Old 06-13-2012, 11:03 AM
A2dor3d A2dor3d is offline
Mein Auto: 550i
Smog check
My 540i failed smog check at 15 mph but passed at 25 mph.
Is there something that can be replaced or adjusted or repaired other than replacing the cats to pass???
Old 06-13-2012, 01:23 PM
acoste's Avatar
acoste acoste is online now
Mein Auto: 2010 550i MT
The previous owner of my car had issues with the smog check and replacing the evaporative emission control valve did solve that. I don't know to much about it but I saw the service records.
Old 06-13-2012, 01:32 PM
Mein Auto: 550i
Thanks for the tip. I'll look into it.
Old 06-13-2012, 05:37 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
What is the model year of the car? How many miles? Do the cats rattle when struck with a rubber mallet?
If you have a '97-'98, you can do Magnaflow cats. Otherwise, you're at the mercy of the dealer. You're probably close to needing new cats.
I was able to get mine to squeak past be replacing the pre-cat O2 sensors. Bosch only! Got them at AutoZone. It had failed the 15 MPH test.
Old 06-13-2012, 05:52 PM
Mein Auto: 550i
Thanks for the input. It's 97' 540i 200k. I'll do the cat check, I was getting a low voltage read on pre O2 sensor in bank 2 a while back and never came back.
Old 07-03-2012, 06:08 PM
Mein Auto: 550i
Finally passed with flying colors 200k miles and all. Replaced pre cat O2 sensors made a huge difference huge... Thx for the info all.
Old 07-04-2012, 02:55 AM
Please post the results here so we all benefit:
- What you can expect for E39 smog emissions test results (1)
Old 07-05-2012, 08:24 AM
Mein Auto: 550i
1st check it failed at 15rpm. It was over the allowed NO max of 409 measured 1407. Passed at 25rpm NO max 695 squeezed by at 694 measured.
After replacing the pre cat O2 sensors the 15rpm NO measured 53 and at 25rpm measured 28. Huge difference. Hope this helps anyone having smog check problems.
I purchased the replacement O2 sensors at autozone. BOSCH 13559
