E60 (2004 - 2010)
Old 07-04-2012, 11:14 PM
Revice Revice is offline
Mein Auto: 550i
Need new navigation cd!
I need a new navigation cd for my 2006 550i. It's the one that goes in the dash. Does anyone know where I can get one? Thanks
Old 07-05-2012, 03:59 AM
racooper3 racooper3 is offline
BMW Master Wannabe
Mein Auto: 2005 BMW 545i
I bought 2012 version of the disk at a dealer for $199. I believe some dealers will let you order/ship online too.
Old 07-05-2012, 06:17 AM
borderchris's Avatar
borderchris borderchris is offline
Ich liebe meine Funfers!
Mein Auto: 550i and E34 530i
A couple of issues here. First of all, a 2011-2012 disc will not work in your car unless you've had the iDrive updated to one of the last few versions. Make sure that it's not a brown menu screen. The newer versions have a grayish screen. Even then, you may have some issues due to different layering technology- I actually went back to my stock 2007 disc due to load issues, and returned the 2011 disc (took an act of god).
I'd check out ebay for an OEM BMW 2006-2007 disc- The presentation really looks about the same, and POIs didn't vastly improve. These can be had pretty cheaply, but make sure it's a reliable seller- There are a lot of fakes out there.
550i . Sport . Nav . L7 . Sirius . Cold . Eibachs . Bilsteins . 19" TSW . K&N . MTech V3
Old 07-05-2012, 06:37 AM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
I have a brown CCC screen and the 2012 disks work without a problem.
2008 535i Monaco Blue
PP, SP, SAT w/paddles, AS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Wood Trim,
Gray Dakota Leather
Of course you do. But you don't have a 2006. And that's where the issues lie (direct from BMW, BTW), fixed by the update.
Old 07-05-2012, 06:41 AM
legend700's Avatar
OK. The splash screen is brown, the menu screen is grayish.
Gray Dakota Leather
Old 07-05-2012, 08:53 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Did you get one of the latsest updates, or was it because it wasn't loading? I still use a 2007.1 disc because of this (the same mapping and poi info). I do have they greyish screen, but a 2009 disc didn't read after an update due to a Sirius module. You would think an update would fix (almost) everything.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 07-05-2012, 10:09 AM
Mike Swing Mike Swing is offline
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2007 BMW 530i
This is interesting. I have a 2007 and I just got some 2011 DVD's via eBay. I hope they work.
Mike Swing
Old 07-05-2012, 10:18 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
Lets us know if it works for you
BMW CCA Member, Capital Chapter
Old 07-05-2012, 01:39 PM
Even after I got the update, the 2011 disc worked, but intermittently. As in... 1 out of 10 starts it would freeze (in nav load) and tell me to insert the disc. And I have the absolute (1/2012) latest updates for the CCC and car. I've had no issues at all with the original disc, pre- and post-update. Odd.
Old 07-05-2012, 07:34 PM
BMW Master Wannabe
A couple of issues here. First of all, a 2011-2012 disc will not work in your car unless you've had the iDrive updated to one of the last few versions. Make sure that it's not a brown menu screen. The newer versions have a grayish screen. Even then, you may have some issues due to different layering technology...
Actually the Navteq 2012 DVD Pro disk works just fine in my 2005 545. I don't have any issues with the DVD. I think you should get your VIN number and call dealer to ask for the price and part number. There are a couple of versions of the disks, depending on the setup you have in your car. Buying it from ebay is risky.
Old 07-09-2012, 06:24 PM
Mike Swing
Update. Received the professional 2011 2 disc set today. I need the west coast dvd and of course it doesn't work. Both dvd's are OEM with a reciept from January 2011. When I insert the west coast dvd, it says 'Please insert Navigation DVD' or it will say that it can't read the disc/ disc error. Sometimes it'll say, 'New DVD version. Please shut down system and restart after 5 minutes. I wait at least 10 minutes and still no go. The dvd looks pretty good. The east coast version works but is useless since I live in Tx. Any ideas guys? Anyone out there got a 2011 west coast they wanna trade? Thanks in advance.
Mike Swing
Old 07-12-2012, 06:56 AM
Mike Swing
Anyone?
Mike Swing
Old 07-30-2012, 11:41 AM
mikeignasiak mikeignasiak is offline
Mein Auto: 2006 M5
I recently purchased the 2012 Nav discs for my 2006 M5 from user lmm1005 on ebay - searched for BMW Navigation System Update - only paid $60. I strongly suspect they are not actual BMW OEM, however, they have performed flawlessly.
Old 07-30-2012, 03:31 PM
jim165 jim165 is offline
Mein Auto: 2008 BMW 550i Sport
Mike,
I think you'll have problems with that disc as stated at the top of this thread. Your firmware is probably too old to read that disc. You'll either need to get a firmware update or find a 2007 or older disc. I purchased an OEM 2009.1 disc from Ebay and my car has issues reading it. From what I understand, there were problems with the data on the 2009 discs. I'm not totally sure if it's just the drive itself dying or if the double layer format is causing read issues. My drive will read the disc with no problem initially, but if I have the assist window set for a map without navigation active, it'll stop tracking me and turn off after about 20 minutes. If I have the navigation running, it'll run without problems until I'm finished using it.
2008 550i Sport
Space Gray, Black Dakota, Bamboo Anthracite
SAT, Sat, Shades, Cold Wthr, Comf Access, Nav,L7, PDC, LUX V3 AEs, BMW Perf. Grilles, HID fogs, ACS Roof Spoiler, M5 Lip Spoiler, RPI GT Exhaust
Others:
2006 Corvette Conv, Z51,6sp (wife)
2007 Honda CBR1000RR
2005 Triumph Daytona 650 (wife)
Old 07-30-2012, 07:34 PM
Mike Swing
I'm going to test the dvds in a friends BMW soon.
Mike Swing
Old 08-19-2012, 04:09 PM
joe23mike joe23mike is offline
Mein Auto: 528i
please post if it worked or not.
Old 08-20-2012, 07:10 AM
Mike Swing
I stil haven't had the chance to meet with my two friends who have BMW's with Nav. Hopefully something positive will happen. If not, I'll sell the Nav DVD for what I paid for them.
Mike Swing
Old 08-23-2012, 07:58 PM
DBSonic74 DBSonic74 is offline
Mein Auto: 2006 530xi, 2005 X3
I was looking for a recent disk also. Glad I found this thread.
cd, navigation
