Old 07-04-2012, 07:00 PM
mjgood mjgood is offline
Mein Auto: 2011 550i M-Sport
Just took a look at mine.... F-10 550i M-Sport
Wert_02, Werte=02
attached the CAFD.... added .pdf to get it to upload
File Type: pdf CAFD_00000721_001_000_023.ncd.pdf (456 Bytes, 413 views)
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 07-04-2012, 07:07 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
@JEG23; Thanks for chiming in. Your default settings seem to confirm that Dinan changed Stealth.Pilot's settings from the default. Unfortunately, it's not an easy thing to test if changing yours to Wert_02 removes the limiter.
Old 07-04-2012, 07:09 PM
Wert_02, Werte=02
Malcolm, is yours stock of Dinan tuned?
Old 07-04-2012, 09:09 PM
Stealth.Pilot's Avatar
The Driver
Mein Auto: 2014 M5
Shawn - there are 3 speed limit configurations on the 550i:
1) 200kmh - Stock 550i
2) 250kmh - 550i M-Sport
3) Unlimited - 550i Dinan
It is possible Wert_02 is the M-Sport setting and not the unlimited setting. I am curious whether MJGood has a Dinan or just an M-Sport. Mine is M-Sport and Dinan.
If Wert_02 raises the limit to 250, then it would suggest that maybe Dinan is delimiting the car somewhere else or perhaps their software overrides the car's software.
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 07-04-2012, 09:21 PM
As far as I know my car does not have Dinan, I'm the 2nd owner and bought the car with 7000 miles on it from the dealer... I don't trust Texas roads or TX police to test the car for top speed... :-)
I'm guessing there would be some kind of Dinan identifier on the car if is was tuned?
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 07-04-2012, 10:16 PM
The Driver
Mein Auto: 2014 M5
No identifier. But if your 0-60 times are in low 4 second range instead of 5 second flat, then you have Dinan. If your wheels spin under full throttle you have Dinan.
Sold:
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 07-05-2012, 04:35 AM
Looking through the FA for my car I find 337 (M Sports Package), I also see 840 (High Speed Tuning)... doing a quick google, I found this... http://x3.xbimmers.com/forums/showthread.php?t=590503
It looks like option 840 is the bump to get 250 kmh...
I wonder when @nasmo added 7ME to the VO maybe he had 840 in there as well? the lower may take precedence....
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 07-05-2012, 04:46 AM
I'll give it a try today... It will be good to know what my 0-60 time is... I've never had the tires spin, got them to break loose (was doing about 30mph, then gave it full throttle) then the car has a fit, guess I need to turn off traction control somehow...
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 07-05-2012, 04:57 AM
Well, that is what I suspected too after Malcolm reported his was Wert_02, that this was the M-Sport Setting, not Dinan. I just checked the FA on my 535i M-Sport, and I too have SA 337 and SA 840. For now, I don't know. I am sure the factory VMAX is the difference between 200 kmh and 250 kmh, but I am not sure how Dinan is overriding VMAX.
Old 07-05-2012, 04:58 AM
That is a very good point. He may need to remove 840 and add 7ME.
Old 07-05-2012, 05:28 AM
@Losco; Just curious, but do you have SA 840 in your FA?
Old 07-05-2012, 09:50 AM
Just confirmed my car does not have Dinan... 5.3 was what I got, might have been a bit less, was trying to keep an eye on the speedo and road and timer....
2011 550i M-Sport
2011 Countryman S
Bell 407
Old 07-05-2012, 11:18 AM
nasmo nasmo is offline
Mein Auto: M5 F10
Sorry no 840 option in my car, these are all SALAPA elements included:
  • 1CA,1CC,1CD,223,245,248,2MK,2NZ,2PA,2VB,302,316,31 9,320,322,323,358,3AG,403,415,416,423,428,430,431, 441,453,464,465,488,494,496,4L9,4M8,4MA,4NB,4UR,50 2,508,522,524,548,575,5AC,601,609,610,612,614,615, 616,620,633,654,677,696,698,6AA,6AB,6FH,6FL,6NF,6N R,6VC,754,760,761,776,7ME,850,868,877,886,887,8KA, 8S2,8S3,8SM,8TF,8TG,8TH,8TN,
    8V1
Last night I kept searching without any luck, think I . we need someone pointing us in the right direction. (a tuner perhaps)
Old 07-06-2012, 04:17 AM
Losco Losco is offline
Mein Auto: 2010 528i M-Sport
I just checked, no 840. btw my car's M-sport.
