The X5 SAV Forum
Old 07-03-2012, 12:05 AM
Jo Mozone Jo Mozone is offline
Mein Auto: X5 - 2001
air bag light is on
Hi,
i have the airbag light on, after opening one of the doors and replacing the window actuator.
are there any fuses for the airbags ??
mine is a 2001 ,
Thanks,
Old 07-03-2012, 07:22 AM
Zulu95's Avatar
Zulu95 Zulu95 is online now
Mein Auto: 2001 X5 3.0L
Sounds like you disconnected a wire in the door airbag. You'll need to have the airbag code read and possible go back in and have a look. I would try and pick up a Peake SRS code reader/reset unit.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
Old 07-05-2012, 04:16 PM
infamous212 infamous212 is offline
Mein Auto: '04 BMW X5 4.4i, '05 G35
I've done this several times, only way to clear that light is to buy the srs code reader and clear it...
'04 4.4i BSM/TB w/ spt & premium pkg, pan roof, navi.
'05 Infiniti G35
'00 e39 M5 (sold)
Old 07-05-2012, 05:17 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
If you had the airbag disconnected while the battery was connected you will get the light. It needs to be cleared by a code reader. GT1, INPA, CarSoft, PA Soft, Auto Logic, Bavarian Technic. I don't recommend the Peake tool because it's a one trick pony. $100 and you'll likely only use it once.
Old 07-06-2012, 06:48 AM
teps9968 teps9968 is offline
Mein Auto: 2006 BMW X5
Smile Coolant Adding Often
I reasonly change my expansion coolant resevior and for some strange reason I have to add coolant every few days. I pressure checked it and I don't see any leaks anywhere. Can someone give me an idea what to do.?
Old 07-06-2012, 10:42 AM
ECSTuning's Avatar
Instructor of the Stig™
Agreed.
The Peake SRS Reader is a simple tool which is a must when dealing with air bag lights. Sine your X is an 01 you can use the Peake SRS Reader found HERE, but just to insure it's the one you need check for 20-pin round port in engine bay.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 07-06-2012, 12:23 PM
tmvE39/E53/Z32's Avatar
Stop hijacking and start your own thread.
Did you bleed the cooling system properly?
