just the pulley. Maybe someone has bought an aftermarket one that worked? The belt is going to deep in ours and it will slip and squeal in a heartbeat. The new belt fits correct in the main drive pulley along with the other two belts for the AC and power steering. Thanks
Powder Coating It @ Dad's Garage |
Could it be the belt? or maybe you not tightening enough. I have an extra alt, but I would only sell it with the pulley. or the bushings might need replaced.
Andy Last edited by south26; 07-03-2012 at 03:58 PM. |
New bushing might be the ticket. The alt as for as I know is the org and you can see they are not what they used to be. Now to pick the correct ones??? I did go on one site and they listed the OEM ones and then the newer type but heck they showed like 5 or more of the newer ones??? The problem is I have run out of adjustment. And you can look and see that the alt is being pulled out of line so bushing would be the cause. A few years back I did do a red neck fix on the adjustment by adding a bolt and a nut that connected to the pump below. heck it works I decided to tighten the nut up today and got the belt like it should be and then fired it up and no high pitch squeal. But I think I am hearing bearing noise![]() Might need your alt after all if the price is right??????? I did install a new regulator in this one the first of the year. PM or contact me through my site on a price and info on your spare alt. I just might need it. The wife Love's this car so much that spare parts is something I try to keep handy and thank goodness I have a shop and tools because I have paid one time to have something fixed at a dealer and NEVER AGAIN $100 for a distributor cap!!!! Thanks
Hi in the 48 in can do 40 shipped. It is out of a 84 528. Looks good and worked well.
Andy |
Sounds like a deal to me. I know that one of these days this will fail and might be real soon. Even after I replaced the regulator in it you still might have to hit the gas a few times to get it to charge and sometimes it comes alive like it should. So consider it SOLD. Thanks I have another problem I need to chase down also. So I am going to check all the stuff out the guy told me to check. I had done this before a long time ago. But sure is hard to fix something when it works fine until you get every thing hot for a while and then you have to work on a hot motor ![]() take a look and see if you might have a suggestion. http://www.bimmerfest.com/forums/sho....php?p=6931741
