E36 (1991 - 1999)
Old 07-04-2012, 09:19 AM
Sbla13 Sbla13 is offline
Mein Auto: 323i Convertible 99
Starts but won't idle
My 99 BMW 323i (E36) won't idle. I can start it, but if I take my foot off the accelerator, it stalls.
I am getting a mass airflow meter fault code, but replacing the MAF did not help, I still have that code, but no other fault codes are present. Disconnecting the MAF had no effect.
Old 07-04-2012, 09:21 AM
Dino1394's Avatar
Dino1394 Dino1394 is online now
bimmerfest Supporting Member
Mein Auto: 04 330xi
is the icv clean?
any vacuum leaks?
Old 07-04-2012, 09:31 AM
The car was running fine with no history of this problem. After replacing the rear brake pads, it wouldn't idle (the brake repair had nothing to do with this problem - I only unscrewed the brake fluid resivior cap under the hood).
I don't suspect any vacuum related problem due to the sudden onset of the problem.
If it were an ICV, wouldn't I get some additional fault code?
Also, why do I still have the MAF code (It has returned even after I clear it)?
Old 07-04-2012, 09:34 AM
tiger8mush tiger8mush is offline
Mein Auto: 1996 328is
Fuel pump? Fuel pressure regulator?
Old 07-04-2012, 09:39 AM
Car was running fine, and still does. The problem seems to be idle related. When I start it, it just turns over, fires up but never reaches full idle speed and quits. If I give it gas, it will start and run smooth.
Old 07-04-2012, 09:47 AM
Dino1394's Avatar
Mein Auto: 04 330xi
ehh not necessarily. If its dirty the little vane/door cant move and do its job. Its not a bad idea to clean it though. (free to do anyways)
also if cleaning the maf could do too (if not your maf could be bad since it threw a code)
unplug the maf and see if the car idles without it
Old 07-04-2012, 09:51 AM
I'll give the ICV cleaning a try. Any key cautions I should know of?
Old 07-04-2012, 09:55 AM
Dino1394's Avatar
Mein Auto: 04 330xi
just remember which hose goes where (theres one on each side)
I replaced the MAF but with or without the MAF connected, I still have the problem.
Old 07-04-2012, 09:57 AM
Dino1394's Avatar
Mein Auto: 04 330xi
yeah try cleaning maf and icv and see if it helps
http://www.bimmerforums.co.uk/forum/...ite-up-t41173/
Old 07-04-2012, 12:42 PM
The ICV was stuck. I cleaned it with MAF cleaner and the engine is idling fine.
I suspect that the ICV was altering intake airflow sufficiently to cause the MAF fault. I cleared the fault after the fix, and it did not return.
Thanks for your help!
idle, maf
