Old 07-06-2012, 04:36 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Thumbs up BMW ISTA-D 2.30 ENG (UK) + GER (DE) On VMWare
Courtesy of monekyboy8888 on bmwcoding.com:
RapidShare Links:
https://rapidshare.com/files/1929458..._VM.part01.rar
https://rapidshare.com/files/2564352..._VM.part02.rar
https://rapidshare.com/files/6290184..._VM.part03.rar
https://rapidshare.com/files/9486747..._VM.part04.rar
https://rapidshare.com/files/2050106..._VM.part05.rar
https://rapidshare.com/files/2700713..._VM.part06.rar
https://rapidshare.com/files/3583804..._VM.part07.rar
https://rapidshare.com/files/1421920..._VM.part08.rar
https://rapidshare.com/files/7906549..._VM.part09.rar
https://rapidshare.com/files/3823837..._VM.part10.rar
https://rapidshare.com/files/2935312..._VM.part11.rar
https://rapidshare.com/files/5791451..._VM.part12.rar
Torrent File:
http://fs07n5.sendspace.com/dl/3ccf5...202.30.torrent
1) Needs VMWare or VMWare Player to run VM.
2) Needs Genuine BMW ICOM, or ICOM Clone, or ICOM Emulator.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 07-06-2012, 05:20 PM
john mclane john mclane is offline
Mein Auto: X5 5.0
Pardon my noob ignorance, what's the difference to the E-sys?
Well, never mind, search is your friend :
http://www.obd2be.com/bmw-ista-p-635.html
X5 5.0 MY12, M package, black sapphire
650i vert, MY12, Blue/ivory, to be modded soon...
Gone: 997.2 modded, 987s (not forgotten ), MB C55 amg, Passat W8, Cayenne MY 08
Old 07-06-2012, 05:23 PM
E-Sys is similar to ISTA/P for Progamming. ISTA/D is for Diagnostics. It has wiring diagrams and diagnosis, but also repair and replace, training, and other documents. essentially DIS, WDS, TIS, etc. all combined.
- BMWCCA #446923
- flick
Old 07-06-2012, 05:27 PM
Mein Auto: X5 5.0
Thanks, good stuff as usual!
Slightly deviating from subject, try adding 5AS to your FA. Then go to HUD and see the new options, including SLI ON/OFF...
Old 07-06-2012, 06:43 PM
Thanks, but I don't have a HUD...that's DreamCar's project.
- BMWCCA #446923
- flick
Old 07-06-2012, 07:29 PM
Mein Auto: X5 5.0
I found that this addition releases the SLI ON/OFF option on coding. That shouldn't matter if you have HUD or not, only the lane departure warning, I believe.
Some of the options are in the KAFAS also...
It also shows a fog detection system with automatic fog lights, particularly useful in soupy days in the Galveston area...
Old 07-06-2012, 07:35 PM
I should have specififed that I don't have LDW either, so I do not have the camera for SLI at all. Automatic Fog Lights are interesting, although I image it's tied to the same camera and SLI weather system.
- BMWCCA #446923
- flick
Old 07-06-2012, 08:46 PM
Mein Auto: X5 5.0
Bummer, makes you itch to put a new one on order...I think next time I'll only get (I rarely order) the hardware on board, the software can be dealt later...
Old 07-07-2012, 09:42 AM
JEG23 JEG23 is offline
Mein Auto: 550i
@shawnsheridan
Thanks for the links. Any suggestions on where to get the BMW ICOM?
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 07-07-2012, 10:51 AM
John, can you clarify this. Are you saying by adding to the VO and coding a module, the CAFD file has new entries that can be FDL coded that did not exist before, or only that new options appear in iDrive that were not previously present?
- BMWCCA #446923
- flick
Old 07-07-2012, 10:59 AM
Originally Posted by JEG23 View Post
@shawnsheridan
JEG23
A seller recommended to me the following Chinese ICOM Clone, however, I did not purchase it, so I cannot personally vouch for it:
http://www.chinamaster88.com/En/ProductView.asp?ID=104
I believe the cost is around $700, a bargain compared to an original BMW ICOM, which is north of $3500.
