E34 (1989 - 1995)
Old 07-04-2012, 08:57 PM
rsims5series rsims5series is offline
Mein Auto: 740I
Missing Blower resitor?
OK, I just got the car a week ago,I have so far got the Windows working the battery stays charged and I found front seats because this car has the Twisted and ripped passenger seat.all interior lights working now and few other things I forgot already...
BUT.....
Now Im trying to get the AC working,I have googled and been on the forums and have found how to change the blower resistor,I think I should have mine on the driver side above the Gas pedal??? If so its missing? I see a plug with 4 wires is that the correct Plug and does the resistor snap on the heater housing ? what else can I be missing.....all the duct work was already off so Im asuming the last guy was trying to do the job and never got to it....
rs
Old 07-04-2012, 10:05 PM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
Sounds like it was removed and never put back. Hopefully for no good reason.
pics would help.
Old 07-05-2012, 12:56 AM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Yes above the gas petal it plugs into the heater housing.About $42 or so shipped.The new are Blue the originals are Brown
Name:	Blower Resister.jpg
Old 07-05-2012, 05:14 AM
Mein Auto: 740I
blower resistor
Here are some pics... I ordered the resistor the other day on ebay 29.99 free shipping, also theres a pic of a Orange resistor looking part? it opens on a small spot to show a few silver pieces.
thks
rs
ID:	331689   Click image for larger version
ID:	331690   Click image for larger version
ID:	331691   Click image for larger version
Old 07-05-2012, 08:23 AM
luckydog's Avatar
Pretty sure the orange connector on pass side is a air bag related. were you able to locate the cabin filter?
Old 07-05-2012, 08:26 AM
luckydog's Avatar
E-34 convertable
Old 07-05-2012, 09:01 AM
Mein Auto: 740I
blower resistor
Lucky I havent looked for the cabin filter as of yet,Im trying to sort thru whats suppose to be where..Im waiting for the resistor to come in and see what happens. Should the AC work without it? I tried charging the ac but the gauge shows high pressure,"stays in the red" and the clutch hasnt come on? the compressor does, should I keep trying to fill it until the clutch engages???.
rs
Old 07-05-2012, 07:00 PM
The A/C should work as long as the blower fan comes on. You just won't be able to use speeds 1,2,and3, only 4. Sounds like a problem with your pressure switch on the A/C receiver drier. There should be a way to jumper the switch somehow.
The pictures above were of the passenger side glovebox. The resistor is supposed to be on the drivers side directly above the accelerator pedal. Look there instead.
Old 07-05-2012, 07:05 PM
Mein Auto: 740I
blower resistor
paperplan the pics are of both sides, you can see the driver dash stuff removed and the one pic shows above the gas pedal, there is no resistor there at all..? It shipped ,so in a few days Ill get that on , in the mean time the ac clutch hasnt engaged,the AC light is on and the comprssor is on but no cluch doing anythg, maybe ill try more freon... ill try again when its a little cooler out, its 100 plus here and i have other cars to use ...
rs
Old 07-05-2012, 07:07 PM
Ah hard to tell but now I see. The coolant pipes gave it away finally.
Yeah, throw a resistor on there and see what she does.
Old 07-05-2012, 09:43 PM
supertech777's Avatar
supertech777 supertech777 is online now
Mein Auto: 1995 525i
rs
The compressor is not on if the clutch is not engaged .
Sent from my Desire HD using Bimmer App
Old 07-05-2012, 09:54 PM
The only way you can get the system to take r134 in there is to have the clutch engaged . If you don't its useless to even try . You have to bypass that swtich like paperplane sugested
Old 07-05-2012, 11:40 PM
luckydog's Avatar
Lucky I haven't looked for the cabin filter as of yet,Im trying to sort thru whats suppose to be where..Im waiting for the resistor to come in and see what happens. Should the AC work without it? I tried charging the ac but the gauge shows high pressure,"stays in the red" and the clutch hasnt come on? the compressor does, should I keep trying to fill it until the clutch engages???.
rs
Not sure if that s your ac problem but it may be,since the blower resistor allows for 3 speeds of the blower. You may want to check fuses too. Wile your there check your cabin filter. Right side passenger side left of foot well. "
remove the glove box at lower strap clips and 2 rear release hinge ,remove 2 covers on lower left passenger side carpet panals , . remove Pass side air duct at feet . In the very back left middle of firewall look up to your left with a flashlight. Remove plastic filter access door. Its the only cream colored plastic door back there.Its about 3 in wide and 8 in long One # 8 torks screw low on the door and a funny plastic blade at top that swings left to open. There will be a slim black climate control component box in the way of sliding out the filter.This small box is removable to allow the filter to be easily removed. Filters are 10 to 50 dollars. Bring vacuum with long narrow attachment for filter housing. Be prepared to be completly disgusted by how dirty it is with hair, dirt, dust ,leaves, grease . Watch your heating and cooling system come back to full strength as it can breath again. Very easy change 30min job LD
Old 07-07-2012, 07:25 AM
Mein Auto: 740I
blower resitor
Yeaa, Got the resistor,, plugged it in and I have all speeds on the fan, NOW I have to get the Ac working, Where do I jump the compressor to get to see if everythg is working?
rs
Old 07-08-2012, 12:22 AM
luckydog's Avatar
I would research and test related fuses and relays. I know that the green led will come on the button, when the snowflake symbol button is pushed and vent dials are turned to blue and the blower is set to blow. # 5 is the relay in this pic below. I think their is a related fuse too.
Old 07-09-2012, 07:02 PM
Mein Auto: 740I
blower resistor
OK, Drove 230 miles total today ,Picked up 2 front seats LIKE NEW cond.. some other stuff.Hopefully Ill get to install them tomorro and get driving the car.
On the AC, When I turn it on I hear/see the engine rpms go up ,,the ac button is lit but I do not see a "Green" Light...the clutch is NOT coming on,Ill check the temp switches and others tomorrow.anythg else? This should be r143a already? the gauge fits?
rs
Old 07-10-2012, 09:59 AM
Mein Auto: 740I
ac relays?
?? the smaller relay box under the hood has 2 relays and looks like a third should be there??? i have a yellow light green and a missing spot I think?
rs
Old 07-10-2012, 09:33 PM
rs
That is normal. Relay connector is there for a feature you don't have.
You need to jumper the switch at the A/C reciever drier to turn the compressor on. I don't know the exact wire or wire color so search!