Old 07-08-2012, 12:14 PM
Ray_S Ray_S is offline
Mein Auto: M550dX
If I compare the coding options I guess Dinan re-flashed the DME, it does not look like we can disable the speed limiter w/ coding.. I also have a different menu - pull-down for VMAX with all kinds of values up to 255 (default in Germany), even with my latest M550dX model.... but still, I will also test adding 7ME - not putting much hope on it..
Werte_02 looks to me like a flashed software..
At least for Germany there are some rumours of 7ME becoming availble in the future also for M-Performance models, not just for M5, but not sure this will become true..
_________________________________
BMW 330d xDrive touring w/ M PPK (F31)
Porsche 996 turbo Cab
Old 08-16-2012, 03:28 AM
mtec mtec is offline
Mein Auto: 320D F30
@shawnsheridan
Hi, i have a new f30 320d not the Best but Ok ;-)
i use esys an now i want to code my VMAX Setting... i found a Setting in Module
http://www.bimmerfest.com/forums/att...9&d=1341186808
But i cant Write a anather Value ?! 240 kmh ... when i write a anathe value the car every show the 240 ...
what is the trick.. ?! :-)
THX a Lot for your Time
Kind Rega. Marcel
Old 08-16-2012, 01:33 PM
Originally Posted by mtec View Post
@shawnsheridan
Kind Rega. Marcel
What are the last 7 characters of your BMW VIN #?
Old 08-17-2012, 03:09 AM
Mein Auto: 320D F30
hi, ihave a litle trouble with esy... it give me no connection to car at time...
i hope the last coding wars ok ;-)
i write shortly ...
Old 08-17-2012, 11:00 AM
Griffin 27 Griffin 27 is offline
Verified Trusted User
Mein Auto: 2012 535i, Space Grey
I just tried coding my 535 non M sport. It's limited to 130mph/210kph There is a pick list to change the speed and shows that it's coded successful, no errors. However, when I then check it, it defaults back to the old value, 210 and A4.
I'm bummed because I would like to get it up to 150mph at least, not necessarily remove the limiter entirely, although that would be great :-)
2012 535i, April build, Space Grey, Oyster Interior, 19" M sport rims/tires, premium pkg, premium sound, side/top cameras, heated seats, comfort access, ceramic controls, OEM spoiler, painted front reflectors, 35% tint, rear Fog lights, coded to my liking.
Old 08-17-2012, 01:18 PM
Mein Auto: 320D F30
@griffin....
the same like me... i have absolutly the same problem... i can .... ;-))
THE ECU is write protectet i think...
@ shawnsheridan
the last numbers... ARE
***7602_DIAGADR10
Please send me a PM... i dont want my VIN write here ?!
Old 08-17-2012, 01:21 PM
Mein Auto: 320D F30
... i forget ...
THX A LOT !!!
Old 08-17-2012, 01:46 PM
The reason I asked for your guys VIN#'s, is I was checking your factory installed option codes, looking to see if it was speed limited in anyway, such as:
S118A Top Speed reduction
SRM2A Top Speed US/CDN
Neither of you have either of the above option codes, so that is not it. It also tells me that it is limited to 130 mph by default without any option code.
For M-Sport, the following Option is added to increase the default 130 mph speed limit:
S840A High speed synchronisation
This seems to change VMAX-Codierung from Wert_00 / Werte=00 to Wert_02 / Werte=02 to bring it to 155 mph.
So, can you FDL Code VMAX-Codierung to Wert_02 / Werte=02, and get it to stick? If the answer is no, then I suspect it's because the DME Modules are entirely different, and the non-M-Sport's cannot be coded to support the increased speed.
Old 08-17-2012, 05:28 PM
Thanks Shawn. I will give it one more try to make the 02/02 stick. Like I said it codes ok but when I verify that it coded ok it reverts back to 210/a4 :-(. I guess thats what I get for not getting the M sport. But I couldn't effort it. Oh well I feel like my car is inadequate now even though I just wanted to go 150mph for a few seconds just once lol
Old 08-17-2012, 05:31 PM
Originally Posted by Griffin 27 View Post
Thanks sean. I will give it one more try to make the 02/02 stick. Like I said it codes ok but when I verify that it coded ok it reverts back to 210/a4 :-(. I guess thats what I get for not getting the M sport. But I couldn't effort it. Oh well I feel like my car is inadequate now even though I just wanted to go 150mph for a few seconds just once lol
If you can't FDL Code it, try adding 840 to the VO and see if it will calculate FP and let you write the VO to the car. If it does, then CODE (Not FDL Code) the DME Module.
Old 08-17-2012, 06:06 PM
Hmm not sure how to do that. I'll have to pm you for a step by step. Sounds kind of confusing. Lol
