#26
Just curious, since we're trying to list all the sizes.
That 3.3 mm OD hard pipe doesn't have dimensions listed in the diagrams. Do you have any idea what the ID of that rigid curved vacuum pipe is? Note: Here is my hastily animated pic showing the 1/8" OD plastic pipe whose tip broke off when I removed the SAS valve 1/8" ID rubber hose: |
#27
WAY
so simple thing to make so complicated dealer sale ~5$ a piece which i used on 2 cars and still have some Last edited by champaign777; 11-06-2011 at 07:58 PM. |
#28
Let me get this straight. You bought all these vacuum hoses, tubes, pipes, & endcaps at the dealer, for just $5????? Quote:
#29
I'm having new struts and shocks installed, so my car is at a shop. I'll try to measure that pipe when I get the car back. When I replaced the hose from the SAP valve to the pipe, I cut the pipe instead of trying to remove the old hose. I just ran a little longer hose. The hose is strong enough to hold the vacuum without collapse, so I assume the pipe is there to ease routing.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
#30
Interesting. I had assumed the pipe was there because it practically touches the engine, so that it apparently handled heat better.
BTW, the reason I ask for dimensions is in keeping with the purpose of this thread - which is to find suppliers. It's especially important to find alternative sources because this simple heat-resistant straw pipe is a (nominal) $27.94 which is probably about $20 too high for what it is. Therefore, I asked because it's the start of the process of looking around for a second source. The fact it's curved, threw a kink (literally) in that pipe quest, but the goal remains the same to find a better quality less expensive replacement. For that, we need the dimensions to some level of accuracy. I assume the OD is essentially the same as the ID of the hoses so that would make the OD about 3.3mm (however I don't trust the realoem diagrams anymore so it could be 3.5mm or anything else). Last edited by bluebee; 11-07-2011 at 05:52 AM. |
#31
blue
i was talking about your topic Where to get M54 metric sized vacuum tubing at decent prices? not about ALL hoses which our BMW has Last edited by champaign777; 11-07-2011 at 06:41 AM. |
#32
this make this job very simple Last edited by champaign777; 11-07-2011 at 06:51 AM. |
#33
I was remiss in that I should report back that my year-long quest to locate the source(s) of a long-standing lean misfire condition (many codes) was resolved simply by replacing a few rubber hose/tubes/pipes/boots/caps & gaskets.
Specifically: a) I first replaced all the rubber tubes/hoses/pipes/plugs I could easily get to in the engine bay ... which immediately helped somewhat lessen the frequency of the lean-condition misfire codes ... - Where in the USA to get new vacuum tubing & vacuum caps (1) & what SAE sizes to get for all the metric M54 engine vacuum tubes, hoses, pipes, and caps (1) & correcting the F-connector errors in the realoem diagrams (1) & finding the ends of hard-to-locate vacuum tubes (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) b) I then ran a smoke test ... - How to make your own smoke machine (1) c) Which pinpointed a lower CCV vent hose leak ... - Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (1) d) I also unclogged the dipstick guide tube which was clogged solid (and perhaps was a reason for the CCV vent hose leak) ... - How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1) e) Lastly, I replaced the rubber boot which is connected to the ICV & TCV. Those simple steps resolved my lean condition misfires (sufficient to pass the California dynomometer smog test): - What you can expect for E39 smog emissions test results (1) BTW, while I rarely solve problems by replacing components without learning how to test them, I concur that one way to solve perplexing lean condition misfires, at this age of our bimmers, is to simply replace every vacuum-related rubber hose/tube/pipe/boot/cap/gasket in the engine bay.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 07-05-2012 at 10:24 PM. |
#34
| Tags |
| fuel / air mixutre, lean codes, misfire, vacuum hose |
