Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 07-05-2012, 03:21 PM
tom@3dproducts's Avatar
tom@3dproducts tom@3dproducts is offline
Mein Auto:
3d bug remover
http://www.3dproducts.com/Bug-Remover.html?a_aid=8013
Easily removes bug stains
Breaks up and dissolves protein based stains
Safe on car paint and windshields
Bug Removers for Cleaning the Bugs and Insects off your Cars
Bug remover is especially designed to remove bug and insects from the exterior surfaces of your car. This enzyme based product will rapidly loosen-up and eliminate the protein based stains off your vehicle.
It's not possible for you to only wipe bugs off your car with a car soap. Sometimes the sun makes the bugs and incests stick to the paint of your car and the grill, after they get baked on they can be stubborn to remove. So consider using 3D Bug Remover Solution with a bug sponge specially designed to be gentle yet tough when trying to get your car’s paint clean. The best thing to do is apply some bug remover on the affected areas. It's an effective and environment-friendly way to get rid-off dried bug and insects. You can ask others who have had their share of using the car bug remover, this is the easiest method. Most of the comments you will get is that this remover has made it a lot easier for car owners to get rid of all protein based stains particularly in the windshield and hood of the car where most of the bug and insects reside.
Wondering, “How do I remove bugs from my winshield?” What makes the bug remover such an effective cleaner is the components that make it up. Designed to loosen the dried bug deposits on any part of your car, making them easier to get rid of. Along with the remover itself, certain cleaning tools like the 3D bug sponge can make the cleaning a lot faster and a lot more effective. All of this makes for an easier car cleaning experience.
You can also use this on your motorcycles after you've been dirt biking and you happened to get some insects stuck on your motor cross vehicle.
If you're looking for an affordable bug remover and other car care products you can trust 3dproducts.com!
DETAILING MADE SIMPLE
www.3dproducts.com
First time buyers, use coupon code TD5
www.autopia.org
www.hdcarcare.com
