Old 07-05-2012, 11:54 AM
rictrd rictrd is offline
Mein Auto: E46 330i
ASC blinks at 60kph
Strange issue, have an 2002 530i (Europe version) driving at 60kph and the ASC light blinks and the car won't accelerate even stepping at the gas pedal, and is just at 60kph, below that the car drives ok. And until the car slows below 60kph the ASC lights goes off and the car starts to drive normal and then passing 60kph the ASC blinks again and the car won't accelerate.
I have tried manually switching off the ASC button and the car drives normal and it does pass 60kph with the ASC off, but then turn on the ASC the car won't pass 60kph, have already changed the ABS module and still has the same problem with a borrow module, anyone have or experinced this issue can point me how to fix it? thanks
I can drive the car normal passing 60kph with the ASC off but now is winter here an I would prefer if the ASC is working...
Old 07-05-2012, 01:04 PM
Mein Auto: E46 330i
Anyone?
Old 07-05-2012, 01:06 PM
acoste's Avatar
acoste acoste is online now
Mein Auto: 2010 550i MT
Get a code reader. This must have stored codes.
Sent from my ADR6350 using Bimmer App
2010 BMW 550i MT
2003 BMW 325i @190k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 07-05-2012, 01:20 PM
Mein Auto: E46 330i
I have get it read already but has no fault codes...
Old 07-05-2012, 05:31 PM
acoste's Avatar
I only have a guess but don't know.
The rotation rate sensor (rpm rate sensor) which prevents car from rollover works at higher speeds only since there is a low chance to roll over at low speeds. I don't know what is the speed threshold there, could be 60.
I guess your ABS works which means speed sensors are o.k.
Steering angle sensor? Brake pressure sensor (must be o.k.)?
Old 07-05-2012, 06:08 PM
mjheinz mjheinz is offline
Mein Auto: bmw 525
The same thing happened to my friends 525. It turned out they had to replace the ABS/DSC module,,,even though the light didn't stay on all the time.
The other possibility...and another friend had this happen (this is no BS), there was something wrong with his trannie, and when his car hit 60, it wouldn't shift and then it would go into a fail-safe mode...
Hope its nothing serious...
