battery location? - Bimmerfest - BMW Forums
Old 07-01-2012, 03:48 PM
750lxi 750lxi is offline
Mein Auto: 750Li
battery location?
does anyone know where the battery is located in our cars, and how to access it?
it does not say in the manual.
Old 07-01-2012, 04:30 PM
bruno787 bruno787 is offline
Mein Auto: 740Li (F02)
its in the trunk, just remove the carpet
15 Maserati Quattroporte GTS
10 740Li (gone)
11 Mini John Cooper Works
12 Range Rover Evoque Dynamic Si4
Old 07-01-2012, 07:04 PM
Mein Auto: 750Li
thanks, but do you know how to remove the carpet?
it doesnt seem easy.
Old 07-02-2012, 12:20 AM
the-pm the-pm is offline
Mein Auto: 2011 BMW F01 730d M Sport
This bit is in the manual, it is under the parking brake section and shows you how to remove the carpet, there is tool in the tool kit to do it. You can see the battery in this post http://www.bimmerfest.com/forums/sho...32#post6928632
Old 07-02-2012, 07:10 AM
07X3platinum's Avatar
07X3platinum 07X3platinum is offline
Mein Auto: 2012 E550 Sedan
The batteries on most new BMWs, if not all, are located in the trunk for better weight balance.
"Money is freedom."
Old 07-02-2012, 08:17 AM
Mein Auto: 750Li
thanks a lot pm!
just looked up that section in the manual and all the info to remove the floor trim in the trunk is there!
Old 07-02-2012, 01:45 PM
No problem, why do you want to know anyway, general interest or do you have an issue?
Old 07-02-2012, 03:33 PM
Mein Auto: 750Li
wondering if disconnecting the battery will clear a fault that has registered...
Old 07-02-2012, 11:15 PM
Individual750LI's Avatar
Individual750LI Individual750LI is offline
BMW rocks!
Mein Auto: 2013 750I M
Anyone know how long the battery will last if parked? I will be on a biz trip for a month and don't wanna come back and have a dead battery.
2015 X6M, 2014 X1, 2015 Kia Sedona SX-Limited
Old 07-03-2012, 12:04 AM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
I use a trickle charger when I go out of town.
Old 07-03-2012, 12:20 AM
BMW rocks!
Thanks! Where do you buy one? Is it safe, I'm kind of concern about it would catch on fire?
Old 07-03-2012, 03:25 AM
Yup, it's safe. Dealers use tenders/ticklers on their cars all the time and keep logs, I actually found the log when I purchased my car.
Battery tenders are better because it's controlled, ticklers consistently stay on and can do damage to the battery over long periods of time. BMW actually sells a battery tender but the best you can buy is in the link below. Don't waste money buying the BMW one because it's a rebadged unit and you're basically paying for the "BMW" name.
http://batterytender.com/automotive.html
Old 07-03-2012, 05:53 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
I picked this one up from Sears - http://www.sears.com/shc/s/p_10153_1...0Chargersmv=rr
I used it for the first time over the weekend. Battery charge level was about 45%! My Mon-Fri commute is only 5 miles each way. After a long 2 hour highway, the battery went from about 58% to 95% through self charging.
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 07-03-2012, 01:17 PM
BMW rocks!
Cool, Thanks a lot guys! Already ordered one.
Old 07-04-2012, 06:07 AM
BMR2009's Avatar
BMR2009 BMR2009 is offline
Munchen bound
Mein Auto: Ferrari
Chris, do you use acccess in the trunk, or the posts under the front hood? I know you can boost from there, didn't know if you could trickle charge from there.
2016 750i, ordered 5.11.16, delivered 7.9.16, custom build.
2009 750Li 9.14.09 ED
Dropped in Munich on 9/28, Redelivered by ELEKTRA, delivered to my home 11/2.
Old 07-04-2012, 06:11 AM
I use the one under the hood - make sure you use the correct nut for grounding. It does come with the lighter attachment (never thought about the trunk), but the socket needs to be "hot" for it to charge the battery.
2016 Benz C300
Old 07-04-2012, 06:32 AM
I just put the charger on to see the charge level. 67%. And it was basically full 2 days ago. I had 2 days of short commutes. With the hybrid auto start, I think this car will degrade the battery pretty quickly (not covered under warranty). I think the tender has saved me a new battery.
2016 Benz C300
