Discussion pertaining to the flagship BMW here. |
750 li coolant leak from small hole next to water pump
Hello everybody i have a 2006 750 li and i found i little hole next to water pump and leak from right there that means i have to replace the water pump
It sounds like the dreaded weep hole leak which is far worse. Search weep hole. You are very lucky to be in LA. All German Auto (methinks in LA County) has a fix that is superior to the flawed factory design and way less money than the dealer (less than $2K vs $10K from the dealer). Search All German Auto. is an AGA youtube link.
2008 750 Li Alpine White/Creme The economy will get worse before it gets worse. |
I thought the coolant pipe was no longer an issue in the 06-08 models
thanks i see on the video and i start working on the car and thanks for ur help Quote:
thanks for ur help
I'd say get some fluorescent coolant marker and let it run through the system if you want to pinpoint it yourself, but I've personally never done it on a closed radiator system or my current vehicle so I am unsure as to if it's safe to do that or not.
