Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 06-14-2012, 10:33 AM
flexstar flexstar is offline
Mein Auto: E60, Porsche987, MB320
Need a wax that doesn't turn black trim white.
I've used P21 wax on my new X5, and where I hit the black trim it turns white and is very difficult to remove. Is there a good quality wax that won't make the black trim turn white? As we 2012 X5 owners know, there is a lot of black vinyl on these vehicles. Thanks!
Old 06-14-2012, 10:46 AM
rdorman rdorman is offline
Mein Auto: 2000 imola red 740i Sport
I use KAIO topped with Collinite 845. You can skip the KAIO as it is more a cleaner then anything else. I actually wax all my plastic trim so I don't have to dress it seperate. Most spray waxes are fine as well just don't last as long as the 845 and it is so easy to use.
Old 06-14-2012, 10:59 AM
ncbuckeye ncbuckeye is offline
Mein Auto: 335d
Zaino won't turn trim white!
Old 06-14-2012, 06:32 PM
OTD OTD is offline
Mein Auto: ///
Opt-seal will not make trims white
Old 06-15-2012, 07:15 AM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: F10 535/E92 335i
use tape and mask the car up before you do any work on it.
Old 06-15-2012, 07:53 AM
No point when waxing. Just use the correct products.
Old 06-15-2012, 08:21 AM
dboy11 dboy11 is offline
Mein Auto: 99...540i
Getting some wax in or on the trim is impossible at times. What you need is product that will remove it. My go to for this is Poorboys World, Trim Restore. Depending on the trim if it's grainey then use a old tooth brush, put some on the brush and brush the trim, wipe off with a MF towel.. The plus is it makes the trim look new again and protects it. If its smooth, then a cotton applicator with some TR on it and it will clean the area up real fast buff with a cotton towel.
Its Going To Cost How Much???????
Old 06-15-2012, 09:53 AM
3ismagic#'s Avatar
3ismagic# 3ismagic# is online now
HerrDoktorProfessor
Mein Auto: '11 335d
Havent had any issues with either Einszett Glanz or Dodo Juice Blue Velvet Pro.
Entertaining America Since 1975
European Delivery July 26th 2011
ED Video: https://vimeo.com/60051914
ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294
335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns
BMWCCA #448878
Old 06-18-2012, 10:32 PM
x26's Avatar
x26 x26 is offline
*** Team America ***
Mein Auto: 335i
Question
Will Black Fire wet diamond dis-color rubber seals and plastics??
Thanks in Advance
Old 06-19-2012, 12:13 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
That sounds like good advice to me for a car that has lots of trim. My 335i isn't so bad, and so I'm sometimes lazy about taping it up.
The OP is asking for the correct products, and since I also would like to know, maybe you could share which ones they are? I haven't used my 476S in a while, but one of the main reasons I picked it over FK1000P (when curious about longer lasting waxes) is because it's supposed to be more forgiving on trim. Not "correct" as in no problem at all, just more forgiving; I would still recommend taping with this stuff on the OP's vehicle.
Thanks for the suggestion, and techniques, perhaps I'll pick some up in the future.
Old 06-20-2012, 09:45 AM
See post #2. The only time I tape any more is when polishing.
Old 07-04-2012, 09:46 AM
BigWhup BigWhup is offline
Mein Auto: 2011 Black Sapphire 750IL
Zaino!
Old 07-05-2012, 09:22 AM
tom@3dproducts's Avatar
tom@3dproducts tom@3dproducts is offline
Mein Auto:
I'll add to the list HD POXY and HD NITRO SEAL - both products should be applied to trim and windows in addition to the paint.
http://www.3dproducts.com/HD-Poxy.html?a_aid=8013
http://www.3dproducts.com/HD-Nitro-Seal.html?a_aid=8013
DETAILING MADE SIMPLE
www.3dproducts.com
First time buyers, use coupon code TD5
www.autopia.org
www.hdcarcare.com
Old 07-07-2012, 06:10 PM
X308Black X308Black is offline
Mein Auto: x3 3.0si
I LOVE poorboys polishes!! easy on and easy off