I am trying to go the software ICOM Emulator VM route, which should cost around $150, but I need to better understand it's limitations. As I understand it, it can be used with E-Net for ISTA/D fully, however, with ISTA/P it is limited to Coding and no Programming.
- BMWCCA #446923
- flick
Old 07-07-2012, 10:32 PM
Mein Auto: X5 5.0
The former. The entries were also in English, which I did not see in other files. They did not appear on idrive, but I need to finish changing other options.
I'll take a screen shot next time...
Please take in consideration my newbieness.
Old 07-07-2012, 10:55 PM
Please do confirm this. I have never seen or heard of where coding a VO Change added new CAFD Entries that weren't already there. If true, it could explain why some FDL Codes that one would think should exist haven't been found, as most people bypass the VO change.
- BMWCCA #446923
- flick
Old 07-08-2012, 05:37 AM
Mein Auto: X5 5.0
Again, accounting that I just started doing this, when I changed the VO with those options, I had CAFD entries that were not there before and the entry description was in English, which I did not see anywhere else.
I can reply later with the FA options I have and you see if it's indeed the way I described or I'm just too new at this...
Old 07-08-2012, 02:48 PM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: Future: F80 M3
Wow ! Finally ... Thanks Shawn!... Not sure how many people would really realize the effort in making these things available ....
And we should look in to the idea of gathering funds so that we can get hold off the software which are financially limited... There are hundreds/thousands? of folks who got benefit out of our mission , i hope it shouldnt be a issue.
Old 07-10-2012, 05:03 AM
cn555ic cn555ic is online now
The Coder guy in N.Y
Mein Auto: bmw
Icom emulator is no longer for sale At the 150 price, in fact it's now up to 350 for it. I inquired about it a month ago and it was at 15O but now it's jacked up to 350. Sucks. So it's either Chinese Icom for 700+ or Icom emulator for 35O. At those prices clone would be better
Old 07-10-2012, 06:44 AM
miotoo miotoo is offline
Mein Auto: F10 520d
Supply & demand...but not worth it for that price. The clone I saw close to the ~600 already with shipping. Wait an see the number of offers in alibaba, as they go up, the price goes down.
F10 520d born 11.04.2011 Deep Sea Blue
205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1
Old 07-11-2012, 04:00 PM
April1 April1 is offline
Mein Auto: X3 2011
Originally Posted by dreamcar View Post
wow ! Finally ... Thanks shawn!... Not sure how many people would really realize the effort in making these things available ....
And we should look in to the idea of gathering funds so that we can get hold off the software which are financially limited... There are hundreds/thousands? Of folks who got benefit out of our mission , i hope it shouldnt be a issue.
+1
Old 08-08-2012, 08:19 AM
TibeRiuS TibeRiuS is offline
Mein Auto: F25
I manage to get ISTA-D working on Vmware, but I can't get a genuine BMW ICOM to connect.
Is there any settings in vmware network that must configure? like IPs.........
Hope anyone can help me.
Thanks!!
Old 08-23-2012, 10:51 PM
chli1976 chli1976 is offline
Mein Auto: S1000RR
Part11 is offlin, can anyone upload it again please
Thank you
Old 11-04-2012, 03:35 AM
Mein Auto: F10 520d
ICOM clone down to $466...
Old 11-04-2012, 08:15 AM
Mein Auto: F10 520d
@Shawn, according to this document, wouldn't we only need ICOM A to use ISTA/D in our F10's -> laptop ethernet?
If yes then ICOM A alone is available for $235..rather take that than a vm emu..
Old 11-04-2012, 08:18 AM
If yes then ICOM A alone is available for $225..rather take that than a vm emu..
Agreed, but where can you buy quality Chinese ICOM A Only clone?
- BMWCCA #446923
- flick
Old 11-04-2012, 08:51 AM
Mein Auto: F10 520d
I think it's the same guy you mentioned in your July post above..
http://www.aliexpress.com/item/For-B...668733329.html
Old 11-04-2012, 09:38 AM
clausx3 clausx3 is offline
Mein Auto: X3 20d f25
Very interesting, the price now is also approachable by a hobbyist like me
